ASUS ProArt X870E-CREATOR WIFI - Ryzen 9950x
1 hour ago, fabiosun said:
Do you mean also no video input of your bios scanning?
or do you see opencore bootloader?
you must start from your USB pen or disk and you have to format it in a proper way for EFI
So on the 4090 i see the bios and press F4 to boot from UEFI USB, and i see the bootloader showing Mac (usb drive) and my Windows installation. I then select Mac and both monitors go black i have left it for an hour while i did a few errands, and when I came back still the same black screens
I formatted the USB as FAT32 and GPT using Rufus, like the below screenshot
see below video
 both gpu plugged into tv as other monitor was borrowed and needed to be returned (4090 on HDMI 4) (6600 on HDMI1)
Edited by khile
it could be normal if you use 4090
try to connect your monitor(s) to rx6600
you should also prvide a full installer and not a recovery installer because in tahoe your ethernet card could not work and a recovery installers needs a working one ethernet
12 minutes ago, fabiosun said:
then with my efi you should see a "dos" verbose scrolling lines
Boot menu i see there is from gtx 4090?
We should see it on RX 6600
usb pen seems to be formatted well
Yes the boot menu is on the 4090. The 6600 does not display anything, but when I click mac it will briefly flash like it's getting a signal then just stay black
i cant seem to find a full installer that will give me a dmg image they all download as pkg files
Edited by khile
is it watercooled or you can remove easily it?
because it is weird if your RX is working well in other os
can you connect only a monitor to RX 6600 and try to boot to your USB as i see in your video?
then will think to full installer problem 🙂
I have a doubt if it is a problem with installed 4090
21 minutes ago, fabiosun said:
bios settings are well done for OSX?
Edited by fabiosun
grammar and added last line
can you attacch only a monitor to RX 6600 and try to boot to your USB as i see in your video?
 It is water-cooled but i have just removed it from slot and disconnected power to it (4090) so only RX6600 is in the system i see the bootloader and then when i select Mac it shows a black screen i dont get and verbose or anything  I have also reset bios and changed setting as stated above and still same issue
23 minutes ago, fabiosun said:
I know i am asking so much 🙂
could you put Rx 6600 in first slot?
are you sure you are trying from my latest EFI?
it seems you loose hdmi connection or there is always a signal also with black screen?
Okay, so removed 4090 and put RX 6600 in slot one. It displays the bootloader and then a black screen, as i have an LG tv it shows its receiving a 1080p signal but i dont see verbose or anything
5 minutes ago, khile said:
hi yes i have tried all ports on the card  and its this card i have https://www.techpowerup.com/gpu-specs/radeon-rx-6600.c3696
it seems a reference one ( i didnt know AMD did ones)
i could try a desperate try but only to see if you can do a step forward with your tv screen and your cables
try to set CSM on in your bios and see (if you do not damage other installation on your system)
Hey, sorry about late reply i had a slight water leak from moving the cards around i still get the same issue with a black screen - i found an update to bios so i've applied that but still no change Unfortunately
Yes i have borrowed a dell monitor, its has DP and hdmi and its the same it shows just a black screen
this puzzle is intriguing 🙂
If you have time and will
post all your bios settings (usually only boot section is useful) see if you have the virtualization option in the BIOS enabled or disabled in some bios part
but always weird you cant see the initial booting stage
here are bios images
few more
in key management have you cleared secure boot keys? but it should be done because you see boot menu
i would try to disable resize bar option and then also 4g in two different tries...but...now i am out of good ideas
Tried the above and no difference
i tried again with  opencore-simplify and got this instead
4090 shows this:IMG_0536.thumb.jpg.30f55173344332cea6a9e2001f1d7ce3.jpg
and the 6600 shows this now:
