Windows 11 installazione da zero...
https://mega.nz/file/oJZjARZS#11lua7A1pQcnCQXgmdf1Ow8ok3XdFkC4eXIloJFfB2s
Integrato tutti e due gli indici tranne i drv della video:
Found 9 driver package(s) to install.
Installing 1 of 9 - D:\ZZZ\amdgpio2.inf_amd64_c72fc3523c1372d0\amdgpio2.inf: The driver package was successfully installed.
Installing 2 of 9 - D:\ZZZ\amdkmpfd.inf_amd64_1942e56b3f6d998e\amdkmpfd.inf: The driver package was successfully installed.
Installing 3 of 9 - D:\ZZZ\amdpcidev.inf_amd64_39b703dc7c5f8982\AMDPCIDev.inf: The driver package was successfully installed.
Installing 4 of 9 - D:\ZZZ\amdpsp.inf_amd64_db1b2556e686c32f\amdpsp.inf: The driver package was successfully installed.
Installing 5 of 9 - D:\ZZZ\atihdwt6.inf_amd64_1b03984455a9ce17\AtihdWT6.inf: The driver package was successfully installed.
Installing 6 of 9 - D:\ZZZ\prnms001.inf_amd64_202973c89a035606\prnms001.Inf: The driver package was successfully installed.
Installing 7 of 9 - D:\ZZZ\prnms009.inf_amd64_620c281895426e89\prnms009.Inf: The driver package was successfully installed.
Installing 8 of 9 - D:\ZZZ\rtucx22x64.inf_amd64_a19e472f32bd1e8d\rtucx22x64.INF: The driver package was successfully installed.
Installing 9 of 9 - D:\ZZZ\smbusamd.inf_amd64_e470528883cc6bc5\SMBUSamd.inf: The driver package was successfully installed.
Operazione completata.
Lo scopo è quello di fare un’installazione, perfezionare il Sistema con i Driver più recenti o migliori, backuppare l’archivio di suddetti driver, integrarli in install.wim. Ogni volta che installeremo il Sistema sarà in quella condizione di massimo aggiornamento, disabilitare prima di entrare in rete gli update DVR da Windows in maniera che nulla interferisca con le nostre scelte.
Possiamo anche integrare Driver di altri hardware al fine di ottenere una ISO che risponderà a questi requisiti su tutta una serie di computer.
Premessa che sono certo che è un Problema locale in quanto msi avrà di certo installato Windows nei vari test pre produzione
da capire quale combinazione di hardware/ bios inibisce qui il funzionamento
ora faccio un clear cmos e provo senza fare altro e vediamo
In pratica non vede in nessuna condizione i dischi nvme
ma anche se ci attacco un sata
questo lo vede ma non prosegue linstallazione
ora ho staccato tutto tranne i tre nvme
Se precarichi i driver che sono sul Sito deve verdelli eccome, hai usato il boot.wim con i driver, ma di sata non vedevo nulla tra quelli che ho integrato, ma male non fanno.
adesso ho fatto delle prove piu' basiche
sconnessi tutti i sata
non vede nulla eccetto la pennetta
caricato bios di default resettando Cmos uguale
ora mi chiedo
ma non lo faccio
se smonto tutti gli nvme e metto solo uno al primo slot
scarico una iso e crea una penna normale di installazione....
come magari farebbe un utente qualsiasi
perche' non vede il disco?
tra parentesi nel bios ci sono e li vede nella sezione boot/boot order
e' in uno dei mega che mi hai fatto questa condizione?
ora provo con questo
Ci sta come per il RAID che ci sono i Driver per quelle periferiche dei Dischi, io quelli del sito li avevo precaricati ma non sono quelli, prova a vedere nelle periferiche di che driver si tratta, io non uso mai niente di nvme mi serve continuamente una macchina dove disabilitare le periferiche dello storage da BIOS.
A meno che non sono il ramo di un altro Driver...
Nulla è anche giusto, teoricamente deve vederli, a meno che il boot.wim non li abbia come da immagine mi pare strano.
i Driver nella sezione Disco periferiche sono tutto Microsoft 2006..?
