OpenCore EFI Maker 1.4.4 (Updated 13-10-2020)
Hi people!
Opencore EFI Maker is a simple app useful to automate download and compilation task of latest release and beta versions of this BootLoader .
it is also useful to download latest base kexts and drivers of Acidanthera group
It creates also complete EFI structure.
You can choose also to use or not FV2 , and automatically it downloads the correct driver for you
It modifies plist as from your choice.
  • +1 2
Quote
"btwise" post_id="33824" time="1557403630" user_id="1111">
btwise post_id=33824 time=1557403630 user_id=1111 said:
Questo strumento sembra buono, ma perché si desidera verificare la connessione a Internet dopo l'esecuzione?
Quote
Because it starts to download required stuff to build OC EFI folder
LINK_TEXT>
I mean, it doesn't download normally, but instead it doesn't have internet, but my network is normal, why?
Quote
"fabiosun" post_id="33828" time="1557404076" user_id="56">
fabiosun post_id=33828 time=1557404076 user_id=56 said:
Quote
Quote
LINK_TEXT>
Quote
OpenCore EFI Maker app checks at its start if Github is available, if in your country it is not possible in that time to acces it this check is negative and quits itself
Viene effettuato un controllo per accesso a Github, per quanto non è accessibile correttamente dalla tua località
il controllo ritorna "falso" e quindi esce
My network is normal, I have no problem accessing github directly in the browser.
"Eniac" post_id="33908" time="1557475525" user_id="1009">
Maybe you can use a proxy for access?
Forse potrebbe usare un proxy per l'accesso ?
"btwise" post_id="34972" time="1558241604" user_id="1111">
Please run on terminal
ping -q -c 1 -W 1 github.com
show the result here
but I use browser visit github.com is good!why?
Quote
"Gengik84" post_id="34974" time="1558247349" user_id="2">
Gengik84 post_id=34974 time=1558247349 user_id=2 said:
Quote
Quote
Quote
Hi, please try and report
ping -q -c 1 -W 1 api.github.com
Ha scritto dopo 29 secondi:
"btwise" post_id="36013" time="1559268525" user_id="1111">
It's not the same
Ha scritto dopo 7 minuti 33 secondi:
Do you live in China?
Well, in this case GitHub is down in China from time to time...
Browser is another story because it's able to load socks5 proxy
$ ping -q -c 1 -W 1 api.github.com
PING api.github.com (13.250.94.254): 56 data bytes
--- api.github.com ping statistics ---
1 packets transmitted, 0 packets received, 100.0% packet loss
"Gengik84" post_id="36157" time="1559400613" user_id="2">
It's not the same
  • 3 months later...
  • 4 weeks later...
"karacho" post_id="44214" time="1570373763" user_id="1305">
That's strange. Per today, the script no longer ask if you're using FileVault and to choose between HfsPlus.efi and VboxHfs.efi.
today there are some problems from acidanthera 's GitHub
I have had also your problem this morning..
I have solved some hours later
It is not an app's problem
  • 11 months later...
46 minutes ago, azerty07 said:
I am trying to setup my first hackintosh, will it work with TRX40 motherboard ?
why not?
you have also another app to try..VM Assistant done for trx40 user and all user..to download a proper opencore EFI to try to start
check in our international area
you will find there many interesting things and threads
Edited by fabiosun
link added
  • 6 months later...
