Help with AMD Power Gadget
SavageAUS
So for the longest time now i have had the error shown in the screen shot and i am finally sick of it.
Please help me.
I have the latest app and kexts and latest OC with RC Ventura and it is still happening.
I believe the kext order is correct.
351692179_Screenshot2022-10-19at7_35_17pm.thumb.png.d3d9d2d2e280a4028720d0188b067bf7.png
  On 10/19/2022 at 11:33 AM, SavageAUS said:
Yeah I updated the app. It’s not listed in login items, just background permissions.
Expand
it seems a wrong assigned path
If you run the app does it start or always that error?
Is it a OS starting error or you can't run that app?
Edited by fabiosun
This was the fix.
I removed all traces of the app, downloaded the newest Kexts and app again. Deleted the "old" kexts from EFI, moved the new ones into EFI and rebooted.
This removed the app from startup and background tasks. I then launched the app and added it to the login items, rebooted and all seems to be good.
