macOS Catalina 10.15.4
  • Contributor
Mi sono sempre chiesto...ma che ci ficcheranno ogni volta in quasi 3 Gb di aggiornamenti ? Dove si può vedere un changelog di cosa c'è di "corretto-aggiunto" in questi aggiornamenti ?
Non dicono un granche'..............
macOS Catalina 10.15.4 Beta 4 Release Notes
Update your apps to use new features, and test your apps against API changes.
Overview
The macOS 10.15.4 SDK provides support to develop apps for Macs running macOS Catalina 10.15.4. The SDK comes bundled with Xcode 11.4, available from Beta Software Downloads. For information on the compatibility requirements for Xcode 11.4, see Xcode 11.4 Beta 3 Release Notes.
Endpoint Security
New Features
  • Using a custom Mach service name is now supported for XPC between apps and extensions. See man EndpointSecurity for more information. (57244148)
Music
New Features
  • The Music app now supports time-synced lyrics for Apple Music subscribers. (53877474)
Safari
New Features
  • Content Blocker extensions delivered with Mac Catalyst apps are now available for use in Safari. (43646265)
Su macrumors c'e' invece scritto questo...................
The new ‌‌macOS Catalina‌‌ beta can be downloaded using the Software Update mechanism in System Preferences after installing the proper software from the Developer Center.
‌macOS Catalina‌ 10.15.4 includes Screen Time Communication Limits, a feature first brought to the iPhone in the iOS 13.3 update, and it brings a new Head Pointer Accessibility option that allows the cursor to be controlled with head movements using the Mac's camera.
Real-time lyrics are included in macOS 10.15.4, bringing an iOS feature introduced in iOS 13 to the Mac. Real-time lyrics allow the lyrics for a song to scroll in real-time to the music so you can follow along with what's being sung.
References to AMD processors have also been discovered in the macOS 10.15.4 beta, leading to speculation that Apple is working on AMD-based Macs, but these references could simply be for internal testing rather than evidence of an AMD Mac.
Though not directly related to ‌macOS Catalina‌ 10.15.4, Apple is adding a new universal purchase option for macOS and iOS apps, which will allow Apple device users to purchase one app that works across multiple platforms.
@KTC se ti riferisci alla nvidia, su mojave e catalina al max può essere usata per le codifiche, ad ogni aggiornamento i driver vanno allineati con nv_webpatcher
1006982894_Schermata2020-03-04alle17_09_43.thumb.png.92a1751077ebcab3c004e8574cee657b.png
per la visualizzazione a monitor uso la iGPU HD4600 a cui sono collegato in DVI-D con la 1070 e in HDMI con la HD4600 e switcho a seconda del macOS che uso
