Support Team Anto65 Posted February 16, 2022 Support Team Share Posted February 16, 2022 WI-FI ? MA NON HAI NESSUN KEXT PER IL WIFI 🤔 Link to comment Share on other sites More sharing options...
savana88 Posted February 16, 2022 Author Share Posted February 16, 2022 Non saprei , ho dovuto mettere la psw per collegarmi a internet 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted February 16, 2022 Supervisor Share Posted February 16, 2022 ma la torpedo ha il wifi? sembra avere due lan intel... https://it.msi.com/Motherboard/MAG-Z590-TORPEDO/Specification Link to comment Share on other sites More sharing options...
savana88 Posted February 16, 2022 Author Share Posted February 16, 2022 No , credo siano riferiti alle due porte Ethernet . Io come Wi-Fi ho una fenvi t919( venduta e ricomprata mannaggia a me 😅) Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted February 16, 2022 Supervisor Share Posted February 16, 2022 ahhhh e quella la vede senza nulla e' la stessa mia 1 Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted February 16, 2022 Support Team Share Posted February 16, 2022 aaaa allora yes ( ecco perche' senza kext ) che hai fatto hai riavviato nel frattempo ? Link to comment Share on other sites More sharing options...
savana88 Posted February 16, 2022 Author Share Posted February 16, 2022 No no è passato a 6h 50 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted February 16, 2022 Supervisor Share Posted February 16, 2022 vi vedo troppo ottimisti 😛 1 1 Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted February 16, 2022 Support Team Share Posted February 16, 2022 BE CON L INSTALLER PIENO AVREBBE FATTO A QUEST ORA ... CREDO Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted February 16, 2022 Supervisor Share Posted February 16, 2022 io infatti avrei già rifatto la penna con il full installer ma Savana88 e' moltooooo più' paziente di me 🙂 1 Link to comment Share on other sites More sharing options...
savana88 Posted February 16, 2022 Author Share Posted February 16, 2022 (edited) A dire la verità oggi sono molto calmo gli è andata bene E poi ragazzi c’è da dire che la mia linea non è che sia eccezionale Edited February 16, 2022 by savana88 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted February 16, 2022 Supervisor Share Posted February 16, 2022 non so che connessione hai..ma quei tempi non sono un segnale positivo perché' tutto vada a buon fine... Link to comment Share on other sites More sharing options...
savana88 Posted February 16, 2022 Author Share Posted February 16, 2022 Sono arrivato a pensare che quei tempi non sono i tempi reali , nel senso c’è scritto 4 h ma in realtà potrebbe essere 20 minuti , anche perché la barra di installazione è tutta caricata Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted February 16, 2022 Supervisor Share Posted February 16, 2022 ma il disco lavora? Link to comment Share on other sites More sharing options...
savana88 Posted February 16, 2022 Author Share Posted February 16, 2022 La luce della usb è fissa Link to comment Share on other sites More sharing options...
Giaccaz Posted February 16, 2022 Share Posted February 16, 2022 (edited) Avvicinati con una mazzetta vedrai che prende paura!! Edited February 16, 2022 by Giaccaz 1 Link to comment Share on other sites More sharing options...
savana88 Posted February 16, 2022 Author Share Posted February 16, 2022 Mi dice ora 1h e 30 , aspetto o rifaccio usb ? Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted February 16, 2022 Support Team Share Posted February 16, 2022 Forza il riavvio se riparte da capo ( se non vedi macintosh hd ) ... si , se hai modo di scaricare l installer completo e' meglio un paio di volte ho installato tramite recovery e' andata sempre a buon fine 🤷♂️ Link to comment Share on other sites More sharing options...
savana88 Posted February 16, 2022 Author Share Posted February 16, 2022 Ho rifatto il tutto con gibmacos . comunque erano 12 gb , se avessi aspettato era meglio 😅 Link to comment Share on other sites More sharing options...
savana88 Posted February 16, 2022 Author Share Posted February 16, 2022 Download fermo a 9 giga dei 12 totali 🤦 1 Link to comment Share on other sites More sharing options...
savana88 Posted February 17, 2022 Author Share Posted February 17, 2022 Ho appena provato a riscaricare ma niente , ad un certo punto si blocca il download . Soluzioni ? Link to comment Share on other sites More sharing options...
savana88 Posted February 17, 2022 Author Share Posted February 17, 2022 2 ore fa, savana88 ha scritto: Ho appena provato a riscaricare ma niente , ad un certo punto si blocca il download . Soluzioni ? Finalmente è andato tramite recovery ,ho rimesso la usb che avevo preparato 1 Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted February 17, 2022 Support Team Share Posted February 17, 2022 É natoooo 😂 1 1 Link to comment Share on other sites More sharing options...
savana88 Posted February 17, 2022 Author Share Posted February 17, 2022 Allora , non va ethernet e non è fluido , inoltre nel Finder non c'è il disco dove ho installato Monterey , ma ce n'è uno di nome untitled dove ci stanno le cartelle di Windows Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted February 17, 2022 Support Team Share Posted February 17, 2022 Non hai accelerazione grafica perche' hai avviato in vesa , cancella dal plist " -igfxvesa " ( puoi usare OCAT ti servira' per editare il config e mantenere aggiornato OC https://www.macos86.it/topic/5238-aggiornare -opencore-e-kexts-con-ocat/?tab=comments#comment-121408 ) in DeviceProperties aggiungi AAPL,ig-platform-id Data 00009B3E framebuffer-patch-enable Data 01000000 framebuffer-stolenmem Data 00003001 1 Link to comment Share on other sites More sharing options...
