[WIP] Photoshop, After Effects CC 2021, Premiere Pro CC 2021 15.4 AMD hackintosh fix
tomnic
Hey @tomnic and @fabiosun
Can we get this thread a little more organised as to where we are at. ie In your guide you mentioned you are doing are you including 2022 Adobe stuff as well as the old.
Im doing a reinstall on Monterey and I see fake intel is no longer required, and other info here and there.  Could you update the correct method in the first post of the thread for all to see with dated updates to help?
Can you list each app and version into respective sections in the first post, together with patch method and coding required.
When you've been away, to read everything again is time consuming 😉
All the best to you guys for the awesome work.
We have a WIP thread in Staff area it will be published as soon as possible!
Thank you for your patience 😉
