ASUS ROG Crosshair X870E Hero - Ryzen 9950x
As soon as possible i will fill with a working EFI 🙂
These below are ACPI patches useful to avoid ACPI errors with bios 1203
patches_OC.plist.zip
As always thanks @Corpnewt aka CorpGhost on AMD-OSX discord to do them for us 🙂
link
Configuration in detail:
Case ThermalTake Core X9
PSU Enermax 1700w platimax
Asus ROG CrossHair x870E Hero
192 96 Gb Corsair Vengenage 6400 Mhz 42x48Gb
2 6950xt 16 Gb GPU ( 🙂 )
2 KC3000 Nvme Kingston 2 Tb
2 Sabrent Rocket 4.0 1 Tb
2 SSD 4Tb each
2 HD 20 Tb each
I did an initial working EFI.
to support 6950xt OSX needs a spoof to 6900xt
One slot needs additional SSDT bridge
I did also a fast USB mapping , i have to refine it better
Attached my working EFI
Pay attention:
Intentionally i didnt build a MMIO whitelist Area but i have used DisableVAriableWrite quirk to boot without MMIO declaration
I do not advice to do the same , and you should build your proper MMIO area to whitelist
System works wonderfully and the only things i can see it is not working are ASMedia USB4 and WIFI because i do not want to disassamble ASUS motherboard plate , in a future maybe i will do
as last information i am using 1203 Asus Hero bios
image.thumb.png.d8350de7e49efbd23f806c599b810055.pngimage.thumb.png.39c1b162fe2a96f69500e4109b932caa.pngimage.thumb.png.3356f21fc020455fbf2ece8ce96f2dc0.pngimage.thumb.png.91eb2c984d4e1121e19c587bd92b3b3f.pngimage.thumb.png.d894213159edf6272728bc5a693de5d4.pngimage.thumb.png.a730994fcc41390ad5c221dd79e79af7.pngimage.thumb.png.8044490849f0cbbdadd1e3271bcd0a7b.pngimage.thumb.png.007ea8934e01755a3708f14b6c9c8230.png
ASUS X870E Hero_Clover_tahoe.zip
ASUS-X870E Hero-OC.zip
  • Like 3
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
Hi Fabiosun,
Is the sleep function working fine with this motherboard? I am considering between ProArt and ROG CROSSHAIR mainboards.
I intend to use it with Ryzen 9900x, should that work fine? I've seen some discussions around tha cpu not being recommended.
Thanks in advance for your advise.
Edited by Nick White
2 hours ago, Nick White said:
Hi Fabiosun,
I think it is the best solution! 🙂
in my case all things work (only realtek ethernet doesnt work and also USB4 ports dont work)
Audio is USB audio (you have to map properly your USB)
9900x works (i have a 9950x but you have only to change core count patch i think)
Sleep works
Thanks, actually you inspired me to upgrade to one of those two configurations.
Between the two mainboards ProArt or ROG CROSSHAIR which one you consider more stable?
I saw that ProArt doesn't require ACPI patching while ROG CROSSHAIR does.
If you can afford an Asus Hero (if in your country is available) i would buy it
i had both but Hero is far away better
The only pro for Proart is about 10 Gbit Aquantia ethernet
I prefer Hero because i use 2 6950xt and slot space is better
EDIT:
also internal wifi is not working for both..but i have mounted in internal wifi a broadcom (on proart is more simple to do because hero has a huge backplate)
  • 4 weeks later...
12 minutes ago, viljeml said:
I am trying unsuccessfully to install tahoe or sequoia with your OC on an ASUS Crosshair x870E hero motherboard and an ASUS ROG Crosshair X670E extreme motherboard.
Welcome here
some more usuful data?
EDIT:
CPU?
GPU?
Disks?
Bios Settings
and so on ie where it hangs!
Edited by fabiosun
