Administrators Gengik84 Posted March 6, 2018 Administrators Share Posted March 6, 2018 Riavvia Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 6, 2018 Author Share Posted March 6, 2018 fatto Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 6, 2018 Administrators Share Posted March 6, 2018 la webcam? Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 6, 2018 Author Share Posted March 6, 2018 devo rimettere il Kext che mi hai dato prima?perchè l'avevo tolto...comunque mi dice nessun dispositivo in acquisizione immagine Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 6, 2018 Administrators Share Posted March 6, 2018 prova a rimetterlo Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 6, 2018 Author Share Posted March 6, 2018 niente...devo fare hack info? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 6, 2018 Administrators Share Posted March 6, 2018 da sempre quell'errore? a vedere da hack info è riconosciuta correttamente sotto usb Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 6, 2018 Author Share Posted March 6, 2018 no però non funziona sul resoconto del computer la vede in usb ma non in camera se ben ricordo è proprio chicony il produttore Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 6, 2018 Administrators Share Posted March 6, 2018 Facetime non riconosce la web? Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 6, 2018 Author Share Posted March 6, 2018 non ho ancora attivato iMessage altro comunque non la vede...cercando su google qualcuno ha inserito il kext anyisightcam sugli Asus Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 6, 2018 Administrators Share Posted March 6, 2018 Puoi provare anche se essendo usb dovrebbe andare nativamente, quindi è probabile che non abbia più gran supporto Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 6, 2018 Author Share Posted March 6, 2018 funziona con il kext Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 6, 2018 Author Share Posted March 6, 2018 mi sono accorto che il tasto alt gr non funziona come sulle tastiere windows devo premere un' altro ....non è importante ma comunque se c'è una soluzione la gradire....bisogna configurare altro? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 6, 2018 Administrators Share Posted March 6, 2018 La mappatura dei tasti su OSX è differente...ma alla fine è solo questione di abituarcisi... Nel caso comunque..ci sono applicazioni per rimappare i tasti Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 6, 2018 Author Share Posted March 6, 2018 non è un problema comunque...credi che ora il pc sia funzionante del tutto o pensi che bisogna configurare qualcosa' altro?...inoltre ho seguito la guida per servizi iMessage solo che ho messo come configurazione un iMac in quanto aveva la stesso processore...risultato non rivede più la webcam... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 6, 2018 Administrators Share Posted March 6, 2018 Scarica https://software.intel.com/file/613985/download">Intel Power Gadget Aprilo poi fai una foto, lascialo aperto esegui qualche test per stressare un po' la cpu e fai nuovamente una foto Postale entrambe NO... non devi mettere iMac devi lasciare MacBook Pro 9,2.. il smbios è importante e va usato uno consono all'hardware iMac è un desktop Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 6, 2018 Author Share Posted March 6, 2018 devo provare con un MacBook Pro? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 6, 2018 Administrators Share Posted March 6, 2018 Devi lasciare intatto il config,nella parte smbios come ho impostato io.. Va solamente modificato/aggiunto dei parametri per iMessage Quindi sostituisci il config con quello fatto da ma Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 6, 2018 Administrators Share Posted March 6, 2018 Poi scarica https://www.macos86.it/MacOS86_Downloads/Applicazioni/Script/Ethernet%20en0%20FIX/Fix_en0.zip">questo Eseguilo e riavvia Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 6, 2018 Author Share Posted March 6, 2018 ho eseguito il file ma si è riavviato da solo.... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 6, 2018 Administrators Share Posted March 6, 2018 ok..va bene...è uno script che serve per mettere la ethernet in en0 Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 6, 2018 Author Share Posted March 6, 2018 si ho visto....quindi devo modificare/generare solo il seriali per quanto riguarda iMessage ? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 6, 2018 Administrators Share Posted March 6, 2018 Segui la guida...ce ne sono un paio.. e per dubbi o richieste puoi postare anche li Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 6, 2018 Author Share Posted March 6, 2018 ok Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 6, 2018 Administrators Share Posted March 6, 2018 il minimo va bene, un po' basso il massimo...ma potrebbe dipendere che non hai stressato la cpu... Prova eseguendo un semplice Geekbench ovviamente lasciando aperto intel power gadget.. e poi fai un paio di foto Link to comment Share on other sites More sharing options...
