 Release v1.0.6
  • Added workaround for not detected CPU frequency in ProvideCpuInfo quirk, thx @hg13bs
  • Updated QemuBuild.command to support EFI mode without Duet
  • Increased OC_STORAGE_SAFE_PATH_MAX to 192 to support various plugin kexts
  • Fixed vaulting failures when custom fonts are used, thx @al3xtjames
  • Updated documentation for several Booter quirks
  • Added background-color NVRAM variable to fix 10.9 boot screen
  • Fixed debug build of OpenShell not starting on Mac EFI with > 25 file systems
  • Improved build speed for Utilities in CI and local build
  • Fixed ACPI 1.0 RSDP being reported under ACPI 2.0 GUID with Duet
  • Improved logic for RSDP version checking in ACPI patching code
  • Downgraded routine log messages such as 'Needs journal recovery, mounting read-only' from WARN to INFO in Ext4Dxe (allows DEBUG_WARN in HaltLevel)
  • Improved OpenNtfsDxe stability, thx @stokescat
  • 4 months later...
Release v1.0.7
  • Improved XhciPortLimit compatibility with macOS Tahoe, thx @laobamac
  • Updated builtin firmware versions for SMBIOS and the rest
  • Migrated to edk2-stable202511
