epxpc01
Hello fabiosun,
Trying to get my MMIO Whitelist info for my X870 MSI. When I use the Opencore Release OC 1.0.3 I get to the Opencore boot menu with no issue. Starts to boot but then boot loop as there is no MMIO Whitelist included in the config. So when I use OC 1.0.3 Opencore.efi debug I get the boot menu as in the attached pic, but then a boot loop. I never get to the Opencore boot menu. Any idea?
Thank you for your response!
As you can see in pics attached, I am using opencore.efi debug version, and 67 on Target. But I am getting this Access Denied! so I never get to the Opencore boot menu to build a txt file that includes MMIO.
In your screenshot i see opencore 1.03
it should be opencore 1.03 debug
also latest efi driver errors means a bad efi done
check if it is ok also for you here and check also EFI structure
In your picture i see also SysRport unflagged
it should be flagged to see your DSDT.aml file (if also your motherboard needs about additional ACPI patches)
