mongi Posted May 24, 2022 Share Posted May 24, 2022 ragazzi volevo ''hackintoshizzare'' il mio fisso secondario, componenti: - i5-9400f -nvidia 1650 (che sustituiro') -8gb ram volevo sapere che scheda grafica mi consigliereste, per poter sostituire la Nvidia. Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted May 24, 2022 Supervisor Share Posted May 24, 2022 Dipende dal budget che hai RX 560/570/580/590 Vega 56/54 Rx 6600/6600 xt Rx 6800/6800 xt 6900 xt per la CPU che hai credo sia la 6600 xt la scelta migliore Link to comment Share on other sites More sharing options...
emiliano Posted November 8, 2023 Share Posted November 8, 2023 Buona sera @fabiosun. Per un i5 12400 va bene una sapphire pulse rx 6600 per Sonoma ? Grazie Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 8, 2023 Supervisor Share Posted November 8, 2023 Ottima scheda pronta anche se un giorno prendi una cpu più potente 1 Link to comment Share on other sites More sharing options...
emiliano Posted November 8, 2023 Share Posted November 8, 2023 @fabiosun l’ho trovata ad euro 226. E’ un buon prezzo o posso trovare di meglio a quel prezzo ? Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 9, 2023 Supervisor Share Posted November 9, 2023 Su Amazon nrinfo ne fa una a 219 nel nostro mercatino un admin ne vende una a 150 ( di seconda mano) 1 Link to comment Share on other sites More sharing options...
emiliano Posted November 9, 2023 Share Posted November 9, 2023 @fabiosun buongiorno . Dove trovo il mercatino ? Grazie Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 9, 2023 Supervisor Share Posted November 9, 2023 On 11/9/2023 at 1:29 PM, emiliano said: @fabiosun buongiorno . Dove trovo il mercatino ? Grazie Expand https://macos86.it/forum/34-mercatino-macos86/ 1 Link to comment Share on other sites More sharing options...
emiliano Posted November 9, 2023 Share Posted November 9, 2023 @fabiosun Grazie Link to comment Share on other sites More sharing options...
