Ploddles Posted November 13, 2025 Share Posted November 13, 2025 Thanks @fabiosun, that USB Network controller works great. 1 Link to comment Share on other sites More sharing options...
Xsario Posted November 14, 2025 Share Posted November 14, 2025 (edited) On 11/13/2025 at 1:26 PM, fabiosun said: @Xsario https://limewire.com/d/8PjAu#4b5uKzMwP2 this is your SOnoma working EFI with opencore debug to extract your SysReport folder if your EFI booted well sonoma and sequoia this should do the same It will add in your EFI partition your actual SysReport folder If so post this folder zipped here try it only with Sonoma (or Sequoia if you have also Sequoia installed) Hi @fabiosun, I tested the EFI you shared on my system in both Sequoia and Sonoma and shared the resulting sysreport files via the link below. https://limewire.com/d/LKKBO#Jo2pihWJQK Edited November 14, 2025 by Xsario wrong verbs Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 14, 2025 Author Supervisor Share Posted November 14, 2025 42 minutes ago, Xsario said: Hi @fabiosun, I tested the EFI you shared on my system in both Sequoia and Sonoma and shared the resulting sysreport files via the link below. https://limewire.com/d/LKKBO#Jo2pihWJQK https://limewire.com/d/nYz6B#XyRCjaHk77 try this in sonoma and or Sequoia and see if it boots if so try also Tahoe..i changed ACPI/ssdt via SSDT Time and updated kernel patches for tahoe (deleted aquantia one idk if they support Tahoe for now (if it boots you can try to add back then) pls backup always your working efi Link to comment Share on other sites More sharing options...
Xsario Posted November 14, 2025 Share Posted November 14, 2025 @fabiosun, I tried installing Tahoe with the EFI you sent last, and my device restarted. I encountered the restart issue every time I tried again. The Sonoma and Sequoia installations with the same EFI are opening without any problems. Is there another solution you can suggest? Thanks for help. Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 14, 2025 Author Supervisor Share Posted November 14, 2025 9 minutes ago, Xsario said: @fabiosun, I tried installing Tahoe with the EFI you sent last, and my device restarted. I encountered the restart issue every time I tried again. The Sonoma and Sequoia installations with the same EFI are opening without any problems. Is there another solution you can suggest? Thanks for help. Same EFI try this config only for tahoe installation config.plist.zip Link to comment Share on other sites More sharing options...
Xsario Posted November 14, 2025 Share Posted November 14, 2025 (edited) 1 hour ago, fabiosun said: Same EFI try this config only for tahoe installation config.plist.zip 7.35 kB · 1 download @fabiosun, I tried the new config.plist file and my system restarted when i tried tahoe install. Edited November 14, 2025 by Xsario missing verbs Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 14, 2025 Author Supervisor Share Posted November 14, 2025 @Xsarioi am running out of good idea may i ask why in your working config you use Aquantia ethernet patches? Have you an aquantia ethernet on pcie card? Link to comment Share on other sites More sharing options...
Xsario Posted November 16, 2025 Share Posted November 16, 2025 On 11/14/2025 at 6:39 PM, fabiosun said: @Xsarioi am running out of good idea may i ask why in your working config you use Aquantia ethernet patches? Have you an aquantia ethernet on pcie card? @fabiosun, This is really unfortunate. I don't understand why I experienced these issues on the Tahoe with a similar configuration system. Yes, I have a 10G Aquantia Ethernet card in the PCIx slot. Link to comment Share on other sites More sharing options...
Ploddles Posted November 16, 2025 Share Posted November 16, 2025 @Xsariowhat BIOS version are you on? I’m using the latest without any problems. Link to comment Share on other sites More sharing options...
Xsario Posted November 17, 2025 Share Posted November 17, 2025 11 hours ago, Ploddles said: @Xsariowhat BIOS version are you on? I’m using the latest without any problems. @Ploddles, I am using version 3304 on my system. Could you share your BIOS settings with me? I may have made a mistake in some BIOS settings. 🙂 Link to comment Share on other sites More sharing options...
Ploddles Posted November 17, 2025 Share Posted November 17, 2025 4 hours ago, Xsario said: @Ploddles, I am using version 3304 on my system. Could you share your BIOS settings with me? I may have made a mistake in some BIOS settings. 🙂 Sure. First I do the Load Optimised Defaults (on the Exit screen). Memory I set at 5400 Press F9 (search option) type CONTEXT and Enable both values Save & Exit I haven't played with changing the Memory settings but that works fine for me - I could try other settings but I don't think it would make much difference. Link to comment Share on other sites More sharing options...
Xsario Posted November 18, 2025 Share Posted November 18, 2025 Hi @Ploddles, I followed the same steps you shared, and my system restarted again. I booted Sonoma and Sequia with the same EFI, and the installation screen appeared without any issues. Link to comment Share on other sites More sharing options...
Ploddles Posted November 18, 2025 Share Posted November 18, 2025 All I can think of now is it may be the usb mapping. When I get home this afternoon I’ll upload a dummy one you can try. Link to comment Share on other sites More sharing options...
Xsario Posted November 18, 2025 Share Posted November 18, 2025 Alright, thank you, my friend. Link to comment Share on other sites More sharing options...
Ploddles Posted November 18, 2025 Share Posted November 18, 2025 @Xsario, try this instead of USBMap.kext. USBMapDummy.kext.zip Link to comment Share on other sites More sharing options...
Xsario Posted November 19, 2025 Share Posted November 19, 2025 @Ploddles, This didn't work either. I'm starting to suspect this new BIOS. The system was more stable before the BIOS update. Is there another BIOS you can recommend? If the problem is with the USB configuration, how can I create my own kext for Tahoe? Link to comment Share on other sites More sharing options...
Ploddles Posted November 19, 2025 Share Posted November 19, 2025 All the BIOS versions work for me. I think the only relevant difference between our systems is that you have the additional network card installed. If possible, it may be worth trying the install without the card in your machine. To create the USB kext, you need to download and run CorpNewts script, which can be downloaded from GitHub, https://github.com/corpnewt/USBMap. You can run it from Sonoma or Sequoia. Link to comment Share on other sites More sharing options...
Ploddles Posted November 28, 2025 Share Posted November 28, 2025 @Xsario I purchased a new drive to try a fresh Tahoe install. To start with it was continually rebooting just like yours did. However, I finally got it installed and working with the attached EFI. EFI.zip Link to comment Share on other sites More sharing options...
Xsario Posted December 1, 2025 Share Posted December 1, 2025 On 29.11.2025 at 00:56, Ploddles said: @Xsario Yeni bir Tahoe kurulumu denemek için yeni bir sürücü satın aldım. Başlangıçta tıpkı sizinki gibi sürekli yeniden başlatılıyordu. Ancak sonunda kurulumu yaptım ve ekteki EFI ile çalışır hale getirdim. EFI.zip 9.06 MB · 0 indirme Hi @Ploddles, Thank you for the good news. I'll try it when I have time. Also, the new BIOS version 3402 is out. Have you updated to this version? Link to comment Share on other sites More sharing options...
Xsario Posted March 12 Share Posted March 12 On 11/29/2025 at 12:56 AM, Ploddles said: @Xsario I purchased a new drive to try a fresh Tahoe install. To start with it was continually rebooting just like yours did. However, I finally got it installed and working with the attached EFI. EFI.zip 9.06 MB · 26 downloads Hi @fabiosun @Ploddles, I tried installing Tahoe 26.3.2 again with the latest EFI you shared, but it failed. I can briefly summarize my attempts as follows. I updated the motherboard's BIOS version to 3513. I reset the BIOS to default and only updated the memory as you previously shared, then changed the CONTEXT and saved it. I removed the Aquantic card from my device. I booted from the EFI, but I noticed a freeze during boot, as shown in the image I shared. Alsa I have shared my EFI for you. Could you help me with the Tahoe installation? Thanks for help. EFI.zip Link to comment Share on other sites More sharing options...
