Gigabyte TRX40 AORUS MASTER (rev. 1.0)
shrisha
13 minutes ago, shrisha said:
@fabiosun Oh God! I'm in trouble again 🙂 After update to 12.5 directly from 12.2.1 System is not booting anymore. Could you please help me to debug it?
sure
does it hang?
and If so where?
try to disconnect ethernet cable and see if it is the same
as latest resource post your EFI/ config plist
It is just reboot after 15 seconds of booting. Or if I enable verbose mode it is hang on random places.
To check if during update system got corrupted I did usb drive with install of Monterey and copy EFI from my system and it is the same
Edited by shrisha
Yes now it is 083. And there is some progress 🙂 Now it's not rebooting anymore but hang in a middle. Also USB installation is booted fully. And I tried to updgrade current system from it. And during copying files it's rebooted again.
On all my previous Hackintoshes I was using clover what do you thing if we try clover here insteadof OC? Is it to much work?
Yes exactly! 🙂 After like five reboots it is booted into old system and seems like everything is fine except now I'm standard user and my password is not accepting as admins by system. Why? Do you know how to fix it? WiFi adapter stopped working too.
Edited by shrisha
I have disabled many kext, you can try to put updated ones for your WIFI and bt
Mhh I do not think it is EFI related..I don't know
Ok I fixed. According to Apple docs after some big updates you might loose your admin privileges. Solution is to delete .AppleSetUpDone file from /var/db and go through system setup wizard again. Create new admin account and under that account give again to your original account admin rights. Then new account can be deleted.
Thank you so much, you save me again!
Very very very much appreciated!
11 minutes ago, fabiosun said:
remember to check also your MMIO whitelist with a 083 debug log (use OC debug version)
Ok, How do I do that? Honestly I'm very good at following if you just tell me what to do 🙂 But to go through whole research process is quite envolving for me.
28:131 00:007 OCABC: MMIO devirt 0xC7100000 (0x81 pages, 0x8000000000000001) skip 1
28:140 00:009 OCABC: MMIO devirt 0xCF180000 (0x81 pages, 0x8000000000000001) skip 1
28:148 00:007 OCABC: MMIO devirt 0xD7180000 (0x81 pages, 0x8000000000000001) skip 1
28:155 00:007 OCABC: MMIO devirt 0xD7300000 (0x100 pages, 0x8000000000000001) skip 1
28:163 00:007 OCABC: MMIO devirt 0xDF100000 (0x181 pages, 0x8000000000000001) skip 1
28:170 00:007 OCABC: MMIO devirt 0xFEA00000 (0x100 pages, 0x8000000000000001) skip 1
28:278 00:108 OCABC: MMIO devirt 0xFEC00000 (0x1 pages, 0x8000000000000001) skip 1
28:286 00:007 OCABC: MMIO devirt 0xFEC10000 (0x1 pages, 0x8000000000000001) skip 1
28:293 00:007 OCABC: MMIO devirt 0xFED00000 (0x1 pages, 0x8000000000000001) skip 1
28:300 00:007 OCABC: MMIO devirt 0xFED40000 (0x5 pages, 0x8000000000000001) skip 1
28:307 00:007 OCABC: MMIO devirt 0xFED80000 (0x10 pages, 0x8000000000000001) skip 1
28:314 00:007 OCABC: MMIO devirt 0xFEDC2000 (0xE pages, 0x8000000000000001) skip 1
28:322 00:007 OCABC: MMIO devirt 0xFEDD4000 (0x2 pages, 0x8000000000000001) skip 1
28:329 00:007 OCABC: MMIO devirt 0xFEE00000 (0x100 pages, 0x8000000000000001) skip 1
28:336 00:007 OCABC: MMIO devirt 0xFF000000 (0x1000 pages, 0x8000000000000001) skip 1
28:344 00:007 OCABC: MMIO devirt 0x2040000000 (0x10400 pages, 0x8000000000000001) skip 0
28:351 00:007 OCABC: MMIO devirt 0x5770000000 (0x10400 pages, 0x8000000000000001) skip 0
28:358 00:007 OCABC: MMIO devirt 0x8EA0000000 (0x10400 pages, 0x8000000000000001) skip 0
28:366 00:007 OCABC: MMIO devirt 0xC5D0000000 (0x10400 pages, 0x8000000000000001) skip 0
28:373 00:007 OCABC: MMIO devirt end, saved 1064960 KB
They are fine!
They are fine!
Ok great. Thank you so much!
Hello @fabiosun Sorry to bother you again. I tried first to find solution myself but unsuccessful so I'm here again with my problems 🙂
So, computer is booting up with Monterey with no problem the only thing which is bothers me it is that booting time is very long. Few minuter at list. So I check in verbose mode what is taking to boot it so long and I found that most of the booting time is taken by this error:
AppleUSB20HubPort: AppleUSBHostPort::disconnect: persistent enumeration failures
It's like hundreds lines running with it and in some point of time it boot it into desktop.
What do you think can be a problem?
Thank you.
