[Discussion] AMDFriend, for (almost) all of your library patching needs
Nyaomi
Try these possible fixes:
Change npm's default directory to a hidden directory in your home folder:
mkdir ~/.npm-global
npm config set prefix '~/.npm-global'
export PATH=~/.npm-global/bin:$PATH
source ~/.profile
And then try to normally issue the command:
npm install -g amdfriend
If this doesn't work try to issue the command with this syntax:
sudo npm install -g --unsafe-perm=true --allow-root amdfriend
before to have the chance to patch any app you want you have to install well the script
Devs has prepared an executable file which could help you
https://github.com/NyaomiDEV/AMDFriend/releases/tag/v1.0.2
download it
then
from terminal
xattr -c /Users/fabio/Downloads/amdfriend
and then
chmod +x /Users/fabio/Downloads/amdfriend
then you can try to patch photoshop
sudo /Users/fabio/Downloads/amdfriend --in-place --sign --directories /Applications/Adobe\ Photoshop\ 2023/Adobe\ Photoshop\ 2023.app
  • 4 months later...
in this latest Photoshop release , liquid filter, deep font and usual stuffs needed to patch for AMD users is gone away
Adaptive wide angle filter needs patch and AMDFriend did the job well again! 🙂
  • 4 months later...
  • 3 weeks later...
