Administrators Gengik84 Posted March 18, 2020 Administrators Share Posted March 18, 2020 fai una foto al verbose prima del riavvio. oppure piccolo video. Link to comment Share on other sites More sharing options...
nikfol Posted March 18, 2020 Author Share Posted March 18, 2020 ecco il video WhatsApp Video 2020-03-18 at 13.05.23.mp4 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 18, 2020 Administrators Share Posted March 18, 2020 sostituisci ho sbagliato una cosa config.plist.zip Link to comment Share on other sites More sharing options...
nikfol Posted March 18, 2020 Author Share Posted March 18, 2020 ora e partito anche se in modo vesa,ti allego il ioreg fatto ioreg nikfol.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 18, 2020 Administrators Share Posted March 18, 2020 si ho messo io vesa prova questo dsdt nell'attuale efi, rifai ioreg https://www.macos86.it/topic/2396-asus-f555u/?do=findComment&comment=61098 in caso aggiungi anche voodooI2CElan Link to comment Share on other sites More sharing options...
nikfol Posted March 18, 2020 Author Share Posted March 18, 2020 ok provo 7 minutes ago, Gengik84 said: si ho messo io vesa prova questo dsdt nell'attuale efi, rifai ioreg https://www.macos86.it/topic/2396-asus-f555u/?do=findComment&comment=61098 in caso aggiungi anche voodooI2CElan Link to comment Share on other sites More sharing options...
nikfol Posted March 18, 2020 Author Share Posted March 18, 2020 fatto e ho aggiunto 2celan io reg nikfol.zip Link to comment Share on other sites More sharing options...
nikfol Posted March 21, 2020 Author Share Posted March 21, 2020 (edited) On 3/18/2020 at 1:40 PM, nikfol said: fatto e ho aggiunto 2celan io reg nikfol.zip 528.41 kB · 0 downloads ciao gengik84 sono riuscito a fare qualche passo in avanti da quello che mi appare in verbose, ora mi sa che il problema e con hd 520 non riesco ad avere neanche la veste grafica in vesa , quindi non sono arrivato alla casa di istallazione qualche idea per la scheda video ? Edited March 21, 2020 by nikfol Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 21, 2020 Administrators Share Posted March 21, 2020 avvia in vesa e cerca di finire l'installazione aggiungi alle boot-arg : -igfxvesa Link to comment Share on other sites More sharing options...
nikfol Posted March 21, 2020 Author Share Posted March 21, 2020 già fatto ma non va ti posto il video dove mi blocco WhatsApp Video 2020-03-21 at 20.08.17.mp4 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 22, 2020 Administrators Share Posted March 22, 2020 Non riesco a vedere bene, soprattutto la parte finale Link to comment Share on other sites More sharing options...
nikfol Posted March 22, 2020 Author Share Posted March 22, 2020 8 hours ago, Gengik84 said: Non riesco a vedere bene, soprattutto la parte finale cercando qua e la in pratica gli errori sono relativi alla maledetta scheda video nvidia che nonostante sia stata disabilitata tramite config e anche nel DSDT sembra che su catalina non siano efficaci localhost com.apple.xpc.launchd[1] Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 22, 2020 Administrators Share Posted March 22, 2020 non credo proprio... WEG funziona benissimo allega clover Link to comment Share on other sites More sharing options...
nikfol Posted March 22, 2020 Author Share Posted March 22, 2020 32 minutes ago, Gengik84 said: non credo proprio... WEG funziona benissimo allega clover ecco il clover CLOVER.zip ti allego il video magari si vede meglio questo WhatsApp Video 2020-03-22 at 20.09.58.mp4 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 22, 2020 Administrators Share Posted March 22, 2020 PCIRootUID=1 e anche nv_disable rimuovilo Link to comment Share on other sites More sharing options...
nikfol Posted March 22, 2020 Author Share Posted March 22, 2020 20 minutes ago, Gengik84 said: PCIRootUID=1 e anche nv_disable rimuovilo già fatto ma niente stesso problema Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 22, 2020 Administrators Share Posted March 22, 2020 riscarica e ricrea l'installer su altro supporto e riprova Link to comment Share on other sites More sharing options...
nikfol Posted March 22, 2020 Author Share Posted March 22, 2020 Just now, Gengik84 said: riscarica e ricrea l'installer su altro supporto e riprova ok Link to comment Share on other sites More sharing options...
nikfol Posted March 22, 2020 Author Share Posted March 22, 2020 1 hour ago, Gengik84 said: riscarica e ricrea l'installer su altro supporto e riprova Niente da fare stesso problema Link to comment Share on other sites More sharing options...
nikfol Posted March 25, 2020 Author Share Posted March 25, 2020 (edited) sono riuscito ad istallare catalina e stata dura ma ci sono riuscito ,ora il problema e elan1000 che lavora su i2c "la tastiera funziona con ps2 controller ma il track pad no chiaramente " il wifi che e una AR9002wb-1ng e l'audio un 8086 2809 ho provato con le impostazioni funzionanti su mojave ma niente da fare fortunatamente sono riuscito ad attivare la hd 520 allego foto e efi CLOVERnikol.zip Edited March 25, 2020 by nikfol Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 25, 2020 Administrators Share Posted March 25, 2020 il supporto atheros è stato rimosso, in caso devi installare un vecchio kext di sistema allega ioreg anche Link to comment Share on other sites More sharing options...
nikfol Posted March 25, 2020 Author Share Posted March 25, 2020 8 minutes ago, Gengik84 said: il supporto atheros è stato rimosso, in caso devi installare un vecchio kext di sistema allega ioreg anche ok Link to comment Share on other sites More sharing options...
nikfol Posted March 25, 2020 Author Share Posted March 25, 2020 ecco qui comunque grande soddisfazione per me ho combattuto ma ci sono riuscito 😁😁 nikfol ioreg.zip 1 Link to comment Share on other sites More sharing options...
nikfol Posted March 26, 2020 Author Share Posted March 26, 2020 (edited) buongiorno Gengik allora la situazione e questa sono riuscito a far funzionare su catalina praticamente tutto tranne che la ar9002 per l'audio e stato facile nel config e bastato mettere su audio inject 5 e ora funziona per il trackpad ho rimesso la versione vecchia di VoodooI2C.kext e il mio vecchio DSDT editato per mojave e ora funziona anche se e rimasto il problema di non avviare il osx in verbose ora voglio risolvere il problema del wifi credo sia un problema del DSDT ,non so se ti ricordi ma su questo pc accadeva una cosa strana in mojave senza il VoodooI2C.kext non mi rilevava la AR9002 "neanche tu ti spiegavi come mai succedesse questo" ,in ogni modo volevo provare ad editare il mio dsdt ,ma con MaciASL a dsdt originale estratto con clover e non ancora modificato ho tanti errori di sintesi ,mi potresti dare una mano o almeno farmi capire come eliminare questi errori ,mi sono letto vari argomenti sul dsdt ma gli errori che riporta non sono riuscito a risolverli "almeno non tutti ". ti allego il mio dsdt grazie origin_dsdt_nikfol.zip Edited March 26, 2020 by nikfol Link to comment Share on other sites More sharing options...
nikfol Posted March 27, 2020 Author Share Posted March 27, 2020 wifi funzionate con un po di pazienza sono riuscito a far funzionare tutto mi serve solo la pulizia degli errori del dsdt originale che non riesco a togliere per fare altri test con i nuovi voodooI2c Link to comment Share on other sites More sharing options...
