[BETA] Clover Bootloader
Clover beta 4490
Patch to Performance.h introduced in r4419 is obsoleted by r4426 - zenith432
Clover beta 4489
fix a mistake of 4468 - slice2009
Clover beta 4488
Discard unneeded leftover patches - zenith432
Clover beta 4487
fix a problem that Device->Properties was not injected - slice2009
Clover beta 4486
Fork Patches_for_UDK2018 from Patches_for_EDK2 - zenith432
Clover beta 4485
correct EFI_PHYSICAL_ADDRESS casting from pointer - slice2009
Clover beta 4484
use STATIC patterns for find and replace - slice2009
Clover beta 4483
create new tag cache if old one is ended - slice2009
Clover beta 4482
update plist memory management, tickets 467, 468 - slice2009
Clover beta 4481
better shell.efi - slice2009
Clover beta 4480
Remove more build products from source control - zenith432
Clover beta 4479
shell improvements - slice2009
Clover beta 4478
Discard empty folder - zenith432
Clover beta 4477
Reengineer vararg patch to GetBestLanguage(), discarding 6 patched files - zenith432
PS: oggi si lavora! :D
Clover beta 4495
fixed RenameDevices feature - slice2009
Clover beta 4494
Fix rest of svn properties - zenith432
Clover beta 4493
avoid infinite loop at renaming devices - slice2009
Clover beta 4492
Fix more svn properties - zenith432
Clover beta 4491
Fix some svn properties - zenith432
In uso 4493 4495 beta in hack 1 e 2
E' forse in arrivo la versione finale?! https://www.insanelymac.com/forum/topic/304530-clover-change-explanations/?page=5&tab=comments#comment-2614287">https://www.insanelymac.com/forum/topic ... nt-2614287">https://www.insanelymac.com/forum/topic/304530-clover-change-explanations/?page=5&tab=comments#comment-2614287
Previsione azzeccata! appena rilasciato clover in versione finale, quindi NON beta 4497 https://sourceforge.net/projects/cloverefiboot/files/?source=navbar">https://sourceforge.net/projects/clover ... rce=navbar">https://sourceforge.net/projects/cloverefiboot/files/?source=navbar
PS: mi scappa da ridere... ho installato praticamente quasi tutte le versione beta e tranne 2 volte, tutto pefetto... versione finale, installo, riavvio et... tranne hdmi scomparso audio in ingresso e uscita dell'hack 2 emoticon_uff
vedo e prevedo a breve nuova release finale emoticon-occhi_51
PS2: ripristinata la EFI 4495 del backup automatico e ritornato tutto a posto emoticon_41
@Baio77[/mention] una cavia a caso :D lo provi anche tu così vediamo se è un problema solo mio o più largo^
Anche con clover beta 4498 il problema rimane, scompaiono le periferiche audio; questa volta ho testato tutti i layout ID del 1220A ma il problema rimane... vedi screenshot sopra
Non ho controllato... ora sto installando i nuovi driver AMD con cui speriamo di riuscire ad installare win10 1803 al 7/8 tentativo :D
Stasera reinstallo clover su un paio di hack ed eseguo un hack_info e vediamo ;)
Ha scritto dopo 52 minuti 45 secondi:
Ho provato clover 4498 nell'hack 3, sempre pessimi risutati, processi lenti, niente audio. LILU e AppleALC vengono caricati; ho provato a rimuovere i daemontools e DVDfab (fabiokext in S/L/E) ma il risultato non cambia.
@Gengik84[/mention] ti allego hack info
HackInfo_Report_Z97_clover4498.zip
In effetti... mi era sfuggito il layout emoticon_blabla ciò non toglie comunque che queste ultime 2 release di clover siano un po' da sistemare con prossime versioni.
Clover beta 4499
add Kaby Lake iGPU id - sherlocks
Ha scritto dopo 1 ora 39 minuti 43 secondi:
"Baio77" post_id="6124" time="1527157485" user_id="55">
Provato da ieri sera su i miei hack tutto OK , x il problema con la beta che ho avuto , ho riscontrato un problema di installazione di Clover tutto qui .........
Hai il layout ID immesso nel DSDT?
Nell'hack 3 ALC 1150 layout ID 7 e nell'hack 2 ALC 1220A layout ID 1
PS: ho fatto presente la cosa su insanely nel thread di clover, anche un'altro ha manifestato problemi con l'audio.
ok...fa parte dei miei ssdt che hanno oltre un hanno.. fatti su skylake.. poi passati per kabylake..etc...
Li ho per tutto... e nessuna patch o rename sul config... default_wink_anim
Ha scritto dopo 2 minuti 12 secondi:
ah dimenticavo..funzionano bene ma nel caso di dover applicare molte patch, preferisco dsdt ed è quello che comunque uso
"iCanaro" post_id="6133" time="1527175559" user_id="57">
Clover beta 4499
No , se posso NON uso DSDT come in Desktop o in Notebook lo uso x la patch batteria , il resto del lavoro lo fa Clover
"Gengik84" post_id="6140" time="1527177144" user_id="2">
Please test su hack 2
nessun rename sul config HDAS to HDEF e nessun layout
Nell'hack 2 funziona perfettamente emoticon_41 emoticon_applausi2
Nell'hack 3 niente audio e processi che si impallano come con gli ultimi clover
Fermo "occhio" ...ho detto hack 2 per un motivo
so bene la struttura della acpi da skylake in poi
Haswell è altra storia.. dovrei modificarlo :)
Ha scritto dopo 1 minuto 31 secondi:
Per clover è sempre stato così, quando vengono usati nuovi Edk2...
Più bug del solito
Si l'iniezione e altro è "rotta" per via delle modifiche al codice sorgente, dovute anche all'aggiornamento edk avvenuto da pochi giorni.. come ho detto nel post precedente
Ho letto e lasciato la mia esperienza ......
Ci aggiorniamo con prossime Beta :P
Avrei una richiesta , una piccola guida x interpretare IOREG , le basi almeno ... empticons_thu
In questi casi dove appare il codice della periferica , cosa mancherebbe??Secondo la mia esperienza dovrei assegnare un NOME ,cosi almeno risolvo quando inserisco MCHC o IMEI
https://postimg.cc/image/noou00esn/">LINK_TEXT>
"Baio77" post_id="6148" time="1527184907" user_id="55">
Assegnare un nome?
risolvi...cosa?
Non capisco ... emoticon-occhi_61
