Adobe Photoshop 22.5.1 AMD fix
tomnic
Liquify example
1526961057_Schermata2021-11-30alle23_39_17.thumb.png.3dc25a491143a3bec3c63dd006376451.png
Adaptive Wide Angle example
1641367823_Schermata2021-11-30alle23_39_34.thumb.png.87ab9e576c7769f5302193362c1557b8.png
Pugetbench results
Object selection works, Neural filters work, Camera Raw works, Deepfont works, Pugetbench works... patching only the needed original libraries/plugins to make Photoshop think that it works on a genuine Intel CPU... no libfakeintel, no environmental variables involved.
Just replace libmkl_core.dylib into:
/Applications/Adobe Photoshop2021/Adobe Photoshop 2021.app/Contents/Frameworks
and "Adaptive Wide Angle" in:
/Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/PlugIns/Required/Filters/Adaptive Wide Angle.plugin/Contents/MacOS
libmkl_core.dylib.zip Adaptive Wide Angle.zip
  • Like 5
Works great as always 🙂
Just a clarification for users who have SIP enabled.
Libraries may need to be re-signed.
Just in case use this command:
sudo codesign --force --deep --sign - /patched library or patched plugin path and file
use drag and drop after  -
  • 4 weeks later...
Hello,
just run my first Puget Photoshop benchmark. First of all, NO crash, any. 🙂
Secondly, the following are my results:
1379435810_ScreenShot2022-01-04at22_22_08.thumb.jpg.95e27159e127e6570b771872a3e67821.jpg
They look a little bit odd, compared the other ones I see in the online database: nothing is above the 1500 pt line. I strongly guess it will not be validated.
At the end, I cannot understand how powerful is my system.
However, everything is running pretty fast and, most important, without any issue or crash, so far.
Enjoy the rest of the evening.
13 hours ago, Nighthawk99 said:
Hello,
A stable and compatible AMD Hackintosh, with bare metal, IS possible... people like you, @fabiosun and me are the living proofs. Keep on going!!!!
  • +1 2
2 hours ago, SonaVis said:
Hi,
anybody tested if it's safe to update Photoshop to 22.5.5 and use the 22.5.1 patches?
Thank you.
No it is not safe
if you update post relative library to be patched (in external link please)
  • 4 months later...
  • 3 months later...
  • 3 months later...
