Support Team iCanaro Posted March 9, 2018 Support Team Share Posted March 9, 2018 Software consigliato da jolly e con giusta ragione, che permette anche con la versione base gratuita di individuare nel proprio sistema adware e porcherie varie. Quindi NON installate antivirus e amenità varie, al limite, mia opinione, reimpostare SIP a 0x0 V. 4.1.1 https://etrecheck.com">https://etrecheck.com EtreCheck will help you: Find serious problems on your Mac, Remove annoying adware, Get help on Apple Support Communities, See just what your Mac is doing on the inside. Safety: EtreCheck does not install files in hidden directories, EtreCheck reports protect your personal information when posted online, EtreCheck makes no changes without your consent. Reliability: EtreCheck will not slow down your machine, EtreCheck will not cause other apps to crash, EtreCheck uses little memory while running and no memory when not running. Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 9, 2018 Administrators Share Posted March 9, 2018 Ho spostato questo topic in software :) Link to comment Share on other sites More sharing options...
Fasullo Posted March 10, 2018 Share Posted March 10, 2018 Non più gratuito Link to comment Share on other sites More sharing options...
Moderators Jolly Posted March 10, 2018 Moderators Share Posted March 10, 2018 Non usate il 4. Ultima release del 3 va benissimo. Purtroppo pare non si possano più fare certe operazioni automatiche ma come diagnostica va benissimo. Link to comment Share on other sites More sharing options...
