Krisp AI 1.30.10 AMD fix + 1.31.22 update
tomnic
Just replace the main executable in /Applications/krisp.app/Contents/MacOS/krisp with the patched one. Forced the program to detect our AMD cpu as a Genuine Intel, no other tricks involved.
Then codesign again the executable:
sudo codesign --force --deep --sign - /Applications/krisp.app/Contents/MacOS/krisp
1573028864_Schermata2021-12-07alle22_38_35.thumb.png.c8532d0eba34af24cfe92f8b662a5335.png
krisp.zip
  • tomnic changed the title to Krisp AI 1.30.10 AMD fix
  • tomnic changed the title to Krisp AI 1.30.10 AMD fix + 1.31.22 update
