Installazione mac os Ventura
Niconaco
Ciao , EFI aggiornata alla versione ?
Rivedila con OCAT ( se ti e' piu' semplice  ) e riprova ... in caso si cambia Smbios
Last login: Wed Jan 11 20:28:02 on ttys000
lupi@iMac ~ % /Users/lupi/Downloads/OpenCore-0.8.8-RELEASE/Utilities/ocvalidate/ocvalidate /Users/lupi/Desktop/nico-EFI/OC/config.plist
NOTE: This version of ocvalidate is only compatible with OpenCore version 0.8.8!
OCS: Missing key CustomPciSerialDevice, context <Quirks>!
OCS: Missing key ForceAquantiaEthernet, context <Quirks>!
OCS: Missing key HibernateSkipsPicker, context <Boot>!
OCS: No schema for SerialInit at 5 index, context <Debug>!
OCS: Missing key LogModules, context <Debug>!
OCS: No schema for AllowNvramReset at 0 index, context <Security>!
OCS: No schema for AllowToggleSip at 2 index, context <Security>!
OCS: Missing key FullNvramAccess, context <Tools>!
OCS: Missing key Serial, context <Misc>!
OCS: No schema for LegacyEnable at 2 index, context <NVRAM>!
OCS: Missing key PointerDwellClickTimeout, context <AppleInput>!
OCS: Missing key PointerDwellDoubleClickTimeout, context <AppleInput>!
OCS: Missing key PointerDwellRadius, context <AppleInput>!
OCS: Missing key LoadEarly, context <Drivers>!
Serialisation returns 29 errors!
UEFI->Output->IgnoreTextInGraphics is enabled on non-System TextRenderer (currently BuiltinGraphics)!
CheckUefi returns 1 error!
Completed validating /Users/lupi/Desktop/nico-EFI/OC/config.plist in 1 ms. Found 30 issues requiring attention.
  Mostra contenuto nascosto
ciao, è aggiornata alla versione opencore 0.7.8
11 minuti fa, antuneddu ha scritto:
Infatti 😁 hai visto gli errori nello spoiler ?
Siamo alla 0.8.8 !!!
ah non avevo visto, ero convinto che l’ultima versione fosse la 0.7.8 errore mio, è un po’ tutto nuovo per me 😅 domani aggiorno grazie mille!
