emiliano Posted May 10, 2025 Author Share Posted May 10, 2025 Non avevo eseguito il reset nvram Link to comment Share on other sites More sharing options...
emiliano Posted May 10, 2025 Author Share Posted May 10, 2025 @Anto65 resoconto di un blocco : panic(cpu 6 caller 0xffffff8017bcfd84): rwlock_count is 1 for thread 0xffffff99cf57eb30, possibly it still holds a rwlock @ast.c:372 Panicked task 0xffffff903ef18988: 3 threads: pid 4868: mdworker_shared Backtrace (CPU 6), panicked thread: 0xffffff99cf57eb30, Frame : Return Address 0xffffffbdbffefba0 : 0xffffff8017bda441 mach_kernel : _handle_debugger_trap + 0x4c1 0xffffffbdbffefbf0 : 0xffffff8017d4d6c6 mach_kernel : _kdp_i386_trap + 0x126 0xffffffbdbffefc30 : 0xffffff8017d3c85c mach_kernel : _kernel_trap + 0x75c 0xffffffbdbffefcf0 : 0xffffff8017b6f971 mach_kernel : _return_from_trap + 0xc1 0xffffffbdbffefd10 : 0xffffff8017bda737 mach_kernel : _DebuggerTrapWithState + 0x67 0xffffffbdbffefe10 : 0xffffff8017bd9dbb mach_kernel : _panic_trap_to_debugger + 0x1fb 0xffffffbdbffefe80 : 0xffffff80183cdd5d mach_kernel : _panic + 0x81 0xffffffbdbffeff70 : 0xffffff8017bcfd84 mach_kernel : _ast_taken_user + 0x4c4 0xffffffbdbffeffa0 : 0xffffff8017b6f93d mach_kernel : _return_from_trap + 0x8d Process name corresponding to current thread (0xffffff99cf57eb30): mdworker_shared Boot args: keepsyms=1 debug=0x100 Mac OS version: 24E263 Kernel version: Darwin Kernel Version 24.4.0: Fri Apr 11 18:28:23 PDT 2025; root:xnu-11417.101.15~117/RELEASE_X86_64 Kernel UUID: E6326809-88F4-3ECC-93BB-D2CBDF235588 roots installed: 0 KernelCache slide: 0x0000000017800000 KernelCache base: 0xffffff8017a00000 Kernel slide: 0x00000000178e4000 Kernel text base: 0xffffff8017ae4000 __HIB text base: 0xffffff8017900000 System model name: iMac20,1 (Mac-CFF7D910A743CAAF) System shutdown begun: NO Panic diags file available: NO (0xe00002bc) Hibernation exit count: 0 System uptime in nanoseconds: 3482606539221 Last Sleep: absolute base_tsc base_nano Uptime : 0x0000032adb8695f9 Sleep : 0x000002c3f83ae2b3 0x00000000a0ea23e0 0x000002156dd56583 Wake : 0x000002c3fc631ed9 0x00000000a30301eb 0x000002c3f9003c86 Compressor Info: 2% of compressed pages limit (OK) and 3% of segments limit (OK) with 1 swapfiles and OK swap space Zone info: Zone map: 0xffffff8036197000 - 0xffffffa036197000 . PGZ : 0xffffff8036197000 - 0xffffff8038198000 . VM : 0xffffff8038198000 - 0xffffff8504997000 . RO : 0xffffff8504997000 - 0xffffff869e1a1000 . GEN0 : 0xffffff869e1a1000 - 0xffffff8b6a9a0000 . GEN1 : 0xffffff8b6a9a0000 - 0xffffff903719f000 . GEN2 : 0xffffff903719f000 - 0xffffff950399e000 . GEN3 : 0xffffff950399e000 - 0xffffff99d019d000 . DATA : 0xffffff99d019d000 - 0xffffffa036197000 Metadata: 0xffffffcc2b38f000 - 0xffffffcc4b38f000 Bitmaps : 0xffffffcc4b38f000 - 0xffffffcc4e38f000 Extra : 0 - 0 Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted May 10, 2025 Support Team Share Posted May 10, 2025 Sembrerebbe legato a questo processo mdworker_shared che assorbe memoria e cpu Prova a leggere qui come risolvere https://macsecurity.net/view/567-mdworker-shared-high-cpu-mac 1 Link to comment Share on other sites More sharing options...
emiliano Posted May 12, 2025 Author Share Posted May 12, 2025 Buongiorno @Anto65 seguita la guida come riattivo stoplight si blocca. grazi mille Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted May 12, 2025 Support Team Share Posted May 12, 2025 Prova con sudo mdutil -a -i Link to comment Share on other sites More sharing options...
emiliano Posted May 12, 2025 Author Share Posted May 12, 2025 Last login: Mon May 12 10:50:28 on ttys000 cristian@iMac-di-Helmut ~ % sudo mdutil -a -i Password: mdutil: option requires an argument -- i Usage: mdutil -pEsa -i (on|off) -d volume ... mdutil -t {volume-path | deviceid} fileid Utility to manage Spotlight indexes. -i (on|off) Turn indexing on or off. -d Disable Spotlight activity for volume (re-enable using -i on). -E Erase and rebuild index. -s Print indexing status. -a Apply command to all stores on all volumes. -t Resolve files from file id with an optional volume path or device id. -p Publish metadata. -V vol Apply command to all stores on the specified volume. -v Display verbose information. -r plugins Ask the server to reimport files for UTIs claimed by the listed plugin. -L volume-path List the directory contents of the Spotlight index on the specified volume. -P volume-path Dump the VolumeConfig.plist for the specified volume. -X volume-path Remove the Spotlight index directory on the specified volume. Does not disable indexing. Spotlight will reevaluate volume when it is unmounted and remounted, the machine is rebooted, or an explicit index command such as 'mdutil -i' or 'mdutil -E' is run for the volume. NOTE: Run as owner for network homes, otherwise run as root. cristian@iMac-di-Helmut ~ % @Anto65 mi da questo. non dovrei indicare cosa fare? Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted May 12, 2025 Support Team Share Posted May 12, 2025 sudo mdutil -a -i on Puoi provare anche ad alleggerire l indicizzazione di Spotlight escludendo alcuni elementi Cliccando su Privavy della ricerca ( in basso ) Puoi escludere un disco intero come vedi nel mio esempio Link to comment Share on other sites More sharing options...
emiliano Posted May 12, 2025 Author Share Posted May 12, 2025 avevo già escluso questi Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted May 12, 2025 Support Team Share Posted May 12, 2025 In condivisione , da me tt disabilitato Puoi provare anche con qualche app tipo CCleaner , ONYX , Cleanmymac per fare pulizia , scovare forse un virus e reindicizzare Spotlight ... 🤷♂️ Link to comment Share on other sites More sharing options...
emiliano Posted May 12, 2025 Author Share Posted May 12, 2025 Buona sera @Anto65 sto provando sonoma e fino ad ora sta andando bene. la ventola dell'alimentatore non la sento per niente. invece con sequoia era quasi sempre a palla Link to comment Share on other sites More sharing options...
emiliano Posted May 16, 2025 Author Share Posted May 16, 2025 Buongiorno. Niente si blocca anche con Sonoma. Rimetto ventura Link to comment Share on other sites More sharing options...
emiliano Posted May 22, 2025 Author Share Posted May 22, 2025 Buona sera. Normale che le ventole girano a palla ? Link to comment Share on other sites More sharing options...
emiliano Posted May 22, 2025 Author Share Posted May 22, 2025 Buona sera. Non va nemmeno con ventura Link to comment Share on other sites More sharing options...
