ASUS ROG Crosshair X870E Hero - Ryzen 9950x
By the way, if you have different CPU you have to change some AMD kernel patches adapting them to your core count
I use to spoof my dual GPU system (6950xt) one of them in last PCIE 16 slot needs of a SSDT for a bridge
Spoof is done inside Device Properties of my config.plist
I do not use latest 1805 bios because it adds some problem in my Sata disks
if you use it you must also change ACPI/patches i have in config.plist
EFI_viljemi-no broadcom wifi.zip
this EFI is based on my working one, i disabled WIFI parts (i advice to disable in bios)
it should boot also in your if your motherboard bios is 1715 or lower
i miss some infos about your bios and your OSX you are trying to install or to boot in an installed one previously
usually i disable fast boot in Bios and use other OS to boot on boot section (4G and resize bar on)
In the past i used to flash with balena etcher app (but not with olarila image i do not trust)
Intel or AMD booting pen is the same (no differences in file system)
I cant say more but i think it is a problem where my EFI is inserted in that usb
Sorry!
I trust you 🙂
i do not understand if you can see with my EFI an opencore boot menu and the the installer does not work or you do not reach  opencore boot menu at all
with that EFI you can install also Ventura/Sonoma/Sequoia/tahoe but the problemi in Tahoe is Ethernet card Hero have (both are not working anymore in Tahoe)
In Sequoia intel one and lower works with APPLEIGC.kext
3 minutes ago, viljeml said:
i have two hackintoshes with intel procesors  (one coffee lake 9900k,and one arrow lake 285k)both working good
if so why dont you create a full installer with those hackintosh withou using Olarila IMG?
how to do that without olarila
I had a working sonoma amd osx computer when you had a 7950 processor and an asus motherboard then you changed the processor to a 9950x, me too of course and my amd computer no longer worked
Edited by viljeml
sudo /Applications/Install\ macOS\ Ventura.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolumeName
I use terminal command like this
Using correct path for os and pro per path for usb volume where to install
Problem was bios update for incoming cpu
it needed of acpi patches
if you followed my thread i talked about this
also x870 needs of patches
CorpGhost on AMD osx discord server helps to build proper ones for different Bios and motherboard
Edited by fabiosun
11 hours ago, viljeml said:
I did the install media twice, copied your EFI, same problem, I'm adding a couple of screenshots
Hi, i see an ACPI errors to the start of this screenshot, do you see also others ACPI errors before this one?
MAybe you need a custom ACPI patches for your ASUS motherboard
to do this you have to use Opencore bootloader debug and  to enable SysReport in your config . plist, then you will find a SysReport folder in your EFI partition/USB
post it here or on AMD OSX discord server to CorpGhost attention (Only ACPI folder) and usually he produces correct acpi patches for you
I think is not related but it is weird you cant boot with my EFI and so it is the only idea that your acpi patches need other than mine (weird and impossible in my opinion but i have no more idea for now)
