Skylum Luminar AI AMD Hackintosh fix
Download from App Store Luminar AI
install it and to enjoy trial period also in Hackintosh with AMD CPU change these libs:
/Applications/Luminar AI.app/Contents/Frameworks/MPCore.framework/Versions/A/Frameworks/libtbb.dylib
/Applications/Luminar AI.app/Contents/Frameworks/MPCore.framework/Versions/A/Frameworks/libtbbmalloc.dylib
if you have SIP Enabled and you have problem then with code sign, execute from terminal:
sudo codesign --force --deep --sign - /Applications/Luminar\ AI.app
and enjoy your free trial days--mine is ended 🙂
It is not an app crack, it is only a method to have the app working on OSX with AMD Cpu
PS:
Thanks @tomnic
libtbb.dylib.zip libtbbmalloc.dylib.zip
Edited by fabiosun
  • fabiosun changed the title to Skylum Luminar AI AMD Hackintosh fix
  • 2 months later...
