max70 Posted November 18, 2024 Author Share Posted November 18, 2024 2 minutes ago, Anto65 said: ma hai riavviato dopo aver messo il kext ? Il tuo FeaturUnlock dici? si si certo 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 18, 2024 Supervisor Share Posted November 18, 2024 se usi photobooth ti fa utilizzare la camera dell'Ipad come camera? Link to comment Share on other sites More sharing options...
max70 Posted November 18, 2024 Author Share Posted November 18, 2024 No Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 18, 2024 Supervisor Share Posted November 18, 2024 Se non lo vedi come dispositivo olttre alla webcam credo ci siano altri problemi nei device del tuo account lo vedi insieme al Mac? Link to comment Share on other sites More sharing options...
max70 Posted November 18, 2024 Author Share Posted November 18, 2024 (edited) 3 minutes ago, fabiosun said: Se non lo vedi come dispositivo olttre alla webcam credo ci siano altri problemi nei device del tuo account lo vedi insieme al Mac? Come webcam non lo vedo, ma nell'account si, vede sia l'iPad, l'iPhone, l'Apple Watch e tutti Edited November 18, 2024 by max70 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 18, 2024 Supervisor Share Posted November 18, 2024 mi posti la tua EFi senza dati seriali e smbios? mi pare strano..io ora non ho fenvi ma potevo usare tutto e sbloccavo il mac/hack con il watch qaundo lo avevo La mappatura USB non la hai mai fatta immagino? Link to comment Share on other sites More sharing options...
max70 Posted November 18, 2024 Author Share Posted November 18, 2024 Eccola, ma non so come togliere i dati seriali e smbios. Mappatura USB mai fatta https://drive.google.com/file/d/1Z4F9zDQZIMgKzXJbxzLK5um8oDKBUQhI/view?usp=share_link Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 18, 2024 Supervisor Share Posted November 18, 2024 e wifi e blutooth funzionano su questo pc con una fenvi Broadcom patchata con OCLP su sequoia? 🙂 Link to comment Share on other sites More sharing options...
max70 Posted November 18, 2024 Author Share Posted November 18, 2024 Per quel che ne capisco si, il wifi si collega e navigo, e anche il bluetooth funziona e si collega Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 18, 2024 Supervisor Share Posted November 18, 2024 fai vedere che ti dice qui sulla destra? Comunque se riesci a mandarti foto con iphone e ipad sul pc sembrerebbe funzionare correttamente Link to comment Share on other sites More sharing options...
max70 Posted November 18, 2024 Author Share Posted November 18, 2024 Ecco Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 18, 2024 Supervisor Share Posted November 18, 2024 anche nella EFI a parte che usi <SMBIOS Imacpro1.1 e' tutto ok Io userei macpro 7.1, pero' non vorrei che ti si incasini l'accesso a apple Link to comment Share on other sites More sharing options...
max70 Posted November 18, 2024 Author Share Posted November 18, 2024 29 minutes ago, fabiosun said: anche nella EFI a parte che usi <SMBIOS Imacpro1.1 e' tutto ok Io userei macpro 7.1, pero' non vorrei che ti si incasini l'accesso a apple Mi pare proprio che si era optato per quella versione di smbios perché non dava problemi. Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 19, 2024 Supervisor Share Posted November 19, 2024 La versione piu' adatta sarebbe la MacPro7.1, ma se cambi seriali poi potresti avere problemi diversi con i servizi apple Forse per quello non avevamo cambiato il tuo precedente SMBios Link to comment Share on other sites More sharing options...
max70 Posted November 19, 2024 Author Share Posted November 19, 2024 Che dite posso provare a cambiare il modello da imacpro1,1 a macpro7,1 ? Faccio un backup su una penna della EFI e lo cambio usando OCAT dalla sezione PI/SMBIOS? Basta cambiare il modello alla sezione SystemProductName o va fatto qualcos'altro? Grazie Link to comment Share on other sites More sharing options...
max70 Posted November 23, 2024 Author Share Posted November 23, 2024 Una guida abbastanza semplice per provare a cambiare SMBios c'è? Qualcuno sa indirizzarmi? Link to comment Share on other sites More sharing options...
max70 Posted November 25, 2024 Author Share Posted November 25, 2024 Ciao gente Mi sono fatto coraggio e dopo aver cercato e trovato guide per cambiare l'smbios ho provveduto con OCAT e tutto è filato liscio. Ho impostato come modello MacPro 7.1 e sembra funzionare tutto, anche i servizi Apple. Ma la funzione Continuity per estendere il desktop sull'ipad mi blocca sempre il computer. Potrebbe essere vovuto alla mancanza di mappatura delle porte usb? Mi date qualche suggerimento? Grazie anticipate Link to comment Share on other sites More sharing options...
