Clover Configurator problem
From many versions the Clover Configurator app has serious problems if you use the features guaranteed by Clover Bootloader.
I am referring in particular to the KernelToPatch section and the skip and count tabs which are completely missing (see photo below)
The even more serious thing is that if you provide a config.plist that has these two tabs in it, the app just with a simple save deletes the config lines, producing serious difficulties and a non-working config.plist
This is of particular importance for users with AMD CPUs, but it is also of some importance for Intel users who use some Kernel patches with clover (take a look to know which ones are in the samplefull.plist present in the opencore docs)
To avoid controversy I am attaching a link where the Clover dev (Slice) explains the changes in the clover versions .. and skip and count are present and identical to the corresponding versions of OpenCore!
slice tab conversions (Clover---OpenCore)
