ASUS ROG Crosshair X870E Hero - Ryzen 9950x
@viljemltry these two tries (in different steps)
1) Disable whatevergreen.kext
and see what happen
2) enable whatevergreenkext, disable USBPorts.kext, enable kernel/quirk XhciPortLimit
Edit:
Only for my curiosity
HAve you a booting Sonoma OS with latest firmware (1805) for your motherboard?
also i never installed on a sata disk on this motherboard and with 1804/1805 motherboard bios i have problem with my two SilicomPower SSD connected to my interna sata port
system works but i cant see my disk on desktop or they appear after many minutes after boot
No it works with only one gpu and 32gb
i would double check bios motherboard option
i cant see why your system doesnt boot
could you try to flashback old 1715 bios or use a nvme disk for osx?
maybe a sata problem with 1805 hero bios
22 minutes ago, viljeml said:
what if there is something in the bios settings
I use load optimized values
disable fast boot asus logo off CSM off
you can disable wifi and realtek ethernet because not supported
end
This is a debug EFi with Opencore
then there is also clover booloader
you can choose at boot what to execute
choose OC and see
after the choice (if it boots ...well you are done, if not it produce a folder SYSReport you can use to produce patches for your motherboard (post it here if you like)
in boot folder i use bootloader chooser for this task
after first boot and choice it boot always with the bootloader choosen
you can change to the other when you see bios post clicking on any keyboard button
let see if we do a step forward
EDIT:
both bootloaders have patches for 1805 bios
Edited by fabiosun
config.plist.zip
use this config in opencore to see correct EFI
but i see the same error also in clover bootloader as previously seen
6 minutes ago, viljeml said:
opencorew boot shows this:
post this sys report folder if you see in yourEFI partition
a more clear foto here to read acpi errors i see
