Administrators Gengik84 Posted March 5, 2018 Administrators Share Posted March 5, 2018 il disco è impostato come primario per il boot? se usi il boot manager? Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 5, 2018 Author Share Posted March 5, 2018 Ho copiato la cartella EFI nella EFI on EFI ,Mac High Sierra, recovery HD ( disk0s1)..... Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 5, 2018 Author Share Posted March 5, 2018 Come dovrei impostarlo? Link to comment Share on other sites More sharing options...
Moderators Jolly Posted March 5, 2018 Moderators Share Posted March 5, 2018 Ma hai settato il bios per boot uefi? Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 5, 2018 Author Share Posted March 5, 2018 Ho settato come primo HD quello del Mac.....ma senza chiavetta non parte....come dovrei impostare il BIOS uefi? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 5, 2018 Administrators Share Posted March 5, 2018 Possibile che il tuo bios sia un po' "ostico" riguardo al boot uefi da disco prova a seguire questa guida https://www.macos86.it/viewtopic.php?p=154#p154">https://www.macos86.it/viewtopic.php?p=154#p154 Ovviamente sul disco deve esserci la stessa EFI che hai nella usb. Prima di iniziare a seguire la guida, espelli la usb Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 5, 2018 Author Share Posted March 5, 2018 Ecco come è impostato Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 5, 2018 Administrators Share Posted March 5, 2018 Segui quella guida oppure dovrai usare legacy per avviare direttamente da hd Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 5, 2018 Author Share Posted March 5, 2018 Ho seguito la guida ora ho riavviato senza USB è andato prima in clover e poi ho scelto HD ed è partito Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 5, 2018 Administrators Share Posted March 5, 2018 Ok...ottimo...;) Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 5, 2018 Author Share Posted March 5, 2018 Ora per i driver della scheda wifi, dei comandi con fn, e dell'audio dove posso cercarli?...ti ringrazio davvero tanto sei stato molto paziente Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 5, 2018 Administrators Share Posted March 5, 2018 https://www.macos86.it/viewtopic.php?p=1065#p1065">https://www.macos86.it/viewtopic.php?p=1065#p1065 Segui qui e posta il tutto.. Pian piano configuriamo il tutto a modo.. però serve quelle informazioni... E' un piacere e una passione aiutare... questo è lo spirito del forum... emoticon_sorriso Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 5, 2018 Author Share Posted March 5, 2018 non so se ho fatto bene o meglio se è il post giusto....non sono pratico di questi topic .....se mi aiuti emoticon_vergogna ho scaricato i tre file penso di aver fatto bene HackInfo_Report.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 5, 2018 Administrators Share Posted March 5, 2018 Questi vanno bene però manca ioreg, quindi apri IOregistryExplorer, poi vai su file/save as...salva,comprimi e posta inoltre manca la procedura F4 nella gui di clover e poi devi allegare la tua attuale EFI Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 5, 2018 Author Share Posted March 5, 2018 La procedura di f4 su clover non ho capito come si fa Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 5, 2018 Administrators Share Posted March 5, 2018 nella gui prima di avviare il disco premi F4,attendi 20 secondi e poi avvii normalmente e poi posti la EFI Link to comment Share on other sites More sharing options...
Baio77 Posted March 5, 2018 Share Posted March 5, 2018 alla Gui di clover , la schermata dove vedi gli HD , clicchi F4 aspetti 20 sec e avvi monti la EFI e in orgini trovi le tabelle acpi Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 5, 2018 Author Share Posted March 5, 2018 ecco i file....per quanto riguarda f4 Clover.....ho premuto f4 ma non è successo niente ho aspettato 20 sec e poi ho avviato MacBook Pro di Giuseppe.zip EFI.zip Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 5, 2018 Author Share Posted March 5, 2018 ecco i file....per quanto riguarda f4 Clover.....ho premuto f4 ma non è successo niente ho aspettato 20 sec e poi ho avviato MacBook Pro di Giuseppe.zip file efi.zip MacBook Pro di Giuseppe.zip file efi.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 5, 2018 Administrators Share Posted March 5, 2018 Sostituisci la EFI,riavvia, fai ioreg e postalo EFI.zip Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 5, 2018 Author Share Posted March 5, 2018 Sembra fermo su questa schermata Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 5, 2018 Administrators Share Posted March 5, 2018 Sostituisci il config config.plist.zip Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 5, 2018 Author Share Posted March 5, 2018 Come se rimane bloccato? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 5, 2018 Administrators Share Posted March 5, 2018 usa la usb per effettuare il boot Link to comment Share on other sites More sharing options...
giuseppe791979 Posted March 5, 2018 Author Share Posted March 5, 2018 Devo avviare da USB? Link to comment Share on other sites More sharing options...
