GB Z370 k3 - i5 8600k - RTX 2060
StewieT
Nella tastiera pur avendo selezionato layot italiano risultano invertiti alcuni tasti... come "<>" e "\|" 😐
Continua a non funzionare lo Stop ..
Sleep Wake failure in EFI
Failure code:: 0xffffffff 0x0000001f
Please IGNORE the below stackshot
Date/Time:        2020-04-06 18:36:45 +0200
OS Version:       ??? ??? (Build ???)
Architecture:     x86_64
Report Version:   29
Data Source:      Stackshots
Shared Cache:     0x947000 80D146EE-7B06-3ECA-811B-A8E9E87C451D
Event:            Sleep Wake Failure
Duration:         0.00s
Steps:            1
Boot args:        nv_disable=1 -wegnoegpu
Time Awake Since Boot: 13s
Process:          swd [260]
Footprint:        400 KB
Start time:       2020-04-06 18:36:45 +0200
End time:         2020-04-06 18:36:45 +0200
Num samples:      1 (1)
  Thread 0x7b7    1 sample (1)    priority 4 (base 4)
  <thread QoS background (requested background), thread darwinbg, process darwinbg, IO tier 2>
  1  start + 1 (libdyld.dylib + 109769) [0x7fff678b6cc9] 1
    1  ??? [0x10ad81454] 1
      1  ??? [0x10ad811dd] 1
        1  __stack_snapshot_with_config + 10 (libsystem_kernel.dylib + 135862) [0x7fff67a182b6] 1
         *1  ??? [0xffffff80002c8206] 1
           *1  ??? [0xffffff80009875f7] 1
             *1  ??? [0xffffff80008a0001] 1
               *1  ??? [0xffffff80002eb9e7] (running) 1
  Binary Images:
        0x7fff6789c000 -     0x7fff678d2fff  libdyld.dylib (750.5)               <D2A07EF5-A64B-3692-BE13-89DAA2EC5E80>  /usr/lib/system/libdyld.dylib
        0x7fff679f7000 -     0x7fff67a23fff  libsystem_kernel.dylib (6153.101.6) <E76440E1-D1E8-3D9A-8B47-D01F554FF1C4>  /usr/lib/system/libsystem_kernel.dylib
Model: iMac19,1, BootROM 1037.100.345.0.0, 6 processors, 6-Core Intel Core i5, 4,7 GHz, 16 GB, SMC 2.46f12
Graphics: kHW_IntelUHDGraphics630Item, Intel UHD Graphics 630, spdisplays_builtin
Memory Module: BANK 0/DIMM1, 8 GB, DDR4, 3200 MHz, G Skill Intl, F4-3200C16-8GTZR
Memory Module: BANK 1/DIMM1, 8 GB, DDR4, 3200 MHz, G Skill Intl, F4-3200C16-8GTZR
Network Service: Ethernet, Ethernet, en0
PCI Card: Intel UHD Graphics 630, sppci_vgacontroller, Slot- 3
PCI Card: Intel Series Chipset Family USB xHCI Host Controller, USB Controller, Built In
PCI Card: Intel Series Chipset Family IMEI Controller, IMEI Controller, Built In
PCI Card: Intel Series Chipset Family SATA Controller, AHCI Controller, Built In
PCI Card: Realtek ALC Audio Controller, Audio Controller, Built In
PCI Card: Intel I219V2 PCI Express Gigabit Ethernet, Ethernet Controller, Built In
Serial ATA Device: ST2000DM008-2FR102, 2 TB
USB Device: USB 3.0 Bus
USB Device: Gaming KB
USB Device: ZOWIE Gaming mouse
USB Device: USB 3.1 Bus
Thunderbolt Bus:
ho provato pure ad applicare il Fix per Shutdown/ Stop/Sleep
Change PTS to ZPTS
Find: 5F505453
Repl: 5A505453
ma nulla 😞
in più vedo girare la ventola della scheda video nvidia, che invece dovrebbe essere disabilitata....
Edited by StewieT
@StewieT oh bene! questa volta hai tutte le 24 porte USB presenti, ora devi:
Nota 2 - estrarre e postare le ACPI: spesso viene fatta questa richiesta, ecco come fare: riavviare l'hack e fermarsi nella GUI di Clover, premere il tasto F4 e aspettare 30/40 secondi (a monitor non succede assolutamente niente) poi avviare regolarmente, montare la EFI, comprimere e uplodare la cartella origin che si trova nel percorso
EFI --> CLOVER --> ACPI
Nota 4 - Mappature delle USB: per eseguire tale operazione occorre che il sistema abbia tutte le USB attive con USBIjectall + Port Limit Patch (per i notebook solitamente basta USBInjectall) poi armati di pendrive USB 2 e 3 si avvia ioreg e una alla volta si infila ed espellono entrambe le pendrive in tutte le porte presenti, si prosegue con ioreg -> file -> save as si salva, si comprime e si posta nel proprio thread o in quello dedicato assieme alle ACPI estratte ed eventualmente la EFI senza all'interno la cartella APPLE o Microsoft che appesantiscono il tutto e non servono a niente.
perfetto ecco a te! grazie sempre!
Archivio.zip
missione compiuta! ora @StewieT fai backup di questa EFI, hai ssdt x hack by gengik operativo e mappato le USB
per scrupolo controlla che ti funzionino tutte le porte, ma sulla carta siamo a posto
in caso di aggiornamenti di macOS, non ti prtecipitare ad aggiornarlo, prima controlla sul forum se vi sono problematiche, aggiorna Clover e kext, poi procedi
Ora prova anche se va in stop
puoi provare a settare dei valori di darwake da inserire inboot arguments, setta, salva, riavvia testa
314390396_Schermata2020-04-07alle00_47_36.thumb.png.5cd142546e5d739ccde27b0c79837e4d.png
grazie mille!! per testare lo stop devo rimuovere il flag su never hibernate?
30 minutes ago, iCanaro said:
non mi pare siano correlati, ma nel dubbio, togli pure il flag 🙂
su config --> kernel & kext patches --> KextsToPatch  non devo rimuovere le 2 patch per il portlimit?
Edited by StewieT
