Release 0.6.8
Switched to VS2019 toolchain for Windows builds
Reduced legacy boot install interaction effort
Increased OpenCanopy rendering performance
Added OpenCanopy Shut Down and Restart buttons
Reduced OpenCanopy mouse pointer input lag
Fixed that cursor bounds could be different from OpenCanopy's
Improved builtin picker rendering performance
Added Memory Type decoding for SMBIOS in Automatic mode
Properly support setting custom entries as default boot options
Fixed creating log file when root file system is not writable
Fixed DisableSingleUser not being enabled in certain cases
Added ForceBooterSignature quirk for Mac EFI firmware
Fixed OpenCanopy sometimes cutting off shown boot entries
Further improved CPU frequency calculation on legacy CPUs
Fixed SMBIOS SMC version encoding sequence
Added TSC frequency reading from Apple Platform Info
Added TSC frequency reading for Apple devices with nForce chipsets
Added Base and BaseSkip lookup for ACPI patches
Fixed ACPI table magic corruption during patching
Fixed unnatural OpenCanopy and FileVault 2 cursor movement
Fixed OpenCanopy interrupt handling causing missed events and lag
Improved OpenCanopy double-click detection
Reduced OpenCanopy touch input lag and improved usability
Improved keypress responsiveness in OpenCanopy and builtin pickers
Improved non-repeating key detection in OpenCanopy and builtin pickers
Fixed Escape preventing OpenCanopy fade up until released, on some systems
Fixed fast repeat then stall issue with key handling on some PS/2 systems
Added accurate Shift+Enter/Shift+Index detection when using PollAppleHotKeys
Added 'set default' indicator to builtin picker
Replaced VerifyMsrE2 with ControlMsrE2 also allowing unlock on some firmwares
Fixed OpenCanopy flicker when refreshing the entry view
Added OpenCanopy TAB navigation support
Added OpenCanopy graphical password interface
Added OpenCanopy pulsing animation to signal timeout
Added OpenCanopy 'set default' indicator
Fixed OpenCanopy not aborting timeout on pointer click
Fixed OpenCanopy intro animation not scaling with UIScale
Add OpenCanopy boot entry label scrolling (fixes missing long labels)
Added tabbable Shutdown and Restart buttons to builtin picker
Fixed in-firmware shutdown for some systems running OpenDuet
Added Zero as alias hotkey for Escape, to force show picker if hidden
Added =/+ key as alias for CTRL to set default OS
Added additional support for configuring correct key repeat behaviour with KeySupport mode
Fixed CPU multiplier detection on pre-Nehalem Intel CPUs
Fixed incorrect handling of multiple processors and processor cache in SMBIOS
Matched default Apple boot picker cursor start position
Updated OpenShell devices command to support misaligned device names returned by some Apple firmware
Added (dmg) suffix to DMG boot options in OpenCanopy
Added identifiers for Rocket Lake and Tiger Lake CPUs
Added PickerAudioAssist 'disk image' indication
Fixed PickerAudioAssist indications played twice in rare cases
Improved OpenCanopy pointer acceleration
Added more precise control on AppleEvent protocol properties and features
Added dynamic keyboard protocol installation on CrScreenshotDxe
Support starting UEFI tools with argument support (e.g. ControlMsrE2) without arguments from picker
Fixed OpenCanopy font height calculation, may reject previously working fonts and mitigate memory corruption
Fixed incorrect identification of Xeon E5XXX/E5-XXXX and Xeon WXXXX/W-XXXX CPUs
Added RSDP, RSDT, and XSDT handling to NormalizeHeaders ACPI quirk
  • Like 3
aggiornato con successo , non mi carica le icone della GUI iniziale è cambiato qualcosa?
Ovviamente ho sostituito l'intera cartella Resources , poi al solito ho settato pickermode=1 e icone = external ma non li carica...
Ciao nella cartella Resources/image hai presente anche queste icone ? Restart, Shutdown, BtnFocus, Dot, Entry, Lock, Password and SetDefault. oltre PickerVariant = Auto
Edited by antuneddu
Non ho queste icone , ho settato PickerVariant da Auto a Default , come suggerito subito dopo , ma nulla!
20 minutes ago, fabiosun said:
@tuxyse hai sostituito le resources con quelle di un paio di giorni fa..seguendo questo schema dovrebbe andare
buonasera
aggiornato a 0.6.8 tutto bene come al soilto ( anche la gui di blackosx funziona all grande ) unico appunto  icona sulla gui di shutdown non va ( si riavvia come quella fianco ) , qualche suggerimento?
Edited by gian
19 minuti fa, gian ha scritto:
buonasera
Strano come hai impostato Misc/boot ?
3 minuti fa, gian ha scritto:
sisi...sia con ocvalidate che con occonfigcompare
Credo che sia la gui, provero una gui diversa.
Infatti , a me e' capitato con un tema di bsx che non mi partiva propio la gui , dopo ho scoperto che aveva nominato male un icona 😁
