Fix SLPB on AMD machine
Lorys89
What happens to your rig if you press the case's power button for one click?
does this happen?
image.thumb.png.99c8c87e872b62a9f88fb6005838c710.png.6793490f27a1a83331479ba67a3bd66e.png
(if it appears then you don't need this guide!)
otherwise you can try to use an ssdt that injects SLPB device and spoof SBRG as if it were LPCB of an intel machine
SSDT-SLPB-SBRG.zip
"i took inspiration from ioregs of real macs and their ACPI"
Edited by Lorys89
  • Like 3
