ASUS ROG Crosshair X870E Hero - Ryzen 9950x
1 hour ago, viljeml said:
will OC patches be ok with 1715 bios i prefer OC over Clover
ACPI/patches section are bios dependant
you have to use the proper ones for bios you use
i use 1715 because 1804 and 1805 in my system had problems with my two sata SSD (silicon power 4 Tb each)
When you have the correct EFI you can use Opencore or clover as i do in my pc 🙂
you cont have to reinstall OSX you only have to put correct patches and boot from that EFI after the bios Update (downgrade in this case)
Every time you update your bios is a risk for system boot
Sometimes we have to recalculate proper ACPI patches and for now only a good guy on discord is able to do them in a clean way!
this section
In bios greater than 1715 i loose disks:
2001
1715
SOmetime after many minutes some of them reappear..not always and i do not like to loose something 🙂
  • 3 weeks later...
49 minutes ago, Nick White said:
@fabiosunhave you tried the new bios 2004 also on ProArt x870e?
Do you know if it has the same issues or its just specific to crosshair hero?
I have only the Hero
I cant say for ProArt Nick
  • 3 weeks later...
I tried the latest versions including 2102 and all have the SATA issue.
So reverted back to 1715.
Not sure if Asus is interested to solve those since if solely focused on Windows and maybe, maybe linux.
Edited by Nick White
