Xeon W and Asus WS C422
"fabiosun" post_id="12170" time="1534587536" user_id="56">
Sorry @obus
your first MSR patch togheter fakecpuid produces 1 for both terminal command?
Yes but with "_xcpm_pkg_scope_msrs_PMhart" and FakeCPUID.
Added in 3 minutes 21 seconds:
AppleIntelInfo.
Added in 33 minutes 51 seconds:
Ok fabiosun.
I have tested a little bit further.
With FakeCPUID my rig boots with full powermanagment (xcpm) together with this patches:
1._xcpm_pkg_scope_msrs_PMhart 31D2E8AE FCFFFF ->31D29090 909090
2.pikeralpha reboot fix554889E5 41574156 41554154 53504189 D64889FB 4189F54C 8D3D7662 -> C34889E5 41574156 41554154 53504189 D64889FB 4189F54C 8D3D7662
3._xcpm_smt_scope31D2E87E FCFFFF -> 31D29090 909090
With xcpm_bootstrap © Pike R. Alpha 89D804C4 3C227722 -> 89D804C1 3C227722 my rig is booting without FakeCPUID and with any other patch but always without native powermanagment (xcpm).
Could it be a bug in Clover? Obviously I can achieve xcpm mode if I use a fake skylakecpuid. If I use 0.0506E3 or E4 or even some other skylake cpuid it seems to work but as soon as I use the correct id 050654 for Skylake X everything seems to get fucked up.
AppleInteInfo.txt.zip
Ciao obus
It seems we can not avoid using fakecpuid..
Probably also others like Broadwell Ep 0x40764 (I don't remember well) do the same job
It is very strange also you can use Appleintelinfo kext because in new I9 architecture it is not working well if MSR is checked in option
Analyzing it you miss C3 states in output but it is pretty normal
Previously when I had an unsupported cpu there was a kernel patches by SammlerG to activate C3 output, in real use however no difference
to come back to our "issue"
I am searching a kernel patch for adding cpu id in kernel section..but I can't find it
Also it would be the same thing of using fakecpuid, so no great catch
No I do not thing it is a clover bug?
but also it is strange if you use KernelXCPM flag is not working for you..
this flag was an automated way to patch unsupported Cpu we had asked the past to clover's coders to not use in automatic way.
My advice is to launch appleintelinfo and use your system loaded/unloade for few time and see if all CPU pSTATES come out
then evaluate if for you it is better to use a Broadwell EP fakecpuid or Skilake X in terms of stability and performances
Hoping Apple programmers include your cpu in next OSX release
Ha scritto dopo 1 minuto 51 secondi:
PS remember also to try unlock MSR bios option to see if you can avoid using MSR patch or any kernel patches
Using a fakecpuid you are using a way to use XCPM of another family of CPU
But it not should be your case because Xeon W family is A CPU supported in iMac Pro...( ;( )
C3 states could be visible only programming MSR 0xe2 from this value 0x1E000005 to another with the help of a kernel patch which an user )SammlerG) found for old OSX version
If I was you I would test with software like cinebench, Geekbench, luxmark 3.1 all your system and post the result also grabbing output and temperature with IPG
To see performances, stability and temperatures in both condition
I think however which your system could reach all States also with Skylake x fakecpuid..maybe it needs more time to reach all states
then you should have a clear situation of optimal condition for your system
Ha scritto dopo 5 minuti 41 secondi:
to explain better C3 states stuff (this is an extraction from an old Insanely Mac thread I created time ago)
follow patch I was using in Sierra to have C3 States, in bold the one which does what I have said in previous message (MSR 0xE2 programming)
Solution 2 (same results and behavior of solution 1)
Bios Unlocked
EIST Enabled
​4g enabled (only for Sierra)
​kext Patch
IOPCIFamily
find
4881FB00000040
replace
4881FB00000080
5960X 10.12 Brumbaer
6 patches
find
AA010000DC3300000000000000000000000000000000000001
replace
AA010000000000000000000000000000000000000000000000
SammlerG Sierra xcpm MSR Patch 1 / xcpm support Pike R. Alpha
find
A0010000DC33000000000000000000000000000040000000010005
replace
A0010000DC33000000000000000000000000000040000000010004
SammlerG Sierra xcpm MSR Patch 2 / xcpm support Pike R. Alpha
find
3A060000DC33000000000000000000001F00000000000000000000000000000000000000000000000000000000000000
replace
3A0600000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
SammlerG Sierra xcpm MSR Patch 3 / xcpm support Pike R. Alpha
find
42060000DC33000000000000000000001F0000000000000018
replace
42060000000000000000000000000000000000000000000000
SammlerG Sierra xcpm MSR Patch 4 / xcpm support Pike R. Alpha
find
E20000004C00000000000000000000000F040000000000000500001E
replace
E20000004C00000000000000000000000F040000000000000700007E
SammlerG Sierra xcpm MSR Patch 5 / xcpm support Pike R. Alpha
[/color]
find
89D8C1E008B99901
replace
B800250000B99901 [ I use 25 (3700 Mhz) you can change accordly your OC clock]
(wrsmr fix to get CPU max) © okrasit
You can disable a couple of them if needed ;-)
yep another input
https://ark.intel.com/products/130046/Intel-Xeon-W-2175-Processor-19_25M-Cache-2_50-GHz">https://ark.intel.com/products/130046/I ... e-2_50-GHz">https://ark.intel.com/products/130046/Intel-Xeon-W-2175-Processor-19_25M-Cache-2_50-GHz
see your CPU specs
turbo for few cores is @4300 so CPU P states must be 43 and you have to see all in CPU PSTATES
your cpu has 14 cores / 28 Threads
this means you have to see in CPU C6 states all from 0 to 27..
when you see this situation without any hole..you are gold (technically speaking) :) in Italian way is simple to figure out this technically speaking..I don't know in English if it is the same :)
Thank's again fabiosun I will elaborate a little bit further with this C3 states stuff and report back to you.
Have a nice Saturday evening emoticon_festa
Added in 4 minutes 45 seconds:
fabiosun!
Could you provide the link to this your old thread about C3 states?
Ok. What you telling me is that max turbo frequency is 4.30 GHz = 43 P-states
and according to my AppleInteInfo I can se 27 CPU C6-Cores = 28 cores (0 - 27)
Added in 5 minutes 18 seconds:
"fabiosun" post_id="12188" time="1534603295" user_id="56">
check your PM
Thank's empticons_thu
ideal condition
CPU C6-Cores [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 ]
CPU P-States [ 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 (33) 34 35 36 37 38 39 40 41 42 43 ]
run 4 times Cinebenchz
for cpu and graphic with appleintelinfo terminal executed
also during test run Intel power gadgets
and post here image of these datas for both fakecpuid togheter complete appleintelinfo output (you have to run command in termal many times (sorry if you know this)
you have to test for about 15/20 minutes...
"fabiosun" post_id="12208" time="1534609107" user_id="56">
Here you go.
In 0x0506E4 CPU P-States 36 38 and 42 is missing.
In 0x040670 no CPU P-States is missing.
Archive.zip
Ciao @obus
IPG graphics are pretty similar
You should do also 3 test if you can
Geekbench (CPU and GPU) in free version only OpenCL is available and it is ok
then in cinebench do some test also for gpu (as I was asking before) and for cpu single core like you can see in my attachment
I am asking because I can't see in both IPG graphics higher freq than 3.3 or 3.4 I think
In some condition you should see some peak around 4.0 and more
however outpinfo show all states so your cpu scales well in both case (few missing states are irrelevant..they could come far in time during testing
Ha scritto dopo 7 secondi:
LINK_TEXT>
Ha scritto dopo 1 minuto 9 secondi:
then important other things..stability is the same?
temperature seems pretty identical in both cases
Ha scritto dopo 9 minuti 58 secondi:
LINK_TEXT>
Ha scritto dopo 4 minuti :
LINK_TEXT>
during single CPU and Graphic cinebench run
"fabiosun" post_id="12262" time="1534687092" user_id="56">
Ciao @obus
then
Max turbo frequency is 4.3 GHz but that never happened.
Could it have to be something with my FakeCPUID?
Use other software to check (Istat menu IE) and test with cinebench single core or Geekbench or cinebench graphics test
with all of this you will use less cores and frequency should bounce higher
  • 4 weeks later...
Hi again @fabiosun[/mention]
There is another guy on the InsanelyMac forum how bought
the same mobo as I and I invited him to this forum. I will wait for the official candidate release of Mojave before I take any further steps.
Everything is working stable on my rig now but I'm not capable to get turboboost over 3.5 or something like that.
If you have any news please inform me. empticons_thu empticons_thu
ciao Obus
you and yapan4 have to understand if your MSR0xe2 is really unlocked for all cores of your cpu
to do this task you can use @vit9696 tools
first of all
VirtualSmc.efi in driver64uefi
then delete your fakesmc and all kext related to it (sensors, acpi an so on)
put in kext/others
VirtualSMC.kext
SMCProcessor.kext
then put
https://github.com/acidanthera/AptioFixPkg/releases
Aptiofix..../tools/VerifyMsrE2.efi
inside clover/drivers64uefi
you should see some lines before clover bootmenu like this one
LINK_TEXT>
if you see all your cores and similar text
you have a really unlocked bios 🙂
Perfetto!
I will check that during the evening. I will report back as soon as possible.
I'm already using virtualSMC and it's working flawlessly on my computer (I don't need any information about fans) even if I know that yapan4 has some problems with the fan sensors.
What about SMCHelper-64.efi? should I leave that in drivers64efi? It's not compatible with vitualSMC.efi if I understand it right?
Salve!
this result is with no other kext in my efi/clover/others
only new bit Virtualsmc and smcprocessor
many things are missing but I think app developer have to adopt some modification to be fully compatible with new VirtualSMC era 🙂
LINK_TEXT>
Ha scritto dopo 1 minuto 39 secondi:
I am using only these ones in my system
LINK_TEXT>
