Support Team Anto65 Posted November 10, 2021 Support Team Share Posted November 10, 2021 non sono puntini ma cosi - Link to comment Share on other sites More sharing options...
sobrakkato67 Posted November 10, 2021 Author Share Posted November 10, 2021 19 minutes ago, antuneddu said: non sono puntini ma cosi - messo trattini niente da fare ecco cosa esce... Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted November 10, 2021 Support Team Share Posted November 10, 2021 un solo spazio non hai usato piu' l app ? sudo /Applications/Install\ macOS\ Monterey.app/Contents/Resources/createinstallmedia --volume /Volumes/Usb Link to comment Share on other sites More sharing options...
sobrakkato67 Posted November 10, 2021 Author Share Posted November 10, 2021 30 minutes ago, antuneddu said: un solo spazio non hai usato piu' l app ? sudo /Applications/Install\ macOS\ Monterey.app/Contents/Resources/createinstallmedia --volume /Volumes/Usb no visto che mi avevi consigliato questo metodo ho interrotto comunque e andata a quasi finito grazie, poi installo il clover come da guida oppure posso prendere direttamente la cartella efi e la copio nella efi della usb? Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted November 10, 2021 Support Team Share Posted November 10, 2021 la seconda monti la usb e ci copi la cartella efi Link to comment Share on other sites More sharing options...
sobrakkato67 Posted November 11, 2021 Author Share Posted November 11, 2021 21 hours ago, antuneddu said: la seconda monti la usb e ci copi la cartella efi rimandato a domani oggi la salute scrichiola....😒 Link to comment Share on other sites More sharing options...
sobrakkato67 Posted November 12, 2021 Author Share Posted November 12, 2021 Buonasera ragazzi, rieccomi come mai monterey va in Stand by nonostante io abbia tolto la spunta in disattivazione dischi rigidi ovvero esce dalla disattivazione ma il monitor resta spento se stacco e riattacco HDMI ritorna lo schermo... Link to comment Share on other sites More sharing options...
sobrakkato67 Posted November 13, 2021 Author Share Posted November 13, 2021 16 hours ago, sobrakkato67 said: Buonasera ragazzi, rieccomi come mai monterey va in Stand by nonostante io abbia tolto la spunta in disattivazione dischi rigidi ovvero esce dalla disattivazione ma il monitor resta spento se stacco e riattacco HDMI ritorna lo schermo... mnon riesco a risolvere...qualche anima pia....😁 Link to comment Share on other sites More sharing options...
Contributor Eniac Posted November 13, 2021 Contributor Share Posted November 13, 2021 hai caricato un SSDT per il PM ? se non lo hai fatto vai in sezione download/acpi e scarica l'SSDT PM All e riprova con quello Link to comment Share on other sites More sharing options...
sobrakkato67 Posted November 13, 2021 Author Share Posted November 13, 2021 10 minutes ago, Eniac said: hai caricato un SSDT per il PM ? se non lo hai fatto vai in sezione download/acpi e scarica l'SSDT PM All e riprova con quello non trovo in Download SSDT PM All saro cecato....😁 altra cosa poi come va inserito? 1 minute ago, sobrakkato67 said: non trovo in Download SSDT PM All saro cecato....😁 altra cosa poi come va inserito? trovato, ora come lo utilizzo? Link to comment Share on other sites More sharing options...
sobrakkato67 Posted November 13, 2021 Author Share Posted November 13, 2021 5 minutes ago, sobrakkato67 said: non trovo in Download SSDT PM All saro cecato....😁 altra cosa poi come va inserito? trovato, ora come lo utilizzo? si lo trovato ma non so come va caricato...😬 leggevo che e molto piu utile per open core, e nella lista delle cpu non il Comet Lake puo andare lo stesso? Link to comment Share on other sites More sharing options...
Contributor Eniac Posted November 13, 2021 Contributor Share Posted November 13, 2021 l'SSDT va messo nella cartella ACPI e poi dichiarato nel config , questo per OC , Clover non lo seguo piu da un pezzo ma dovrebbe essere lo stesso piu o meno Link to comment Share on other sites More sharing options...
Contributor Eniac Posted November 13, 2021 Contributor Share Posted November 13, 2021 comunque se sposti lo slider su MAI non ti dovrebbe andare in stand-by Link to comment Share on other sites More sharing options...
sobrakkato67 Posted November 13, 2021 Author Share Posted November 13, 2021 9 minutes ago, Eniac said: comunque se sposti lo slider su MAI non ti dovrebbe andare in stand-by gia fatto va lo stesso stand-by dopo 10 minuti.... Link to comment Share on other sites More sharing options...
