ASUS ROG Crosshair X870E Hero - Ryzen 9950x
4 minutes ago, viljeml said:
i have sysreport folder
you can upload here:
https://discord.com/channels/249992304503291905/1027560607030984766
your dsdt.aml file you can find in acpi folder to the attention of CorpGhost
or post here all your acpi folder and i will do for you
if you prefer or cant access there
Hi @viljemlthese are my both Opencore and clover EFI with ACPI patches done with your DSDT by CorpGhost
I advice to disable from bios (if they dont work again) these device:
BT
WIFI
Both ethernet
and see
You must use a full installer if you do not have a working usb ethernet adapter if you use Tahoe installer
With Sequoia it could work also with a recovery installer
Archive.zip
Edited by fabiosun
