Rx 6800 XT fe
Giaccaz
17 minuti fa, Giaccaz ha scritto:
ma ...scusa l'hai compilato tu quel ssdt?
 c'era gia da qualche parte?
Cambiato percorso da peg0 a Peg1 ma lo puoi compilare da 0 anche tu se vuoi, se non erro gengik l ha qui in sez download ma credo con percorso peg0 o quello per percorso delle mobo amd cpu.
Basta averci un minimo di manualità con la lettura di acpi e ioreg e saper usare maciasl e ti puoi creare tutti gli ssdt personalizzati con i percorsi per il tuo hardware 🤷
Comunque hai la stessa mobo di un mio amico a lui ho attivato pure igpu, se ti servisse la patch igpu te la passo.
senza fare nulla al config?
Changelogs
OpenCore 0.7.7
Fixed rare crash caused by register corruption in the entry point
Added ProvideCurrentCpuInfo support for Intel Alder Lake
Fixed typo in Cpuid1Data recommendations for Intel Rocket Lake and newer
Updated builtin firmware versions for SMBIOS and the rest
Updated underlying EDK II package to edk2-stable202111
Resolved crashes in QEMU with AudioDxe
Added AudioDxe settings caching (avoids non-needed setup delays)
Added DisconnectHda quirk to allow UEFI sound on Apple hardware and others
Added workarounds for bugs in QEMU intel-hda driver to allow UEFI sound in QEMU
Implemented multi-channel (e.g. bass+main speaker; speakers+headphones) UEFI sound with AudioOutMask
Fixed AudioDxe startup stalls when Nvidia HDA audio is present
Resolved AudioDxe disabling sound in Windows on some firmware
Added pointer polling period tuning in the builtin AppleEvent implementation
Added pointer device list tuning in the builtin AppleEvent implementation
Added VREF handling to support UEFI sound on more Apple hardware
Updated audio output channel detection to support UEFI sound on more Apple hardware
Added manual GPIO config (use --gpio-setup AudioDxe driver argument for UEFI sound on Apple hardware)
Switched UEFI audio levels to decibel gain to allow accurate matching of saved macOS volume levels
Separated settings for minimum audio assist volume and minimum audible volume
16 minutes ago, Giaccaz said:
In effetti ho messo su il 0.7.6 e non mi dava nessun errore....appena lo aggiornato alla vers. 0.8.2 mi usciva .
Ma non capisco il perché.
e perche' avresti messo una versione cosi' vecchia?
Semplicemente son tornato indietro perché volevo capire se avevo cambiato qualcosa nel config.
Ho provato la 0.8 /0.7.9  e mi davano quel problema....poi son passato alla 0.7.6 e sembrava andare , poi l'ho aggiornata con Ocat e mi è tornato fuori.
P.s scusa se ti rispondo tardi...ma son a lavoro
se leggi nel log che ho messo, la funzione e' stata aggiunta dalla versione 0.77
molto probabilemnte OCAT non la corregge ritenendola non essenziale (o e' un bug della app)
comunque non scenderei cosi' tanto di versione e cercherei di sistemare il problema nella versione ultima disponibile
Anche a me piacerebbe sistemare dalla vers.attuale (0.8 2), ma sta vga si è dimostrata "gioie e dolori" .
Devo combattere su due fronti.
Uno win11 che ho capito che se abilito la funzione c.a.m nel bios ( uguale al b.a.r .....non il bar dove si va a bere 😁) all'avvio mi da schermo nero, non ho capito se è un incompatibilità onson i driver amd.
Adesso sotto osx sti benedetti errori...fastidiosi!!!
SONO IN GUERRA!!!!
Edited by Giaccaz
Nemmeno io mai avuto problemi sia su Windows 10 che adesso su 11. Sempre resize bar attiva.
Con I driver, su Windows, ho da sempre queste fisse:
1) non installo mai driver beta
2) Quando esce una nuova versione stabile del driver AMD non eseguo l’aggiornamento via utility AMD ma prima procedo a rimuovere i vecchi driver in ambiente di modalità provvisoria usando o AMDCleanup utility o Display Driver Uninstaller.
3) Quindi riavvio in modalità normale, disattivo completamente  sia l’antivirus di terze parti - se presente - sia Microsoft Defender e infine lancio installazione dei nuovi driver al termine della quale riavvio in ogni caso.
9 minutes ago, Giaccaz said:
Installo win 11 disabilitando csm
ed e' cosa buona e giusta ma cosa centra con OSX e lo schermo nero
io ho uefi, ResizeBar (CAM) e 4G tutti su on e con una EFI parte tutto
io ti chiedevo, parti con il menu di opencore per entrare in windows? o con il tasto funzione della tua piastra?
si scusa ma sto usando il cell.. con la tastiera e mouse.....mentre sto riprovando ad installare win.
Come dicevo disabilito csm  imposto il secure boot e il tpm , installo win e parte appena installo i driver di amd una volta finito , riavvia e quando arriva il  suono lo schermo rimane nero, cosa che quando non avevo installato i driver amd non succedeva.
Se disabilito il C.a.m e faccio il boot di win tutto funziona, ma ovviamente senza il resize bar ( c.a.m)
Avvio con il bootloader di oc.
io proverei nelle condizioni che ti da schermo nero a partire con il tasto funzione per la tua piastra
se anche li hai schermo nero e' da capire meglio
cosi' come mi dici potrebbe essere un problema di ssdt o di opzioni del tuo config
adesso sto scrivendo con win11
1 quando tento di installare win11 in un dei 2 ssd con la pendrive creata con mediacreation di win  , e nello stesso momento ho anche i due nvme , arrivo alla voce di creazione del volume scegliendo il ssd , ma non va oltre la formattazione perche mi dice che non va bene ( non capisco se mi crea la partizione gpt o mbr ).
2 se lo faccio senza i due nvme l'installazione parte al primo colpo .....come ora.
3 se utilizzo solo il ssd di win 11 senza nessun altro disco , il problema  C.a.m (Resize bar) persiste, non centra il bootloader di Oc.....almeno credo, adesso ci riprovo.
Edited by Giaccaz
come installare windows e' un altro discorso, e qui ci possono essere problemi diversi
pero' se e' installato puoi partire con UEFI on ed il resto a mio parere
pero' e' solo una opinione
