Monterey Supporta AMD r9 380?
Domehey
Ciao  direttamente da
https://dortania.github.io/GPU-Buyers-Guide/modern-gpus/amd-gpu.html
R7/R9
#Highest Supported OS: Current/Monterey (12)
#Initial Supported OS: Yosemite (10.10)
R7/R9 is also natively supported without too much issue, but we cannot guarantee the success of R5 and R7 cards due to few reports of success with them. Also, be wary that differing from the reference design of these cards has many more issues that require a lot of work to get them to run properly. Sapphire cards are your best bet. Also, the R9 280X/380X are hit or miss on compatibility.
Supported cards:
  • R9 Fury X
  • R9 Fury
  • R9 Nano
  • R9 390 (Fake ID needed)
  • R9 290X/390X
  • R9 290/390 (Fake ID needed)
  • R9 280X/380X (Hit or miss)
  • R9 280/380 (Fake ID needed)
  • R9 270X/370X
  • R7 270/370 (Fake ID needed)
  • R7 265
  • R7 260X/360X
  • R9 260/360 (Fake ID may be required depending on model)
  • R9 255
  • R7 250X
  • R7 250 (Fake ID needed)
  • R7 240 (Fake ID needed)
Needed kexts
Se è quella devi falsificare ID per farla riconoscere nativamente al s.o.
R7/R9
Supported cards:
  • R9 Fury X
  • R9 Fury
  • R9 Nano
  • R9 290X/390X
  • R9 270X/370X
  • R7 265
  • R7 260X/360X
  • R9 255
  • R7 250X
Needed kexts
Grazie mille per la risposta, sai indicarmi come falsificare l’ID?
Grazie  ancora
O crei a doc un ssdt.spoof seguendo la guida dortania...
O vai in devicepropierties e ti crei sempre un device ....tipo questo
461268934_Schermata2022-02-07alle22_25_11.thumb.png.330af766cb46946fa596ff2f07885b9b.png
scusa ma nei 2 file che hai postato non vedo nessun ssdt.spoof
Edited by Giaccaz
ma scusami , o son io che non lo visualizzo o sei tu che posti il config.plist sbagliato....non riesco a trovare in acpi la voce ssdt-gpu-spoof, mi posti la efi completa con la ssdt-gpu-spoof , per cortesia.
questa e quella che hai postato ora
1738903080_Schermata2022-02-07alle23_14_53.thumb.png.f6d7b699fe901b52b12562379998faa4.png
Edited by Giaccaz
Questa è la efi che sto utilizzando, funziona ma se faccio partire un video si frizza il pc e devo spegnerlo forzatamente
7 ore fa, fabiosun ha scritto:
In Big Sur ti andava?
nel caso prova a rimettere il file ssdt che usavi li
mi pare c’era uno spoof
Ciao, scusa ma ho appena finito di lavorare, ho provato ad inserire la tua efi ma si perde in un caricamento infinito e non si avvia...
Su bigsur funzionava tutto benissimo
Edited by Domehey
Monterey funziona bene, il problema è che se faccio partire un video crasha perchè non rileva la scheda video, come vedi da screen
7 ore fa, Giaccaz ha scritto:
prova , ripeto mi manca device id che trovi o su hackintools o facendo un ioreg.
quello che ho messo e uno che ho trovato in rete,non sono sicuro che sia giusto.
scusa ma su smbios cosa hai impostato ?
iMac o Macpro o altro? e un altra cosa mi fai un o screenshot della finestra relativa alla finestra relativa alla vga.
Stai usando safari o chrome per far partire i video?
In Bigsur funzionava tutto?
Mac Pro 6,1
Su BigSur funzionava tutto senza problemi e sia con Chrome che con Safari mi frizza appena parte un video da Netflix o simili, tieni conto che si frizza pure per aprire il sito di Spotify
Edited by Domehey
