VerifyMsrE2
netgear
che intendi?
quel driver al boot ti dice se hai msr E2 locked o no se non sbaglio
Ha scritto dopo 1 minuto 3 secondi:
Ps
Gigabyte ed asrock lo hanno sbloccato di default
asrock grazie a fabiosun :) *
Asus negli ultimi bios ha una opzione (parlo di x99 e x299)
Ha scritto dopo 5 minuti 43 secondi:
Segue richiesta che feci nel 2014
> 寄件日期: 2014年1月20日 上午 05:44
> 收件者: Asrock TSD
> 主旨: Re: Re Cold boot problem
> Hello AsrockTSD Team,
> I would to like to know if is it possible to have a 3.90 bios for X79
> Extreme 9 with unlock MSR 0xE2 bit 15
> I have to do some test
> Thank you in advance
Dear Customer,
> Thanks for contacting ASRock.
> Please update BIOS L3.91 from attached file for try, it unlock the specific bit of MSR.
> Can you tell us what's the application of that, install Mac OS?
> Thanks for your mail.
> Cheers,
> ASRock TSD
Thank you for your fast answer.
Yes i would like to install osx 10.9.2
I have ha success with your 3.90 firmware having OSX working perfectly with X79 Extreme 9 and xeon v2 cpu
i have only limited osx speedstep control
with msr unlock should be ok
today i will try
with 3.90 firmware all is working except game blaster audio, it is not supported
thank you again
Dear Customer,
Thanks for your mail and feedback.
Have a nice day.
ASRock TSD
MI riferivo al pdf di OC:
AppleXcpmCfgLock
Type: plist boolean
Default value: false
Description: Disables PKG_CST_CONFIG_CONTROL (0xE2) MSR modification in XNU kernel, commonly causing early kernel panic, when it is locked from writing (XCPM power management).
Note: This option should avoided whenever possible. Modern firmwares provide CFG Lock setting, disabling which is much cleaner. More details about the issue can be found in VerifyMsrE2 notes.
Quello è KernelPM....
stessa cosa di clover...con quello che hai linkato tu...c'entra ma molto relativamente...
Ha scritto dopo 1 minuto 20 secondi:
Quindi cosa e quale correzione vorresti provare?
di fatto non hai bisogno di nulla :)
ma poi scusa eh
una correzione diretta su bios per cosa poi?
quando non c'e bisogno e per non usare kernelPM?
ma dai non ha alcuna logica.
Ha scritto dopo 11 minuti 8 secondi:
Quella cosa è estrema, quando la funzione di KernelPM...definiamola patch al "volo"...patch dinamica o come si vuole chiamare...fallisce
allora per ovvi motivi si usa quella modifica, che di fatto è più invasiva... ma quando non se ne può fare a meno...
fare una cosa del genere per non usare il fix, per me è illogico
ti porto un esempio semplice
oggi cè ' AppleALC per l'audio... è come se uno andasse a patchare AppleHDA direttamente e lo rifacesse per ogni aggiornamento del sistema
Ha scritto dopo 1 minuto 53 secondi:
diciamo è palese che AppleALC è decisamente migliore...
Altro esempio al tempo, tu lo ricordi bene senz'altro, lo script di Toleda... che tramite patch sul config e un dummy in EFI faceva funzionare l'audio senza "toccare" in modo invasivo appleHDA
@netgear[/mention] ma stiamo parlando della gigabyte in firma?
Se si non dovrebbe servire..anche gigabyte dovrebbe averlo unlocked da un po' o di suo o come opzione da bios
io comunque protestai con i devs di coder quando misero in automatico delle patches senza dire niente
sulla mia macchina non andavano ed io non potevo fare nulla (x99 non solo mia chiaramente con xeon unsupported)
poi misero la possibilità di abilitare o meno ad esempio il kernelXCPM
Ha scritto dopo 48 secondi:
"netgear" post_id="35084" time="1558287986" user_id="61">
Si Z370, nel BIOS non vedo nulla a meno che non abbia un nome con altri riferimenti...
stavo vedendo in giro per il tuo bios ma non lo vedo
su ASUS scrivono da me MSR
alcune volte CFG Lock
