emiliano Posted December 23, 2024 Share Posted December 23, 2024 Buongiorno a tutti. Per la configurazione con H410 ed i5 10500 ho un problema. Non mi vede aggiornamento a 15.2. come posso risolvere? Grazie Link to comment Share on other sites More sharing options...
Solution Baio77 Posted December 23, 2024 Solution Share Posted December 23, 2024 Ciao Emi , https://github.com/Baio1977/RestrictEvents/actions questo il mio Fork alla versione 1.1.5 ufficiale ho aggiunto le mod del nostro Loris https://github.com/Lorys89/RestrictEvents/commits/master/ queste 1 Link to comment Share on other sites More sharing options...
emiliano Posted December 23, 2024 Author Share Posted December 23, 2024 Buongiorno @Baio77. Grazie mille per la risposta. é la prima volta. come lo uso? Link to comment Share on other sites More sharing options...
Baio77 Posted December 23, 2024 Share Posted December 23, 2024 prendi la kext la metti in EFI OC Kexts e la inserisci in config.plist poi fa tutto lei 😃 1 Link to comment Share on other sites More sharing options...
emiliano Posted December 23, 2024 Author Share Posted December 23, 2024 In che posizione ? Non trovo link dove scaricarla poi la lascio sempre? Link to comment Share on other sites More sharing options...
Baio77 Posted December 23, 2024 Share Posted December 23, 2024 ecco i file , li scarichi dalle actions del mio Fork RestrictEvents + Fix OTA update without bootarg by Loris.zip 1 1 Link to comment Share on other sites More sharing options...
emiliano Posted May 3, 2025 Author Share Posted May 3, 2025 Buona sera. Sto aggiornando a sequoia da ventura ma alla gui di oc quando vado su installer carica un po’ la barra e poi ritorna alla gui. Soluzioni? Grazie Link to comment Share on other sites More sharing options...
T19 Posted May 4, 2025 Share Posted May 4, 2025 Aggiorna opencore e kekt Abilita il verbose mode cosi vedi dove si blocca 1 Link to comment Share on other sites More sharing options...
emiliano Posted May 4, 2025 Author Share Posted May 4, 2025 Risolto grazie. Mi ha aiutato @Baio77 Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted May 4, 2025 Support Team Share Posted May 4, 2025 Grazie per aver condiviso la soluzione 😝 1 Link to comment Share on other sites More sharing options...
emiliano Posted May 4, 2025 Author Share Posted May 4, 2025 Semplice aggiornamento kext e oc che non avevo effettuato 🤦🏽♂️ 1 Link to comment Share on other sites More sharing options...
T19 Posted May 5, 2025 Share Posted May 5, 2025 appunto😉 1 Link to comment Share on other sites More sharing options...
emiliano Posted May 7, 2025 Author Share Posted May 7, 2025 Buongiorno. Sequoia però mi sta dando problemi di frequenti blocchi. In resoconto dei blocchi trovo una volta OneDrive di Microsoft e poi sharingd . Cosa può essere ? Grazie Link to comment Share on other sites More sharing options...
emiliano Posted May 8, 2025 Author Share Posted May 8, 2025 Buongiorno. Rinnovo la mia richiesta di aiuto. Inoltre volevo ritornare a ventura che non mi da problemi. Posso installare prima Windows e poi su partizione Mac. E’ possibile ? Grazie Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted May 8, 2025 Support Team Share Posted May 8, 2025 Quindi unico disco ? Si La EFI sara' condivisa Installi prima WIN , poi OSX sulla partizione dedicata Completata l nstallazione ( OSX ) monti la partione EFI del disco e salvi la cartella Microsoft sul desk ... il resto lo puoi eliminare Copi i file ( Opencore ) BOOT e OC dalla EFI della usb sulla EFI del disco , Riavvia , Resetta Nvram Avvia Ventura , monti la EFI ( del disco ) inserisci / copia pure la cartella Microsoft salvata prima sul Desk avrai cosi ... al prossimo riavvio verra' visualizzato anche Windows 1 Link to comment Share on other sites More sharing options...
emiliano Posted May 8, 2025 Author Share Posted May 8, 2025 @Anto65 perché sequoia mi da problemi blocchi e ventura no ? Grazie ancora Link to comment Share on other sites More sharing options...
emiliano Posted May 9, 2025 Author Share Posted May 9, 2025 Buongiorno @Anto65. scusami se ti disturbo. perché sequoia mi da problemi blocchi e ventura no ? Grazie ancora Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted May 9, 2025 Support Team Share Posted May 9, 2025 🤷 non saprei , personalmente non ho problemi Usi OCLP ? Potrebbe essere lui la causa OneDrive Microsoft - sharingd , prova a disattivare condivisione file Carica la EFI 1 Link to comment Share on other sites More sharing options...
emiliano Posted May 9, 2025 Author Share Posted May 9, 2025 @Anto65 devo mettere la eri qua? Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted May 9, 2025 Support Team Share Posted May 9, 2025 Si zippala ... s e' grande caricala qui https://easyupload.io/ Link to comment Share on other sites More sharing options...
emiliano Posted May 9, 2025 Author Share Posted May 9, 2025 @Anto65 caricata su easyupload https://limewire.com/d/sxuKq#9kl3QrkZjL Link to comment Share on other sites More sharing options...
emiliano Posted May 9, 2025 Author Share Posted May 9, 2025 Uso oclp Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted May 9, 2025 Support Team Share Posted May 9, 2025 Sembra tt ok il pc e' il 2° in firma giusto ? Prova a cambiare Config.plist.zip 1 Link to comment Share on other sites More sharing options...
emiliano Posted May 9, 2025 Author Share Posted May 9, 2025 Uso oclp. Si il secondo Provo grazie mille Link to comment Share on other sites More sharing options...
emiliano Posted May 10, 2025 Author Share Posted May 10, 2025 Buongiorno @Anto65 con il config che mi hai passato non mi fa installare oclp. ho messo sequoia su un ssd esterno per provare . sul principale tengo ventura intanto mi dice che sip è abilitato ed anche amfi inoltre 0x800 invece di 0x803. Link to comment Share on other sites More sharing options...
