AMD Threadripper 3970x on Gigabyte Aorus TRx40 Xtreme - Got it for a bottle of bourbon
maccaroni
I was gifted a Threadripper w/ motherboard from a friend (traded for a rare bottle of bourbon) so I decided to try my hands at a Ryzentosh before I go back to a Apple. The website has been super helpful in getting started, but after many adjustments and attempts I'm stuck with the same results. Install of MacOS Ventura / Sonoma hangs at 12 min and computer freezes up (mouse stops working). I've tried different OpenCore versions, Quirks, boot-args, kexts, MMIO Whitelist with the same results. I've also patched for the 32-core Threadripper in the kernel but I feel like there could be patches I'm overlooking in the ACPI. Any help getting the install done would be appreciated.
Build:
AMD Ryzen Threadripper 3970x 32-core 3.7GHz
Gigabyte Aorus Trx40 Xtreme ver 1.1 (BIOS Feg latest)
EVGA NVIDIA GTX 1080ti Hybrid (temporary until my RX 6600 arrives)
G.Skill Trident Z Neo RGB 192B (6 x 32GB) 2666MHz
WD Black SN7100 1TB PCIe 4.0
SanDisk 64GB UHS-I USB 3.2 (installer thumb drive)
Dynatron L29 Liquid Cooler (280W TDW)
Lian-Li Edge Gold 750W PSU
Lian-Li Odyessey X Black Ed XL-ATX Case
OpenCore 1.05
MacOS Ventura (latest)
EFI (TRx40 Xtreme).zip
Edited by maccaroni
13 hours ago, maccaroni said:
Build:
OpenCore 1.05
Hi and welcome here @maccaroni
have you searched in this thread?
different users with Similar your board (and someone with your Extreme)
Thread is not more updated because new CPU have more success by now in hackintosh
By the way, here Olarila is not supported for different reason!
One reason (personal reason) is inside your Olarila/kext EFI
you have a bunch of ethernet kext there not useful in your rig and many other unproper stuff 😛 🙂
I’ve replaced the 1080ti with a GC Radeon RX 6600 XT and recreated the installer with a different drive and a redownloaded macOS Ventura and the results were the same. Anyone have a solution for the 12 minutes freeze, because I’m out of ideas.
@fabiosun
First I have to say thank you for responding with a solution so quickly. I put the config.plist into my OC folder and things were running the same until the recovery screen was about to pop up and the screen went black
• this is because my GC Radeon RX 6600 XT only wants to work with "agdpmod=ignore". Nothing else worked •
When it got to 12 minutes, verbose mode came back and it rebooted to the installer like its supposed to! Boom 29 minutes left.
Rebooted again to continue, long verbose screen then SSD boot, reboot and voila! Ventura splash screen! 🙌🎉
You're a genius what was missing/removed?
Hi @maccaroni
i bypassed mmio whitelist that was wrong
you have to do better or set on DisableVariableWrite booter quirk on
about gpu
try without Whatevergreen kext or without -v bootarg because some rx6600 have problem with one of these settings
I turned off verbose mode and poof, no more black screen! Brilliant suggestion, I guess my card doesn’t like it. Got wireless network activated through Heliport, now to attempt to activate Thunderbolt and AppleVtd. 🤞
Edited by maccaroni
Typo
5 hours ago, maccaroni said:
AppleVtd.
in my knownledge not available for AMD
Thunderbolt
I had one on PCI and it was working with a SSDT and a firmware patch
  • Sad 1
Thunderbolt card is working with hot plug for USB drives, I just haven't gotten it to recognize the Thunderbolt drive. I supposed if it will recognize Thunderbolt devices I won't need AppleVtd because only a few rarely used devices require it in order to work.
