OCB: LoadImage failed - Unsupported
JonyK
Hi, what are you trying to install? GT 1030e is supported up to H. Sierra
https://dortania.github.io/GPU-Buyers-Guide/modern-gpus/nvidia-gpu.html#pascal-series-gtx-10xx
The config.plist has several things to fix, I recommend you to use OCAT by following here
https://github.com/5T33Z0/OC-Little-Translated/blob/main/D_Updating_OpenCore/README.md
The SMBIOS is not correct you should use  iMac15,1 https://dortania.github.io/OpenCore-Install-Guide/config.plist/haswell.html#platforminfo  ( Generate a complete one )
14 hours ago, antuneddu said:
Привет, что ты пытаешься установить? GT 1030e поддерживается до H. Sierra
В config.plist есть несколько вещей, которые нужно исправить, я рекомендую вам использовать OCAT, следуя здесь
SMBIOS неверен, вы должны использовать iMac15,1 https://dortania.github.io/OpenCore-Install-Guide/config.plist/haswell.html#platforminfo   (Создайте полный)
I want to install High Sierra. Thanks for the answer now I will try to fix something
23 minutes ago, JonyK said:
Я хочу установить High Sierra. Спасибо за ответ, сейчас попробую что-нибудь исправить
I corrected the mistakes. Tell me if everything is correct now
config.zip
  • 7 months later...
5 minutes ago, MaherWaleed said:
Hello,
I'm trying to do the same installing High Sierra
Hardware:
Core i5 9600KF
GTX 1080
Motherboard Z390
Can anyone help me, this is the error I'm getting.config.rar
Could you post your entire EFI?
if greater than 5Mb use a service like MEGA or dropbox or similar
thank you
hello please can help me also
i have acer aspire s7-391 ivy bridge
opencore 0.8.5
i install macOS catalina successfully online methode
after end i get new choose macOS installer
first after opencore boot menu get error
after click on macOS installer stuck in apple logo 10 seconde and restart pc
opencore 0.8.5
https://mega.nz/file/FKl3CLoY#yRJJSg0teKGFDZQrhYfrs9TuwHBrFIPNRsQnAuCJHzA
if you like to try this is an updated EFI of yours
Please for bigger EFI use an external link
thank you
  • 7 months later...
  • 9 months later...
