Aggiornamento OC 0.7.3
Fasullo
E come si apre?
ok
Last login: Thu Sep 16 20:13:44 on ttys000
pallino@iMac ~ % /Users/pallino/Desktop/OpenCore/Utilities/ocvalidate/ocvalidate /Volumes/EFI/EFI/OC/Config.plist
OCS: Missing key Base, context <Patch>!
OCS: Missing key BaseSkip, context <Patch>!
OCS: Missing key SyncTableIds, context <Quirks>!
OCS: Missing key ForceBooterSignature, context <Quirks>!
OCS: Missing key ProvideCurrentCpuInfo, context <Quirks>!
OCS: Missing key CustomKernel, context <Scheme>!
OCS: Missing key Flavour, context <Entries>!
OCS: Missing key AllowToggleSip, context <Security>!
OCS: Missing key Flavour, context <Tools>!
OCS: No schema for AdviseWindows at 0 index, context <Generic>!
OCS: Missing key AdviseFeatures, context <Generic>!
OCS: Couldn't get array serialized at 0 index!
OCS: Couldn't get array serialized at 1 index!
OCS: Couldn't get array serialized at 2 index!
OCS: Couldn't get array serialized at 3 index!
OCS: Couldn't get array serialized at 4 index!
OCS: Couldn't get array serialized at 5 index!
OCS: Couldn't get array serialized at 6 index!
OCS: Couldn't get array serialized at 7 index!
OCS: Couldn't get array serialized at 8 index!
OCS: Couldn't get array serialized at 9 index!
OCS: Couldn't get array serialized at 10 index!
OCS: Couldn't get array serialized at 11 index!
OCS: Couldn't get array serialized at 12 index!
OCS: Couldn't get array serialized at 13 index!
OCS: Failed to calculate size of false field containing <empty> as type integer, context <GopPassThrough>!
OCS: No schema for AppleEvent at 3 index, context <ProtocolOverrides>!
OCS: Missing key AppleEg2Info, context <ProtocolOverrides>!
OCS: Missing key EnableVectorAcceleration, context <Quirks>!
OCS: Missing key ForceOcWriteFlash, context <Quirks>!
OCS: Missing key ForgeUefiSupport, context <Quirks>!
OCS: Missing key ReloadOptionRoms, context <Quirks>!
OCS: Missing key AppleInput, context <UEFI>!
Serialisation returns 37 errors!
Booter->Quirks->ProvideCustomSlide is enabled, but OpenRuntime.efi is not loaded at UEFI->Drivers!
Booter->Quirks->EnableWriteUnprotector is enabled, but OpenRuntime.efi is not loaded at UEFI->Drivers!
CheckBooter returns 2 errors!
UEFI->Quirks->RequestBootVarRouting is enabled, but OpenRuntime.efi is not loaded at UEFI->Drivers!
CheckUEFI returns 1 error!
Completed validating /Volumes/EFI/EFI/OC/Config.plist in 4 ms. Found 40 issues requiring attention.
😆  solo 40 warnings cos avevi la 0.6.8 ?
comunque con  plieditor apri il tuo plist e riporti la tua configurazione  nel Sample.plist.zip
oppure oltre alla sezione driver che ti ho menzionato cerca nel sample gli errori che ti ha evidenziato ocvalidate e li copi nel tuo plist alla stessa posizione
