AlexAMD Posted June 25, 2022 Share Posted June 25, 2022 Ciao tutti, visto e considerato che con il tempo e i nuovi OS qualcosa è cambiato, volevo chiedervi una mano per ottimizzare la mia EFI OC per il mio Huawei ... Grazie in anticipo vi allego la EFI_Huawei Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted June 25, 2022 Support Team Share Posted June 25, 2022 hai usb pronta per testare una efi? cambio smbios quindi sloggati dai servizi apple in ogni os installato Link to comment Share on other sites More sharing options...
AlexAMD Posted June 25, 2022 Author Share Posted June 25, 2022 ok Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted June 25, 2022 Support Team Share Posted June 25, 2022 che os hai su? per metter le kext intel lo chiedo Link to comment Share on other sites More sharing options...
AlexAMD Posted June 25, 2022 Author Share Posted June 25, 2022 sono su ventura beta2 Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted June 25, 2022 Support Team Share Posted June 25, 2022 non c hai pure monterey? Link to comment Share on other sites More sharing options...
AlexAMD Posted June 25, 2022 Author Share Posted June 25, 2022 (edited) no prima ho sbagliato topic mi sembrava quello di ventura .... scusate ... Edited June 25, 2022 by AlexAMD Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted June 25, 2022 Support Team Share Posted June 25, 2022 6 minuti fa, AlexAMD ha scritto: no prima ho sbagliato topi mi sembrava quello di ventura .... scusate ... provala su usb https://github.com/Lorys89/Lorys89/raw/main/FILE - TEST/EFI.zip. e se avvia posta ioreg Link to comment Share on other sites More sharing options...
AlexAMD Posted June 25, 2022 Author Share Posted June 25, 2022 Bloccato come in figura allegata blocco P.S. se hai notato ho WEG 1.4.5 perché è l'unico e l'ultimo che funziona perché con gli altri ho schermo nero dopo il secondo avvio Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted June 25, 2022 Support Team Share Posted June 25, 2022 4 minuti fa, AlexAMD ha scritto: Bloccato come in figura allegata blocco P.S. se hai notato ho WEG 1.4.5 perché è l'unico e l'ultimo che funziona perché con gli altri ho schermo nero dopo il secondo avvio mandami un ioreg fatto con la tua efi che avvia ma hai pure touchscreen? Link to comment Share on other sites More sharing options...
AlexAMD Posted June 25, 2022 Author Share Posted June 25, 2022 Eccolo IOReg Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted June 25, 2022 Support Team Share Posted June 25, 2022 8 minuti fa, AlexAMD ha scritto: Eccolo IOReg prova questa https://github.com/Lorys89/Lorys89/raw/main/FILE - TEST/EFI.zip Link to comment Share on other sites More sharing options...
AlexAMD Posted June 25, 2022 Author Share Posted June 25, 2022 Bloccato QUI Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted June 25, 2022 Support Team Share Posted June 25, 2022 hai le acpi origin e sys report? Link to comment Share on other sites More sharing options...
AlexAMD Posted June 25, 2022 Author Share Posted June 25, 2022 no se mi ricordi come estrarle con opencore Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted June 25, 2022 Support Team Share Posted June 25, 2022 con efi debug Link to comment Share on other sites More sharing options...
AlexAMD Posted June 25, 2022 Author Share Posted June 25, 2022 (edited) aspe provo ma devo impostare qualcosa nel config .... Edited June 25, 2022 by AlexAMD Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted June 25, 2022 Support Team Share Posted June 25, 2022 (edited) 3 ore fa, AlexAMD ha scritto: aspe provo ma devo impostare qualcosa nel config .... prova sta efi debug 0.8.2 serve solo per il sysreport e il log e non per avviare os altra cosa hai gia sbloccato il cfg lock? e impostato dvmt pre a 64mb e dvmt total al max? Edited June 25, 2022 by Lorys89 Link to comment Share on other sites More sharing options...
AlexAMD Posted June 25, 2022 Author Share Posted June 25, 2022 SYSRepost Come si sblocca il cfg Lock? dvmt lo trovo nel bios???? Scusa l'ignoranza Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted June 25, 2022 Support Team Share Posted June 25, 2022 2 minuti fa, AlexAMD ha scritto: SYSRepost Come si sblocca il cfg Lock? dvmt lo trovo nel bios???? Scusa l'ignoranza manca il log txt https://github.com/Lorys89/Lorys89/raw/main/Test/EFI.zip prova ad avviare Link to comment Share on other sites More sharing options...
AlexAMD Posted June 25, 2022 Author Share Posted June 25, 2022 (edited) é partito ! ti allego IOReg ho solo la risoluzione 2160 x 1440 non mi fa selezionare altro ..... anche se seleziono "ridimensiona" inoltre non ho attivi i tasti volumi , luminosità dello schermo e dei tasti in f1, f2 ,f3 4 5 6 .... ram monitor mi segna 11M Edited June 25, 2022 by AlexAMD Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted June 25, 2022 Support Team Share Posted June 25, 2022 2 minuti fa, AlexAMD ha scritto: é partito ! ti allego IOReg ho solo la risoluzione 2160 x 1440 non mi fa selezionare altro ..... anche se seleziono "ridimensiona" inoltre non ho attivi i tasti volumi , luminosità dello schermo e dei tasti in f1, f2 ,f3 4 5 6 .... ram monitor mi segna 11M riscarica la efi l ho cambiata https://github.com/Lorys89/Lorys89/raw/main/Test/EFI.zip e riprova e poi ripassi ioreg Link to comment Share on other sites More sharing options...
AlexAMD Posted June 25, 2022 Author Share Posted June 25, 2022 IOReg Ok risoluzioni e ram scheda video ... Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted June 25, 2022 Support Team Share Posted June 25, 2022 1 minuto fa, AlexAMD ha scritto: IOReg Ok risoluzioni e ram scheda video ... cosa non funziona ancora? tasti audio e luminosità funzionano? Link to comment Share on other sites More sharing options...
AlexAMD Posted June 25, 2022 Author Share Posted June 25, 2022 no non funzionano ne tasti volume luminosità video e luminosità tastiera Link to comment Share on other sites More sharing options...
