johnnyboy Posted August 18, 2019 Author Share Posted August 18, 2019 Ioreg con cavo hdmi collegato o senza? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted August 18, 2019 Administrators Share Posted August 18, 2019 col cavo e monitor collegato Link to comment Share on other sites More sharing options...
johnnyboy Posted August 18, 2019 Author Share Posted August 18, 2019 ecco ioreg con monitor e cavo collegati MacBook Pro di johnnyboy.zipFetching info... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted August 18, 2019 Administrators Share Posted August 18, 2019 Prova config-johnnyboy.plist.zipFetching info... Link to comment Share on other sites More sharing options...
johnnyboy Posted August 19, 2019 Author Share Posted August 19, 2019 ho confrontato il mio config (a cui avevo le modifiche che mi avevi fatto e il fix di jolly) e inserito le modifiche del tuo ultimo config ma al riavvio si blocca a fine caricamento della mela non riesco a capire se ho editato male io il config o altro config.rarFetching info... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted August 19, 2019 Administrators Share Posted August 19, 2019 il config ti si è corrotto Link to comment Share on other sites More sharing options...
johnnyboy Posted August 19, 2019 Author Share Posted August 19, 2019 Devo rimettere il precedente? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted August 19, 2019 Administrators Share Posted August 19, 2019 questo è corrotto rimetti il precedente e rifai nuovamente Poi duplica il config buono, lo modifichi e rinomini esempio config-test poi dalla gui vai nelle opzioni, config e lo selezioni esegui il boot se avessi problemi ti basta riavviare e verrà caricato il config di default Link to comment Share on other sites More sharing options...
johnnyboy Posted August 20, 2019 Author Share Posted August 20, 2019 fatta la prova ma ancora niente allego ioreg con monitor attacco MacBook Pro di johnnyboy.zipFetching info... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted August 20, 2019 Administrators Share Posted August 20, 2019 continuo a non vedere il monitor nel tuo config precedente, lascia solo inject intel, quindi rimuovi il platform-id vediamo weg come si comporta Link to comment Share on other sites More sharing options...
johnnyboy Posted August 20, 2019 Author Share Posted August 20, 2019 va a cannone, sei un grande gen! appena riesco a testare il card reader (usb) possiamo chiudere il thread come risolto Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted August 20, 2019 Administrators Share Posted August 20, 2019 Ottimo! allega ioreg please :) Link to comment Share on other sites More sharing options...
johnnyboy Posted August 20, 2019 Author Share Posted August 20, 2019 un ultima cosa poco importante, il tasto fn+sleep o mi spegne il computer o lo manda in blocco ma da terminale o normalmente il pc va in standby qualè la parte nel dsdt che gestiche gli hotkeys settati? allego ioreg MacBook Pro di johnnyboy.zipFetching info... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted August 20, 2019 Administrators Share Posted August 20, 2019 Non lo so attualmente, dovrei riguardare il tutto che combinazioni usi? fn+? è proprio chiamato tasto sleep o cosa? Quote Quote o mi spegne il computer o lo manda in blocco ma da terminale o normalmente il pc va in standby Quote non ho bene capito cosa intendi Comunque servirebbe un debug e da vedere se fattibile gestire tali "chiamate" Link to comment Share on other sites More sharing options...
johnnyboy Posted August 20, 2019 Author Share Posted August 20, 2019 Fn+f1, praticamente se lo premo si spegne il monitor ma il PC non va in standby come se rimanesse fermo da terminale con pmset sleepmode va in standby tranquillamente Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted August 20, 2019 Administrators Share Posted August 20, 2019 mmm ok.. ci guardo Ha scritto dopo 3 minuti 5 secondi: Prova, anche se non sono sicuro senza un debug dei tasti DSDT-johnny.aml.zipFetching info... Link to comment Share on other sites More sharing options...
johnnyboy Posted August 20, 2019 Author Share Posted August 20, 2019 funziona perfettamente ho notato ora che non funziona il backlight per la tastiera non solo dai tasti fn ma in generale c'è qualche kext da inserire? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted August 20, 2019 Administrators Share Posted August 20, 2019 ma non dicesti che era ok fn per luminosità? Ha scritto dopo 34 secondi: o forse intendi retroilluminazione tastiera? Link to comment Share on other sites More sharing options...
johnnyboy Posted August 20, 2019 Author Share Posted August 20, 2019 La tastiera scusami non c'è retroilluminazione Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted August 20, 2019 Administrators Share Posted August 20, 2019 ah allora qui avevo frainteso https://www.macos86.it/viewtopic.php?p=40559#p40559">viewtopic.php?p=40559#p40559">https://www.macos86.it/viewtopic.php?p=40559#p40559 pensavo andasse anche fn per luminosità su quale combinazione è? Link to comment Share on other sites More sharing options...
johnnyboy Posted August 20, 2019 Author Share Posted August 20, 2019 Fn+f3 per diminuire e fn+f4 per aumentare Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted August 20, 2019 Administrators Share Posted August 20, 2019 prova DSDT-johnny.aml 2.zipFetching info... Link to comment Share on other sites More sharing options...
johnnyboy Posted August 20, 2019 Author Share Posted August 20, 2019 no niente ma la cosa strana è che proprio non funziona il backlight della tastiera Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted August 20, 2019 Administrators Share Posted August 20, 2019 prova anche senza combinazione tipo f3 invece di fn+f3 Link to comment Share on other sites More sharing options...
johnnyboy Posted August 20, 2019 Author Share Posted August 20, 2019 no niente ho notato solo una cosa il tasto pausa/interr (senza fn) aumenta la luminosità (?) e alcune combinazioni di tasti (ho provato ad esempio fn+stamp) mi bloccano il il trackpad Ha scritto dopo 1 minuto 29 secondi: edit il tasto stamp anche senza fn blocca il trackpad Link to comment Share on other sites More sharing options...
