Gigabyte TRX40 AORUS MASTER (rev. 1.0)
shrisha
6 minutes ago, shrisha said:
Yes now it works! Thank you very very much.
So this is it? Or some fine tuning still required, possible?
check if GPU is working better or not
and then you can try to use again also AMDRyzenCPUPowerManagement.kext
and also you can try to put again verbose booting (-v option)
What about Bluetooth ?  Can I enable it too? Also can you please tell me how to hide OC log on a screen which shows before drives chooser?
Yes I think you can try to enable kext for bt
to avoid first oc opencore verbose Lines you have to use a non debug version
post if you want your efi without the kext to have a smaller zip or post your full efi in external link without attaching here
thanks
thanks
Yes bluetooth working now. And here is link to EFI https://mega.nz/file/sFJQkZhL#vMvz9_tmeiLBEcHV9UNSu-SeLawqCfIsFfrJ2C4oq5Q
Also OC not remember last drive to boot from.
Backup your working one and change only these attached
Now Opencore is a non debug 079 release
By the way
With GPU have you the same weirdness you had with Clover?
Archive 2.zip
ah sorry to fix your last drive used to boot
press control + return one time when you choose your booting drive in boot loader menu
By the way
No, GPU is works great now. Vega 64 is old card and I'm planing to get 6900XT if my trexintosh will stable enough to fully move to Mac. My Titan RTX is out from computer for now, laying next to me in crying 🙂
  • Cross Finger 1
I have had also a Nvidia rtx 3090 in my rig
If you use software which uses metal you will be very happy
Trexintosh is one of the best pc you can have now 🙂
I'm 3D artist. Autodesk Maya is my main app for a past 18 years. Main renderer is Vray but with 3970X speed in Arnold is practically identical to VrayGPU with Nvidia Optix. So I'm not that depend on Nvidia now.
Actually I'm on Fedora linux for past two years. Performance is really great compare to Windows. Same scene will render by Arnold in Windows for 20% slower then in Linux. And I checked Macos is in between but in Mac I have all Adobe apps now, thanks to your patches 🙂
One more thing, config.plist from your last EFI folder for me, non debug,  is clean from Platform info, UUID, serial number, etc. When I successfully boot with OC Maya licensing got broken.  I have to clean uninstall and reinstall Maya just now. So if I change config again will I have to do it all over again?
Edited by shrisha
9 minutes ago, fabiosun said:
@shrisha
new way to patch all infamous (for and cpu in OSX) apps is a gold metal @tomnic, I have learned his methods with his help and I was a beta tester 🙂
Oh! My gratitude to him then.
And one more thing 🙂  M.2 SSD (non NVME) is not recognized in Monterey. All together in my motherboard is 2 NVME and 2 SSD in M.2 form factor. NVME is recognized but SSD is not. Normal SATA HDD and SSD is recognized with no problem. Do you have any thoughts on that? Should I try SATA-unsupported.kext or CtlnaAHCIPort.kext
Edited by shrisha
I have not modified SMBIOS in last config posted
I do not know well the kind of sata controller of your motherboard
some motherboard needs of an additional kext for one on board controller
you have to test @shrisha
my MSI does not need of any additional kext for its fully functionality 🙂
20 minutes ago, fabiosun said:
mmmh maybe I have misunderstood your problem
SSD in M2 form?
a picture please and where do you connect them? in a regular M2 slot?
Yes regular M2 slot.  All drives are visible in Windows and Linux, Only macos is not seeing SATA M2 drive.
Edited by shrisha
mmh i don't know exactly but that kind of M2 SSD connector in picture (SSD 860 evo) should not be good for your motherboard M2 slot
but not sure @100%
but if you see them in windows and linux I am wrong for sure 🙂
but not sure @100%
Yes I see them in WIndows and Linux. Both NVME and SSD in M2 slots
This is from motherboard specifications:
Integrated in the CPU:
  1. 1 x M.2 connector (Socket 3, M key, type 2260/2280/22110 SATA and PCIe 4.0 x4/x2 SSD support) (M2M)
  2. 1 x M.2 connector (Socket 3, M key, type 2280 SATA and PCIe 4.0 x4/x2 SSD support) (M2Q)
Integrated in the Chipset:
  1. 1 x M.2 connector (Socket 3, M key, type 2280 SATA and PCIe 4.0 x4/x2 SSD support) (M2P)
  2. 8 x SATA 6Gb/s connectors
10 minutes ago, fabiosun said:
@shrishawhat do you see from terminal if you type:
diskutil list
/dev/disk0 (internal, physical):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      GUID_partition_scheme                        *1.0 TB     disk0
   1:                        EFI ⁨NO NAME⁩                 629.1 MB   disk0s1
   2:           Linux Filesystem ⁨⁩                        1.1 GB     disk0s2
   3:                 Linux Swap ⁨⁩                        34.4 GB    disk0s3
   4:           Linux Filesystem ⁨⁩                        988.1 GB   disk0s4
/dev/disk1 (internal, physical):
   0:      GUID_partition_scheme                        *250.1 GB   disk1
   1:                        EFI ⁨EFI⁩                     209.7 MB   disk1s1
   2:                 Apple_APFS ⁨Container disk4⁩         249.8 GB   disk1s2
/dev/disk2 (internal, physical):
   0:     FDisk_partition_scheme                        *2.0 TB     disk2
   1:               Windows_NTFS ⁨nitai⁩                   2.0 TB     disk2s1
/dev/disk3 (internal, physical):
   0:     FDisk_partition_scheme                        *2.0 TB     disk3
   1:               Windows_NTFS ⁨gaura⁩                   2.0 TB     disk3s1
/dev/disk4 (synthesized):
   0:      APFS Container Scheme -                      +249.8 GB   disk4
                                 Physical Store disk1s2
   1:                APFS Volume ⁨MacSSD - Data⁩           70.0 GB    disk4s1
   2:                APFS Volume ⁨Preboot⁩                 270.1 MB   disk4s2
   3:                APFS Volume ⁨Recovery⁩                1.1 GB     disk4s3
   4:                APFS Volume ⁨VM⁩                      1.1 MB     disk4s4
   5:                APFS Volume ⁨MacSSD⁩                  15.8 GB    disk4s5
   6:              APFS Snapshot ⁨com.apple.os.update-...⁩ 15.8 GB    disk4s5s1
/dev/disk5 (internal, physical):
   0:      GUID_partition_scheme                        *1.0 TB     disk5
   1:           Windows Recovery ⁨⁩                        554.7 MB   disk5s1
   2:                        EFI ⁨NO NAME⁩                 104.9 MB   disk5s2
   3:         Microsoft Reserved ⁨⁩                        16.8 MB    disk5s3
   4:       Microsoft Basic Data ⁨Win⁩                     1.0 TB     disk5s4
Seems like Disk1 and Disk4 is same device. Disk0 and Disk5 are NVME drives. Disk2 and Disk3 are normal HDDs.  I have one more M2 SATA drive which is not visible. And actually I have one more NVME drive but in adapter which is in PCIE X16 port but this third part chipset and I'm not expecting to be recognized by Macos.
Edited by shrisha
it should be your macOS disk (4) and its EFi partition(1)
PCIE X16 port adapter
I use an ASUS adapter for my 960 pro Samsung and it works fine
it boots also my windows 11 installed on it
And this is from linux:
Disk /dev/sda: 238.47 GiB, 256060514304 bytes, 500118192 sectors
Disk model: SanDisk SD7SN3Q2
Disklabel type: gpt
Disk identifier: F35ACEF5-FC24-5447-98AA-96872A5FA2D3
Device        Start       End   Sectors   Size Type
/dev/sda1      2048   1230847   1228800   600M EFI System
/dev/sda2   1230848   3327999   2097152     1G Linux filesystem
/dev/sda3   3328000  20105215  16777216     8G Linux swap
/dev/sda4  20105216 500117503 480012288 228.9G Linux filesystem
Disk /dev/sdb: 1.82 TiB, 2000397852160 bytes, 3907027055 sectors
Disk model: ST2000DL004 HD20
Disklabel type: dos
Disk identifier: 0x1268dbe6
Device     Boot Start        End    Sectors  Size Id Type
/dev/sdb1  *     2048 3907024895 3907022848  1.8T  7 HPFS/NTFS/exFAT
Disk /dev/sdc: 1.82 TiB, 2000397852160 bytes, 3907027055 sectors
Disklabel type: dos
Disk identifier: 0x34702152
/dev/sdc1        2048 3907024895 3907022848  1.8T  7 HPFS/NTFS/exFAT
Disk /dev/sdd: 232.89 GiB, 250059350016 bytes, 488397168 sectors
Disk model: Samsung SSD 850
Disklabel type: gpt
Disk identifier: 4B1A3CBB-9D1F-439C-9AA2-3D5C8506B031
/dev/sdd1      40    409639    409600   200M EFI System
/dev/sdd2  409640 488397127 487987488 232.7G Apple APFS
Disk /dev/sde: 465.92 GiB, 500277790720 bytes, 977105060 sectors
Disk model: APPLE SSD SM0512
Disklabel type: dos
Disk identifier: 0x396ba252
/dev/sde1        2048 977104895 977102848 465.9G  7 HPFS/NTFS/exFAT
Disk /dev/nvme0n1: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors
Disk model: SAMSUNG MZVLW1T0HMLH-000L7
Disklabel type: gpt
Disk identifier: 6AA2D2FE-28E9-44DC-9F5C-9D0918AB2F12
/dev/nvme0n1p1     2048    1230847    1228800   600M EFI System
/dev/nvme0n1p2  1230848    3327999    2097152     1G Linux filesystem
/dev/nvme0n1p3  3328000   70436863   67108864    32G Linux swap
/dev/nvme0n1p4 70436864 2000408575 1929971712 920.3G Linux filesystem
Disk /dev/nvme1n1: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors
Disklabel type: gpt
Disk identifier: 80EA2866-0EBE-48E0-95CE-3C50A2241C0B
/dev/nvme1n1p1    2048    1085439    1083392   529M Windows recovery environment
/dev/nvme1n1p2 1085440    1290239     204800   100M EFI System
/dev/nvme1n1p3 1290240    1323007      32768    16M Microsoft reserved
/dev/nvme1n1p4 1323008 2000408575 1999085568 953.2G Microsoft basic data
You can see SDA and SDE which is here in Linux but missing in Macos.
  • 5 months later...
