Re: OpenCore discussion
Quote
"abdulraheem" post_id="33505" time="1557148650" user_id="1095">
abdulraheem post_id=33505 time=1557148650 user_id=1095 said:
I am still getting the same error
Quote
hi @abdulraheem[/mention]
You can use international area on this forum :
https://www.macos86.it/viewtopic.php?f=107&p=33476#p33476">viewtopic.php?f=107&p=33476#p33476">https://www.macos86.it/viewtopic.php?f=107&p=33476#p33476
Thank you , you are welcome here 🙂
https://postimg.cc/xk4qPsHs">20190506-010658.jpg
Look at your EFI
https://postimg.cc/mhjLBXpt">LINK_TEXT>
you have to delete Opecore.efi inside kext folder and Sample.plist file
also you have many undeclared kext in kext folder (if they are useful you have to declare it in Kext section of your config.plist)
https://postimg.cc/jWS63k1P">LINK_TEXT>
Ha scritto dopo 13 minuti 32 secondi:
also, you have to fill with right SMBIOS data Config.plist platformInfo section
In this system Have you ever had a working OSX system before?
"abdulraheem" post_id="33526" time="1557155688" user_id="1095">
I did already but still get the same error here the efi folder
if you have in automatic YES enabled, you bypass all other data in generic tab and others below
https://postimg.cc/fVcwHmgh">LINK_TEXT>
If you are sure that SMBIOS and all data below automatic are similar to your clover Config.plist SMBIOS try to put it to NO
Also post here your booting clover folder :)
Ha scritto dopo 4 minuti 23 secondi:
to find some data you can also use this app:
https://github.com/acidanthera/MacInfoPkg/releases">https://github.com/acidanthera/MacInfoPkg/releases
macserial from OC devs creator
"abdulraheem" post_id="33670" time="1557263105" user_id="1095">
WOW I did it finally everything just work fine in Mojave in HP Zbook15 sound and graphics intel not nivida card :(
emoticon_thanks emoticon_thanks emoticon_thanks
https://postimg.cc/xkq4D4CJ">LINK_TEXT>
hi @abdulraheem[/mention] happy you did a good installation
Your quadro cards could be a problem if it needs of Nvidia Web drivers (no drivers for Mojave for now)
If not, it should work out of the box without problem (if OSX driver supports it in previous OSX release)
"talmazi" post_id="34398" time="1557756441" user_id="922">
Hello I'm in need of help I can not boot.
https://postimg.cc/RWjkwZ82">IMG-3423.jpg
Hi and welcome here @talmazi[/mention]
we have an international area if you want put there your question :
https://www.macos86.it/viewtopic.php?f=109&t=1415">viewtopic.php?f=109&t=1415">https://www.macos86.it/viewtopic.php?f=109&t=1415
If it is possible put in your signature your hardware so people could help better
Thank you
"classic" post_id="37285" time="1561072476" user_id="1171">
how to start Nvidia web?
Hi
Which OS?
Put your configuration system in your signature (from your profile settings)
