[WIP] Photoshop, After Effects CC 2021, Premiere Pro CC 2021 15.4 AMD hackintosh fix
tomnic
Ok @Driftwoodwoke up In me the desire to test new adobe beta
All apps tested (PS,PR,AE,ME) start fine with no need of any patches to boot (SIP enabled or disabled is the same)
all using problems are there and to have all tools working we have to patch
PS
Deep font in text tool
Object Selection tool
Liquify
PR
Warp Stabiliser
Morph Cut
Rolling shutter
AE
Camera tracking
Warp Stabiliser
and so on
With new @tomnic way to patch I have tested only PS beta and it works perfectly as usual
1767725444_Screenshot2021-10-24at08_24_18.thumb.png.b8709b409e456a2c0efa76ba595198ca.png50134435_Screenshot2021-10-24at08_25_44.png.aa71284ca828fd6240a1393427e46ff5.png
  • Cross Finger 1
I've been having trouble with these patches no matter what I do and what version of PS I use.
I tried again just now on a brand new install (aside from Brave and NordVPN/NordPass, Photoshop 22.5.1 is the only thing installed) and ran into the same error that I have all along irrespective of what version of PS I've tried to use. Running PugetBench to sanity check the install, it always hits the Iris Blur test and hangs. I'm not sure if it's hardware-specific or something else. Either way, I've included the crash log under the cut.
Date/Time:        2021-10-27 15:58:11.852 +1000
End time:         2021-10-27 15:59:43.015 +1000
OS Version:       macOS 11.6 (Build 20G165)
Architecture:     x86_64
Report Version:   32
Data Source:      Stackshots
Shared Cache:     1FB62A50-25C7-3F72-8054-A70CD3CA5953 slid base address 0x7fff2010e000, slide 0x10e000
Command:          Adobe Photoshop 2021
Path:             /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/MacOS/Adobe Photoshop 2021
Identifier:       com.adobe.Photoshop
Version:          22.5.1 (22.5.1)
Parent:           launchd [1]
PID:              2637
Time Since Fork:  331s
Event:            hang
Duration:         91.16s
Duration Sampled: 1.10s (process was unresponsive for 90 seconds before sampling)
Steps:            11 (100ms sampling interval)
Hardware model:   MacPro7,1
Active cpus:      16
Boot args:        agdpmod=ignore chunklist-security-epoch=0 -chunklist-no-rev2-dev
Time Awake Since Boot: 1574s
Time Since Wake:  n/a (machine hasn't slept)
Timeline format: stacks are sorted chronologically
Use -i and -heavy to re-report with count sorting
Heaviest stack for the main thread of the target process:
  10  mkl_serv_exit + 24 (Adaptive Wide Angle + 666712) [0x67b45ac58]
  10  exit + 53 (libsystem_c.dylib + 372752) [0x7fff2034c010]
  10  __cxa_finalize_ranges + 316 (libsystem_c.dylib + 372005) [0x7fff2034bd25]
  10  ??? (Camera Raw + 13211719) [0x17c562847]
  10  ??? (Camera Raw + 13260916) [0x17c56e874]
  10  ??? (Camera Raw + 10091221) [0x17c268ad5]
  10  __ulock_wait + 10 (libsystem_kernel.dylib + 10734) [0x7fff203e89ee]
 *10  ??? (kernel + 6575136) [0xffffff8000855420]
Process:          Adobe Photoshop 2021 (Photoshop) [2637]
UUID:             ABD52CA8-A36D-3767-898A-824CC6574F28
App Version:      22.5.1
Build Version:    22.5.1
Parent:           launchd [1]
UID:              501
Footprint:        18.29 GB
Num samples:      11 (1-11)
CPU Time:         0.026s
Note:             Suspended for 1 sample
Note:             Terminated (zombie) for 1 sample
Note:             Unresponsive for 90 seconds before sampling
Note:             3 idle work queue threads omitted
  Thread 0x7df4    DispatchQueue "com.apple.main-thread"(1),none    11 samples (1-11)    priority 47-80 (base 31-47)    cpu time <0.001s
  <DispatchQueue "com.apple.main-thread"(1), process frontmost, thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [157], IO tier 0, priority 47 (47)>
  10  mkl_serv_exit + 24 (Adaptive Wide Angle + 666712) [0x67b45ac58] 1-10
    10  exit + 53 (libsystem_c.dylib + 372752) [0x7fff2034c010] 1-10
      10  __cxa_finalize_ranges + 316 (libsystem_c.dylib + 372005) [0x7fff2034bd25] 1-10
        10  ??? (Camera Raw + 13211719) [0x17c562847] 1-10
          10  ??? (Camera Raw + 13260916) [0x17c56e874] 1-10
            10  ??? (Camera Raw + 10091221) [0x17c268ad5] 1-10
              10  __ulock_wait + 10 (libsystem_kernel.dylib + 10734) [0x7fff203e89ee] 1-10
               *10  ??? (kernel + 6575136) [0xffffff8000855420] (blocked by turnstile waiting for Adobe Photoshop 2021 (Photoshop) [2637] thread 0x83f6) 1-10
  <DispatchQueue none, thread QoS unspecified, priority 80 (31)>
  1   <truncated backtrace> 11
   *1   return_from_trap + 203 (kernel + 137723) [0xffffff80002319fb] 11
     *1   ast_taken_user + 256 (kernel + 476272) [0xffffff8000284470] 11
       *1   bsd_ast + 899 (kernel + 6421523) [0xffffff800082fc13] 11
         *1   postsig_locked + 1059 (kernel + 6420531) [0xffffff800082f833] 11
           *1   exit_with_reason + 488 (kernel + 6298728) [0xffffff8000811c68] 11
             *1   task_terminate_internal + 250 (kernel + 724202) [0xffffff80002c0cea] 11
               *1   thread_terminate_internal + 343 (kernel + 791783) [0xffffff80002d14e7] 11
                 *1   ipc_thread_port_unpin + 69 (kernel + 574565) [0xffffff800029c465] 11
                   *1   ??? (kernel + 908649) [0xffffff80002edd69] (suspended, running) 11
  Thread 0x7e44    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [157], IO tier 0>
  10  thread_start + 15 (libsystem_pthread.dylib + 9283) [0x7fff20418443] 1-10
    10  _pthread_start + 224 (libsystem_pthread.dylib + 26876) [0x7fff2041c8fc] 1-10
      10  ??? (Adobe Photoshop 2021 + 43979800) [0x10593d418] 1-10
        10  ??? (Adobe Photoshop 2021 + 43979451) [0x10593d2bb] 1-10
          10  ??? (Adobe Photoshop 2021 + 43981755) [0x10593dbbb] 1-10
            10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 15582) [0x7fff203e9cde] 1-10
             *10  psynch_cvcontinue + 0 (pthread + 21269) [0xffffff80035ea315] 1-10
  <thread QoS unspecified>
   *1   ??? (kernel + 776144) [0xffffff80002cd7d0] (suspended) 11
  Thread 0x7e6f    Thread name "com.adobe.ngl-RecurringLogPosting-0x70000ac95000"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
      10  ??? (Adobe Photoshop 2021 + 76444126) [0x1078331de] 1-10
        10  ??? (Adobe Photoshop 2021 + 76443578) [0x107832fba] 1-10
          10  ??? (Adobe Photoshop 2021 + 76443751) [0x107833067] 1-10
            10  ??? (Adobe Photoshop 2021 + 76361006) [0x10781ed2e] 1-10
              10  std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93 (libc++.1.dylib + 48643) [0x7fff20385e03] 1-10
  Thread 0x7e72    Thread name "VulcanMsgRecv"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
      10  ??? (VulcanMessage5.dylib + 521225) [0x119cd5409] 1-10
        10  ??? (VulcanMessage5.dylib + 397601) [0x119cb7121] 1-10
          10  ??? (VulcanMessage5.dylib + 58388) [0x119c64414] 1-10
            10  ??? (VulcanMessage5.dylib + 331229) [0x119ca6ddd] 1-10
              10  ??? (VulcanMessage5.dylib + 331457) [0x119ca6ec1] 1-10
                10  ??? (VulcanMessage5.dylib + 332475) [0x119ca72bb] 1-10
                  10  ??? (VulcanMessage5.dylib + 307593) [0x119ca1189] 1-10
                    10  ??? (VulcanMessage5.dylib + 308590) [0x119ca156e] 1-10
                      10  ??? (VulcanMessage5.dylib + 301487) [0x119c9f9af] 1-10
                        10  ??? (VulcanMessage5.dylib + 325949) [0x119ca593d] 1-10
                          10  ??? (VulcanMessage5.dylib + 493668) [0x119cce864] 1-10
                            10  __recvfrom + 10 (libsystem_kernel.dylib + 18426) [0x7fff203ea7fa] 1-10
                             *10  hndl_unix_scall64 + 22 (kernel + 139766) [0xffffff80002321f6] 1-10
                               *10  unix_syscall64 + 718 (kernel + 7533022) [0xffffff800093f1de] 1-10
                                 *10  recvfrom_nocancel + 277 (kernel + 6819349) [0xffffff8000890e15] 1-10
                                   *10  ??? (kernel + 6819738) [0xffffff8000890f9a] 1-10
                                     *10  soreceive + 2237 (kernel + 6748493) [0xffffff800087f94d] 1-10
                                       *10  sbwait + 226 (kernel + 6792690) [0xffffff800088a5f2] 1-10
                                         *10  ??? (kernel + 6426504) [0xffffff8000830f88] 1-10
                                           *10  lck_mtx_sleep + 104 (kernel + 591352) [0xffffff80002a05f8] 1-10
                                             *10  thread_block_reason + 175 (kernel + 655951) [0xffffff80002b024f] 1-10
                                               *10  ??? (kernel + 662194) [0xffffff80002b1ab2] 1-10
                                                 *10  machine_switch_context + 203 (kernel + 1764571) [0xffffff80003becdb] 1-10
  Thread 0x7e89    Thread name "com.apple.NSURLConnectionLoader"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
      10  __NSThread__start__ + 1068 (Foundation + 365623) [0x7fff211c7437] 1-10
        10  ??? (CFNetwork + 2360152) [0x7fff248e6358] 1-10
          10  CFRunLoopRunSpecific + 567 (CoreFoundation + 519376) [0x7fff20512cd0] 1-10
            10  __CFRunLoopRun + 1332 (CoreFoundation + 522443) [0x7fff205138cb] 1-10
              10  __CFRunLoopServiceMachPort + 316 (CoreFoundation + 528917) [0x7fff20515215] 1-10
                10  mach_msg_trap + 10 (libsystem_kernel.dylib + 4794) [0x7fff203e72ba] 1-10
                 *10  ipc_mqueue_receive_continue + 0 (kernel + 385344) [0xffffff800026e140] 1-10
  Thread 0x7e8f    11 samples (1-11)    priority 20-31 (base 20-31)    cpu time <0.001s
  <process frontmost, thread QoS utility (requested utility), process unclamped, process received importance donation from WindowServer [157], IO tier 1, priority 20 (20)>
      10  ??? (Adobe Photoshop 2021 + 90197799) [0x108550f27] 1-10
        10  ??? (Adobe Photoshop 2021 + 59373085) [0x1067eb61d] 1-10
          10  ??? (Adobe Photoshop 2021 + 59378139) [0x1067ec9db] 1-10
            10  std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 48498) [0x7fff20385d72] 1-10
  <thread QoS unspecified, IO tier 0, priority 31 (31)>
  Thread 0x7e91    Thread name "UXP Database Thread"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
      10  ??? (dynamic-torqnative + 781522) [0x116c99cd2] 1-10
        10  ??? (dynamic-torqnative + 766673) [0x116c962d1] 1-10
          10  ??? (dynamic-torqnative + 768924) [0x116c96b9c] 1-10
  Thread 0x7e92    Thread name "UXP PluginManager Thread"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7e94    Thread name "LibUV Loop Thread"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
      10  ??? (dynamic-torqnative + 18997283) [0x117df9023] 1-10
        10  ??? (dynamic-torqnative + 18996693) [0x117df8dd5] 1-10
          10  uv_run + 359 (dynamic-torqnative + 16791577) [0x117bde819] 1-10
            10  kevent + 10 (libsystem_kernel.dylib + 23626) [0x7fff203ebc4a] 1-10
             *10  ??? (kernel + 6218992) [0xffffff80007fe4f0] 1-10
  Thread 0x7e95    Thread name "Third Party - UXP JavaScript Thread"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7e96    Thread name "First Party - UXP JavaScript Thread"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
          10  ??? (dynamic-torqnative + 768886) [0x116c96b76] 1-10
            10  ??? (dynamic-torqnative + 965013) [0x116cc6995] 1-10
  Thread 0x7e97    Thread name "UI Worker 1"    11 samples (1-11)    priority 31-37 (base 31-37)    cpu time <0.001s
  <process frontmost, thread QoS user initiated (requested user initiated), process unclamped, process received importance donation from WindowServer [157], IO tier 0, priority 37 (37)>
      10  ??? (Adobe Photoshop 2021 + 22060014) [0x104455bee] 1-10
        10  ??? (Adobe Photoshop 2021 + 22053596) [0x1044542dc] 1-10
          10  ??? (Adobe Photoshop 2021 + 22054736) [0x104454750] 1-10
  <thread QoS unspecified, priority 31 (31)>
  Thread 0x7e98    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
      10  ??? (dynamic-torqnative + 19183943) [0x117e26947] 1-10
        10  ??? (dynamic-torqnative + 19220352) [0x117e2f780] 1-10
          10  ??? (dynamic-torqnative + 19222852) [0x117e30144] 1-10
  Thread 0x7e99    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7e9a    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7e9b    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7e9c    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7e9d    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7e9e    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7e9f    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7ea0    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7ea1    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7ea2    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7ea3    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7ea4    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7ea5    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7ea6    Thread name "V8 DefaultWorke"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7eaf    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
      10  ??? (libtbb.dylib + 95577) [0x110364559] 1-10
        10  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4854) [0x7fff203e72f6] 1-10
         *10  semaphore_wait_continue + 0 (kernel + 705616) [0xffffff80002bc450] 1-10
  Thread 0x7eb0    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7eb1    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7eb2    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7eb3    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7eb4    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7eb5    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7eb6    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7eb7    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7eb8    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7eb9    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7eba    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7ebb    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
   *1   call_continuation + 35 (kernel + 135475) [0xffffff8000231133] 11
     *1   ml_set_interrupts_enabled + 17 (kernel + 1756673) [0xffffff80003bce01] (suspended, running) 11
  Thread 0x7ebc    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7ebd    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
  Thread 0x7ec8    Thread name "UI Worker 2"    11 samples (1-11)    priority 31-37 (base 31-37)    cpu time <0.001s
  Thread 0x7ec9    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
      10  ??? (dynamic-torqnative + 16764912) [0x117bd7ff0] 1-10
        10  uv_cond_wait + 9 (dynamic-torqnative + 16832722) [0x117be88d2] 1-10
  Thread 0x7eca    11 samples (1-11)    priority 31 (base 31)
  11  thread_start + 15 (libsystem_pthread.dylib + 9283) [0x7fff20418443] 1-11
    11  _pthread_start + 224 (libsystem_pthread.dylib + 26876) [0x7fff2041c8fc] 1-11
      11  ??? (dynamic-torqnative + 16764912) [0x117bd7ff0] 1-11
        11  uv_cond_wait + 9 (dynamic-torqnative + 16832722) [0x117be88d2] 1-11
          11  __psynch_cvwait + 10 (libsystem_kernel.dylib + 15582) [0x7fff203e9cde] 1-11
           *1   psynch_cvcontinue + 0 (pthread + 21269) [0xffffff80035ea315] (suspended) 11
  Thread 0x7ecb    11 samples (1-11)    priority 31 (base 31)
  Thread 0x7ecc    11 samples (1-11)    priority 31 (base 31)
  Thread 0x7ed8    Thread name "com.adobe.ngl-RecurringProfileAndAuthStateCheck-0x700012549000"    11 samples (1-11)    priority 31 (base 31)
      11  ??? (Adobe Photoshop 2021 + 76444126) [0x1078331de] 1-11
        11  ??? (Adobe Photoshop 2021 + 76443578) [0x107832fba] 1-11
          11  ??? (Adobe Photoshop 2021 + 76443751) [0x107833067] 1-11
            11  ??? (Adobe Photoshop 2021 + 76372767) [0x107821b1f] 1-11
              11  std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93 (libc++.1.dylib + 48643) [0x7fff20385e03] 1-11
  Thread 0x7ed9    Thread name "com.adobe.ngl-AuthStatusFileWatcher-0x7000125cc000"    11 samples (1-11)    priority 31 (base 31)
            11  ??? (Adobe Photoshop 2021 + 76233779) [0x1077ffc33] 1-11
              11  ??? (Adobe Photoshop 2021 + 76801119) [0x10788a45f] 1-11
                11  CFRunLoopRun + 40 (CoreFoundation + 1070376) [0x7fff20599528] 1-11
                  11  CFRunLoopRunSpecific + 567 (CoreFoundation + 519376) [0x7fff20512cd0] 1-11
                    11  __CFRunLoopRun + 1332 (CoreFoundation + 522443) [0x7fff205138cb] 1-11
                      11  __CFRunLoopServiceMachPort + 316 (CoreFoundation + 528917) [0x7fff20515215] 1-11
                        11  mach_msg_trap + 10 (libsystem_kernel.dylib + 4794) [0x7fff203e72ba] 1-11
                         *1   ipc_mqueue_receive_continue + 0 (kernel + 385344) [0xffffff800026e140] (suspended) 11
  Thread 0x7efb    Thread name "BridgeTalk"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
      10  ScObjects::Thread::go(void*) + 151 (ScriptingSupport + 3577575) [0x16e1f66e7] 1-10
        10  ScObjects::BridgeTalkThread::run() + 290 (ScriptingSupport + 3467410) [0x16e1db892] 1-10
          10  ScObjects::Thread::wait(unsigned int) + 56 (ScriptingSupport + 3578680) [0x16e1f6b38] 1-10
            10  __semwait_signal + 10 (libsystem_kernel.dylib + 15282) [0x7fff203e9bb2] 1-10
   *1   semaphore_wait_continue + 0 (kernel + 705616) [0xffffff80002bc450] (suspended) 11
  Thread 0x7f00    Thread name "TaskSchedulerServiceThread"    11 samples (1-11)    priority 31 (base 31)
  <process frontmost, process unclamped, process received importance donation from WindowServer [157], IO tier 0>
      11  ??? (Chromium Embedded Framework + 39670887) [0x170e1d467] 1-11
        11  ??? (Chromium Embedded Framework + 39473942) [0x170ded316] 1-11
          11  ??? (Chromium Embedded Framework + 39399044) [0x170ddae84] 1-11
            11  ??? (Chromium Embedded Framework + 39185109) [0x170da6ad5] 1-11
              11  ??? (Chromium Embedded Framework + 39704510) [0x170e257be] 1-11
                11  ??? (Chromium Embedded Framework + 39708093) [0x170e265bd] 1-11
                  11  kevent + 10 (libsystem_kernel.dylib + 23626) [0x7fff203ebc4a] 1-11
                   *1   ??? (kernel + 6218992) [0xffffff80007fe4f0] (suspended) 11
  Thread 0x7f01    Thread name "TaskSchedulerForegroundWorker"    11 samples (1-11)    priority 31 (base 31)
        11  ??? (Chromium Embedded Framework + 39381556) [0x170dd6a34] 1-11
          11  ??? (Chromium Embedded Framework + 39382403) [0x170dd6d83] 1-11
            11  ??? (Chromium Embedded Framework + 39380216) [0x170dd64f8] 1-11
              11  ??? (Chromium Embedded Framework + 39277969) [0x170dbd591] 1-11
                11  ??? (Chromium Embedded Framework + 39277696) [0x170dbd480] 1-11
  Thread 0x7f02    Thread name "TaskSchedulerForegroundBlockingWorker"    11 samples (1-11)    priority 31 (base 31)
  Thread 0x7f03    Thread name "TaskSchedulerBackgroundWorker"    11 samples (1-11)    priority 0-31 (base 0-31)
  <process frontmost, process unclamped, process received importance donation from WindowServer [157], IO tier 0, priority 0 (0)>
        11  ??? (Chromium Embedded Framework + 39381412) [0x170dd69a4] 1-11
  <priority 31 (31)>
  Thread 0x7f05    Thread name "TaskSchedulerBackgroundBlockingWorker"    11 samples (1-11)    priority 0-31 (base 0-31)
  <priority 31 (31)>
  Thread 0x7f07    Thread name "Chrome_IOThread"    11 samples (1-11)    priority 31 (base 31)
          11  ??? (Chromium Embedded Framework + 22374980) [0x16fd9ea44] 1-11
  Thread 0x7f08    Thread name "NetworkConfigWatcher"    11 samples (1-11)    priority 31 (base 31)
            11  ??? (Chromium Embedded Framework + 39045607) [0x170d849e7] 1-11
              11  ??? (Chromium Embedded Framework + 39049856) [0x170d85a80] 1-11
                11  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 212 (Foundation + 394759) [0x7fff211ce607] 1-11
  Thread 0x7f09    Thread name "DnsConfigService"    11 samples (1-11)    priority 31 (base 31)
            11  ??? (Chromium Embedded Framework + 39704535) [0x170e257d7] 1-11
  Thread 0x7f0d    Thread name "CompositorTileWorker1/164107"    11 samples (1-11)    priority 31 (base 31)
        11  ??? (Chromium Embedded Framework + 39470964) [0x170dec774] 1-11
          11  ??? (Chromium Embedded Framework + 55959928) [0x171da6178] 1-11
            11  ??? (Chromium Embedded Framework + 39667413) [0x170e1c6d5] 1-11
  Thread 0x7f0e    Thread name "AudioThread"    11 samples (1-11)    priority 31 (base 31)
            11  ??? (Chromium Embedded Framework + 39045277) [0x170d8489d] 1-11
              11  ??? (Chromium Embedded Framework + 39277375) [0x170dbd33f] 1-11
  Thread 0x7f0f    Thread name "TaskSchedulerSingleThreadForegroundBlocking0"    11 samples (1-11)    priority 31 (base 31)
        11  ??? (Chromium Embedded Framework + 39381652) [0x170dd6a94] 1-11
            11  ??? (Chromium Embedded Framework + 39380202) [0x170dd64ea] 1-11
  Thread 0x7f12    Thread name "TaskSchedulerSingleThreadBackgroundBlocking1"    11 samples (1-11)    priority 0-31 (base 0-31)
        11  ??? (Chromium Embedded Framework + 39381508) [0x170dd6a04] 1-11
  <priority 31 (31)>
  Thread 0x7f13    Thread name "TaskSchedulerSingleThreadSharedBackgroundBlocking2"    11 samples (1-11)    priority 0-31 (base 0-31)
        11  ??? (Chromium Embedded Framework + 39381460) [0x170dd69d4] 1-11
          11  ??? (Chromium Embedded Framework + 39381794) [0x170dd6b22] 1-11
  <priority 31 (31)>
  Thread 0x7f14    Thread name "TaskSchedulerSingleThreadSharedForegroundBlocking3"    11 samples (1-11)    priority 31 (base 31)
        11  ??? (Chromium Embedded Framework + 39381604) [0x170dd6a64] 1-11
  Thread 0x7f15    Thread name "NetworkConfigWatcher"    11 samples (1-11)    priority 31 (base 31)
  Thread 0x7f16    Thread name "CacheThread_BlockFile"    11 samples (1-11)    priority 31 (base 31)
  Thread 0x7f46    Thread name "com.apple.NSEventThread"    11 samples (1-11)    priority 31-47 (base 31-47)    cpu time 0.014s
  <process frontmost, thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [157], IO tier 0, priority 47 (47)>
      10  _NSEventThread + 124 (AppKit + 1856058) [0x7fff22dcc23a] 1-10
          6   __CFRunLoopRun + 1332 (CoreFoundation + 522443) [0x7fff205138cb] 1-6
            6   __CFRunLoopServiceMachPort + 316 (CoreFoundation + 528917) [0x7fff20515215] 1-6
              6   mach_msg_trap + 10 (libsystem_kernel.dylib + 4794) [0x7fff203e72ba] 1-6
               *5   ipc_mqueue_receive_continue + 0 (kernel + 385344) [0xffffff800026e140] 1-5
               *1   return_from_trap + 203 (kernel + 137723) [0xffffff80002319fb] 6
                 *1   ast_taken_user + 96 (kernel + 476112) [0xffffff80002843d0] (running) 6
          1   __CFRunLoopRun + 2414 (CoreFoundation + 523525) [0x7fff20513d05] 7
            1   __CFRunLoopDoSource1 + 645 (CoreFoundation + 530101) [0x7fff205156b5] 7
              1   __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41 (CoreFoundation + 530390) [0x7fff205157d6] 7
                1   __CFMachPortPerform + 250 (CoreFoundation + 710948) [0x7fff20541924] 7
                  1   MessageHandler(__CFMachPort*, void*, long, void*) + 48 (HIToolbox + 254296) [0x7fff289ca158] 7
                    1   PullEventsFromWindowServerOnConnection(unsigned int, unsigned char, __CFMachPortBoost*) + 268 (HIToolbox + 254622) [0x7fff289ca29e] 7
                      1   SLEventCreateNextEvent + 9 (SkyLight + 1052181) [0x7fff24ce2e15] 7
                        1   SLSGetNextEventRecordInternal + 278 (SkyLight + 2797238) [0x7fff24e8ceb6] 7
                          1   CGSSnarfAndDispatchDatagrams + 169 (SkyLight + 44821) [0x7fff24becf15] 7
                            1   mach_msg_trap + 10 (libsystem_kernel.dylib + 4794) [0x7fff203e72ba] 7
                             *1   ipc_mqueue_receive_continue + 0 (kernel + 385344) [0xffffff800026e140] (blocked by turnstile waiting for WindowServer [157]) 7
          3   __CFRunLoopRun + 1332 (CoreFoundation + 522443) [0x7fff205138cb] 8-10
            3   __CFRunLoopServiceMachPort + 316 (CoreFoundation + 528917) [0x7fff20515215] 8-10
              3   mach_msg_trap + 10 (libsystem_kernel.dylib + 4794) [0x7fff203e72ba] 8-10
               *3   ipc_mqueue_receive_continue + 0 (kernel + 385344) [0xffffff800026e140] 8-10
  Thread 0x7f48    Thread name "TypeKitDownload"    11 samples (1-11)    priority 20-31 (base 20-31)
      11  ??? (Adobe Photoshop 2021 + 83962218) [0x107f5e96a] 1-11
        11  ??? (Adobe Photoshop 2021 + 83962516) [0x107f5ea94] 1-11
          11  ??? (Adobe Photoshop 2021 + 83958163) [0x107f5d993] 1-11
            11  std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 48498) [0x7fff20385d72] 1-11
  Thread 0x7f49    Thread name "TypeKitDownload"    11 samples (1-11)    priority 20-31 (base 20-31)
  Thread 0x7f4a    Thread name "TypeKitDownload"    11 samples (1-11)    priority 20-31 (base 20-31)
  Thread 0x7f4b    Thread name "TypeKitDownload"    11 samples (1-11)    priority 20-31 (base 20-31)
  Thread 0x7f4f    Thread name "TypeQuest"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
      10  ??? (Adobe Photoshop 2021 + 84065873) [0x107f77e51] 1-10
        1   ??? (Adobe Photoshop 2021 + 84051067) [0x107f7447b] 1
          1   std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > const&) + 73 (libc++.1.dylib + 272698) [0x7fff203bc93a] 1
            1   __semwait_signal + 10 (libsystem_kernel.dylib + 15282) [0x7fff203e9bb2] 1
             *1   semaphore_wait_continue + 0 (kernel + 705616) [0xffffff80002bc450] 1
        1   ??? (Adobe Photoshop 2021 + 84051103) [0x107f7449f] 2
          1   CFRunLoopRunSpecific + 567 (CoreFoundation + 519376) [0x7fff20512cd0] 2
            1   __CFRunLoopRun + 1332 (CoreFoundation + 522443) [0x7fff205138cb] 2
              1   __CFRunLoopServiceMachPort + 316 (CoreFoundation + 528917) [0x7fff20515215] 2
                1   mach_msg_trap + 10 (libsystem_kernel.dylib + 4794) [0x7fff203e72ba] 2
                 *1   ipc_mqueue_receive_continue + 0 (kernel + 385344) [0xffffff800026e140] 2
        1   ??? (Adobe Photoshop 2021 + 84051067) [0x107f7447b] 3
          1   std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > const&) + 73 (libc++.1.dylib + 272698) [0x7fff203bc93a] 3
            1   __semwait_signal + 10 (libsystem_kernel.dylib + 15282) [0x7fff203e9bb2] 3
             *1   semaphore_wait_continue + 0 (kernel + 705616) [0xffffff80002bc450] 3
        7   ??? (Adobe Photoshop 2021 + 84051103) [0x107f7449f] 4-10
          7   CFRunLoopRunSpecific + 567 (CoreFoundation + 519376) [0x7fff20512cd0] 4-10
            7   __CFRunLoopRun + 1332 (CoreFoundation + 522443) [0x7fff205138cb] 4-10
              7   __CFRunLoopServiceMachPort + 316 (CoreFoundation + 528917) [0x7fff20515215] 4-10
                7   mach_msg_trap + 10 (libsystem_kernel.dylib + 4794) [0x7fff203e72ba] 4-10
                 *7   ipc_mqueue_receive_continue + 0 (kernel + 385344) [0xffffff800026e140] 4-10
  Thread 0x7f50    Thread name "UxTech Queue ThreadController"    11 samples (1-11)    priority 20-31 (base 20-31)
  Thread 0x7f51    Thread name "UxTech Queue ThreadController"    11 samples (1-11)    priority 20-31 (base 20-31)
  Thread 0x7f52    Thread name "UxTech Queue ThreadController"    11 samples (1-11)    priority 20-31 (base 20-31)
  Thread 0x7f53    Thread name "UxTech Queue ThreadController"    11 samples (1-11)    priority 20-31 (base 20-31)
  Thread 0x7f54    Thread name "UxTech Queue ThreadController"    11 samples (1-11)    priority 20-31 (base 20-31)
  Thread 0x7f55    Thread name "UxTech Queue ThreadController"    11 samples (1-11)    priority 20-31 (base 20-31)
  Thread 0x7f56    Thread name "UxTech Queue ThreadController"    11 samples (1-11)    priority 20-31 (base 20-31)
  Thread 0x7f57    Thread name "UxTech Queue ThreadController"    11 samples (1-11)    priority 20-31 (base 20-31)
  Thread 0x7f5a    Thread name "General Background Service"    11 samples (1-11)    priority 20-31 (base 20-31)
      11  ??? (Adobe Photoshop 2021 + 22060014) [0x104455bee] 1-11
        11  ??? (Adobe Photoshop 2021 + 22053596) [0x1044542dc] 1-11
          11  ??? (Adobe Photoshop 2021 + 22054736) [0x104454750] 1-11
  Thread 0x7f6f    Thread name "ACPLSDKWorkerThread2"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
      11  ??? (Adobe Photoshop 2021 + 55109726) [0x1063da85e] 1-11
        11  ??? (Adobe Photoshop 2021 + 55105112) [0x1063d9658] 1-11
          11  std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > const&) + 73 (libc++.1.dylib + 272698) [0x7fff203bc93a] 1-11
            11  __semwait_signal + 10 (libsystem_kernel.dylib + 15282) [0x7fff203e9bb2] 1-11
  Thread 0x7f78    Thread name "UI Worker 3"    11 samples (1-11)    priority 31-37 (base 31-37)
  Thread 0x7f79    Thread name "Background DOM Loader Thread - UXP JavaScript Thread"    11 samples (1-11)    priority 31 (base 31)
      11  ??? (dynamic-torqnative + 781522) [0x116c99cd2] 1-11
        11  ??? (dynamic-torqnative + 766673) [0x116c962d1] 1-11
          11  ??? (dynamic-torqnative + 768924) [0x116c96b9c] 1-11
  Thread 0x7f81    Thread name "UI Worker 4"    11 samples (1-11)    priority 31-37 (base 31-37)
  Thread 0x7f82    Thread name "com.apple.CFStream.LegacyThread"    11 samples (1-11)    priority 31-47 (base 31-47)
      11  _legacyStreamRunLoop_workThread + 251 (CoreFoundation + 1028592) [0x7fff2058f1f0] 1-11
  Thread 0x7f8f    11 samples (1-11)    priority 31 (base 31)
      11  ??? (dynamic-torqnative + 2432228) [0x116e2cce4] 1-11
        11  ??? (dynamic-torqnative + 2415731) [0x116e28c73] 1-11
          11  ??? (dynamic-torqnative + 2415963) [0x116e28d5b] 1-11
            11  ??? (dynamic-torqnative + 2439036) [0x116e2e77c] 1-11
              11  ??? (dynamic-torqnative + 2474622) [0x116e3727e] 1-11
  Thread 0x7f90    11 samples (1-11)    priority 31 (base 31)
      11  ??? (dynamic-torqnative + 2375996) [0x116e1f13c] 1-11
            11  ??? (dynamic-torqnative + 2439098) [0x116e2e7ba] 1-11
  Thread 0x8054    Thread name "com.apple.CFSocket.private"    11 samples (1-11)    priority 31-47 (base 31-47)
      11  __select + 10 (libsystem_kernel.dylib + 38486) [0x7fff203ef656] 1-11
       *10  ??? (kernel + 6427040) [0xffffff80008311a0] 1-10
       *1   ??? (kernel + 6427040) [0xffffff80008311a0] (suspended) 11
  Thread 0x82f0    11 samples (1-11)    priority 31 (base 31)
      11  __NSThread__start__ + 1068 (Foundation + 365623) [0x7fff211c7437] 1-11
        11  -[NSConnection run] + 126 (Foundation + 1419762) [0x7fff212c89f2] 1-11
            11  __CFRunLoopRun + 2414 (CoreFoundation + 523525) [0x7fff20513d05] 1-11
              11  __CFRunLoopDoSource1 + 645 (CoreFoundation + 530101) [0x7fff205156b5] 1-11
                11  __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41 (CoreFoundation + 530390) [0x7fff205157d6] 1-11
                  11  __CFMachPortPerform + 288 (CoreFoundation + 710986) [0x7fff2054194a] 1-11
                    11  __NSFireMachPort + 242 (Foundation + 661357) [0x7fff2120f76d] 1-11
                      11  -[NSConnection dispatchWithComponents:] + 53 (Foundation + 1044925) [0x7fff2126d1bd] 1-11
                        11  -[NSConnection handlePortCoder:] + 1093 (Foundation + 1047373) [0x7fff2126db4d] 1-11
                          11  -[NSConnection handleRequest:sequence:] + 1332 (Foundation + 1051179) [0x7fff2126ea2b] 1-11
                            11  -[NSConnection dispatchInvocation:] + 150 (Foundation + 1059932) [0x7fff21270c5c] 1-11
                              11  -[NSInvocation invoke] + 305 (CoreFoundation + 410383) [0x7fff204f830f] 1-11
                                11  __invoking___ + 140 (CoreFoundation + 410732) [0x7fff204f846c] 1-11
                                  11  _CF_forwarding_prep_0 + 120 (CoreFoundation + 403816) [0x7fff204f6968] 1-11
                                    11  ___forwarding___ + 819 (CoreFoundation + 404776) [0x7fff204f6d28] 1-11
                                      11  -[NSInvocation invokeWithTarget:] + 70 (CoreFoundation + 605943) [0x7fff20527ef7] 1-11
                                            11  -[NSObject(NSThreadPerformAdditions) performSelectorOnMainThread:withObject:waitUntilDone:] + 124 (Foundation + 322724) [0x7fff211bcca4] 1-11
                                              11  -[NSObject(NSThreadPerformAdditions) performSelector:onThread:withObject:waitUntilDone:modes:] + 807 (Foundation + 323886) [0x7fff211bd12e] 1-11
  Thread 0x82f2    Thread name "CEPMonitorThread"    11 samples (1-11)    priority 31 (base 31)    cpu time <0.001s
        10  ??? (PlugPlugOwl + 866182) [0x11340f786] 1-10
          10  -[NSConcreteTask waitUntilExit] + 324 (Foundation + 983487) [0x7fff2125e1bf] 1-10
  Thread 0x83f6    Thread name "cr_scratch"    11 samples (1-11)    priority 31-47 (base 31-47)
  <process frontmost, thread QoS user interactive (requested default, promote user interactive), process unclamped, process received importance donation from WindowServer [157], IO tier 0, priority 47 (47)>
      11  ??? (Camera Raw + 10091617) [0x17c268c61] 1-11
        11  ??? (Camera Raw + 13222347) [0x17c5651cb] 1-11
  <thread QoS unspecified (promote unspecified), priority 31 (31)>
  Thread 0x877e    11 samples (1-11)    priority 31 (base 31)
      11  ??? (libtbb.dylib + 95577) [0x110364559] 1-11
        11  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4854) [0x7fff203e72f6] 1-11
  Thread 0x877f    11 samples (1-11)    priority 31 (base 31)
  Thread 0x8853    11 samples (1-11)    priority 31 (base 31)
  Thread 0x8854    11 samples (1-11)    priority 31 (base 31)
  Thread 0x8b01    Thread name "TaskSchedulerForegroundBlockingWorker"    11 samples (1-11)    priority 31 (base 31)
  Thread 0x8afb    DispatchQueue "CoreController.server-connection-workloop"(1760)    1 sample (7)    priority 31 (base 31)    cpu time 0.003s
  <DispatchQueue not seen for 6 samples, process frontmost, thread QoS default (requested default, workloop servicer override default), process unclamped, process received importance donation from WindowServer [157], IO tier 0>
  1  start_wqthread + 15 (libsystem_pthread.dylib + 9263) [0x7fff2041842f] 7
    1  _pthread_wqthread + 314 (libsystem_pthread.dylib + 13405) [0x7fff2041945d] 7
      1  _dispatch_workloop_worker_thread + 811 (libdispatch.dylib + 80909) [0x7fff20282c0d] 7
        1  _dispatch_workloop_invoke + 1784 (libdispatch.dylib + 45848) [0x7fff2027a318] 7
          1  _dispatch_mach_invoke + 484 (libdispatch.dylib + 112098) [0x7fff2028a5e2] 7
            1  _dispatch_lane_serial_drain + 263 (libdispatch.dylib + 38035) [0x7fff20278493] 7
              1  _dispatch_mach_msg_invoke + 444 (libdispatch.dylib + 109216) [0x7fff20289aa0] 7
                1  _dispatch_client_callout4 + 9 (libdispatch.dylib + 14502) [0x7fff202728a6] 7
                  1  _xpc_connection_mach_event + 938 (libxpc.dylib + 47771) [0x7fff20161a9b] 7
                    1  _xpc_connection_call_event_handler + 56 (libxpc.dylib + 52260) [0x7fff20162c24] 7
                      1  message_handler + 206 (Foundation + 139321) [0x7fff21190039] 7
                        1  -[NSXPCConnection _decodeAndInvokeMessageWithEvent:flags:] + 418 (Foundation + 435275) [0x7fff211d844b] 7
                          1  -[NSXPCDecoder _decodeMessageFromXPCObject:allowingSimpleMessageSend:outInvocation:outArguments:outArgumentsMaxCount:outMethodSignature:outSelector:interface:] + 33 (Foundation + 439825) [0x7fff211d9611] 7
                            1  -[NSXPCDecoder __decodeXPCObject:allowingSimpleMessageSend:outInvocation:outArguments:outArgumentsMaxCount:outMethodSignature:outSelector:isReply:replySelector:interface:] + 1390 (Foundation + 132022) [0x7fff2118e3b6] 7
                              1  _NSXPCSerializationDecodeInvocationObjectOnlyArgumentArray + 449 (Foundation + 440292) [0x7fff211d97e4] 7
                                1  -[NSXPCDecoder _decodeObjectOfClasses:atObject:] + 63 (Foundation + 137029) [0x7fff2118f745] 7
                                  1  _decodeObject + 1137 (Foundation + 2884422) [0x7fff2142e346] 7
                                    1  look_up_class + 70 (libobjc.A.dylib + 36426) [0x7fff202bce4a] 7
                                      1  getClassExceptSomeSwift(char const*) + 15 (libobjc.A.dylib + 116111) [0x7fff202d058f] 7
                                        1  getPreoptimizedClass + 365 (libobjc.A.dylib + 37176) [0x7fff202bd138] 7
                                          1  header_info::getHeaderInfoRW() + 92 (libobjc.A.dylib + 119100) [0x7fff202d113c] (running) 7
  Binary Images:
           0x102f4c000 -        0x10c0cffff  com.adobe.Photoshop 22.5.1 (22.5.1)                        <ABD52CA8-A36D-3767-898A-824CC6574F28>  /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/MacOS/Adobe Photoshop 2021
           0x11034d000 -        0x110370fff  libtbb.dylib (0)                                           <6847C745-6A55-3135-B251-BF03BBE525FB>  /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/Frameworks/libtbb.dylib
           0x11333c000 -        0x11367bfff  com.adobe.PlugPlugOwl 10.1.0.15 (10.1.0.15)                <4004B6FF-C20F-3C40-9C34-0CD7EA118B69>  /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
           0x116bdb000 -        0x1194befff  com.adobe.uxp.macos.alpaca.v8 local (local)                <BDC87EB3-1C9C-3593-969E-DA8C1BF9959B>  /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/Frameworks/dynamic-torqnative.framework/Versions/A/dynamic-torqnative
           0x119c56000 -        0x119d09fff  VulcanMessage5.dylib (0)                                   <D9692B38-8895-3064-91ED-968B50905575>  /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/Frameworks/VulcanMessage5.dylib
           0x16de8d000 -        0x16e4b8fff  com.adobe.PSAutomate 22.5 (22.5)                           <DBF8B6BE-3E3F-399D-97CF-6882F708A653>  /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/PlugIns/Required/Extensions/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
           0x16e848000 -        0x176151fff  org.chromium.ContentShell.framework 3.3626.1882.0 (1882.0) <0E0CF0DF-F3BD-3EA0-AEEB-F8F6EC8157D6>  /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/PlugIns/Required/Spaces/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
           0x17b8c9000 -        0x181cb0fff  com.adobe.CameraRaw 13.4 (872) (13.4f872)                  <98553940-6F37-304E-9BAD-5AC3F872BE01>  /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/MacOS/Camera Raw
           0x67b3b8000 -        0x67fadbfff  com.adobe.AdaptiveWideAngle 22.5.1 (22.5.1)                <B75A43A0-6C96-328B-9C70-40E088DCC2BD>  /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/PlugIns/Required/Filters/Adaptive Wide Angle.plugin_/Contents/MacOS/Adaptive Wide Angle
        0x7fff20156000 -     0x7fff2018bfff  libxpc.dylib (2038.120.1)                                  <FFFB49D7-2CA6-3E1F-AE4E-5697B19B7D76>  /usr/lib/system/libxpc.dylib
        0x7fff2026f000 -     0x7fff202b3fff  libdispatch.dylib (1271.120.2)                             <8144B0BD-90D2-3EAE-999F-AB0D14082088>  /usr/lib/system/libdispatch.dylib
        0x7fff202b4000 -     0x7fff202edfff  libobjc.A.dylib (824)                                      <4D23FEBB-63D4-3A22-B7AA-698B9FB66EE9>  /usr/lib/libobjc.A.dylib
        0x7fff202f1000 -     0x7fff20379fff  libsystem_c.dylib (1439.141.1)                             <3C273899-4CBE-32D5-BB31-7A449743204F>  /usr/lib/system/libsystem_c.dylib
        0x7fff2037a000 -     0x7fff203cffff  libc++.1.dylib (905.6)                                     <FD6DB1CB-B14B-3404-8BEB-B459C2F6C303>  /usr/lib/libc++.1.dylib
        0x7fff203e6000 -     0x7fff20415fff  libsystem_kernel.dylib (7195.141.6)                        <78289AAE-61B5-339F-A485-8819BC2388F2>  /usr/lib/system/libsystem_kernel.dylib
        0x7fff20416000 -     0x7fff20421fff  libsystem_pthread.dylib (454.120.2)                        <1268FF2D-A513-3B51-BA65-AF2FF5789DDB>  /usr/lib/system/libsystem_pthread.dylib
        0x7fff20494000 -     0x7fff20932fff  com.apple.CoreFoundation 6.9 (1778.101)                    <92C7892A-86A8-3AB3-9B5E-489B135EC424>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff2116e000 -     0x7fff214ccfff  com.apple.Foundation 6.9 (1778.101)                        <7B7FB88B-01D3-38CE-8029-837DB094C545>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff22c07000 -     0x7fff23952fff  com.apple.AppKit 6.9 (2022.60.128)                         <02EC69A0-D634-341B-BE3D-840F496F5814>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff246a6000 -     0x7fff24b44fff  com.apple.CFNetwork 1240.0.4 (1240.0.4)                    <E4BF9BFF-798B-33FF-B37D-6D8175CA708A>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff24be2000 -     0x7fff24f47fff  com.apple.SkyLight 1.600.0 (588.7)                         <5F88F814-A3DF-3446-8B35-F0CDD8C1B302>  /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
        0x7fff2898c000 -     0x7fff28c87fff  com.apple.HIToolbox 2.1.1 (1062)                           <DEF01A0C-8B9D-359E-9FE7-B15D551888DC>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
   *0xffffff8000210000 - 0xffffff8000c0ffff  kernel (7195.141.6)                                        <C2591F4E-EE82-33CC-8C59-DB81D9AD80DD>  /System/Library/Kernels/kernel
   *0xffffff80035e5000 - 0xffffff80035eefff  com.apple.kec.pthread 1.0 (1)                              <33C1DFBF-F57E-3D13-8D6A-650DC1D56CBD>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Kextstat:
Index Refs Address            Size       Wired      Name (Version) UUID <Linked Against>
    1  122 0                  0          0          com.apple.kpi.bsd (20.6.0) C2591F4E-EE82-33CC-8C59-DB81D9AD80DD <>
    2   15 0                  0          0          com.apple.kpi.dsep (20.6.0) C2591F4E-EE82-33CC-8C59-DB81D9AD80DD <>
    3  149 0                  0          0          com.apple.kpi.iokit (20.6.0) C2591F4E-EE82-33CC-8C59-DB81D9AD80DD <>
    4    0 0                  0          0          com.apple.kpi.kasan (20.6.0) C2591F4E-EE82-33CC-8C59-DB81D9AD80DD <>
    5  155 0                  0          0          com.apple.kpi.libkern (20.6.0) C2591F4E-EE82-33CC-8C59-DB81D9AD80DD <>
    6  133 0                  0          0          com.apple.kpi.mach (20.6.0) C2591F4E-EE82-33CC-8C59-DB81D9AD80DD <>
    7   86 0                  0          0          com.apple.kpi.private (20.6.0) C2591F4E-EE82-33CC-8C59-DB81D9AD80DD <>
    8   98 0                  0          0          com.apple.kpi.unsupported (20.6.0) C2591F4E-EE82-33CC-8C59-DB81D9AD80DD <>
    9    3 0xffffff800331a000 0xe000     0xe000     com.apple.kec.Libm (1) 96F1F14F-5867-35F8-95DF-231FAD2C999A <5>
   10   11 0xffffff8003549000 0x92000    0x92000    com.apple.kec.corecrypto (11.1) E38D30E6-600F-30A0-8E38-E3EC38B9D929 <8 7 6 5 3 1>
   11    0 0xffffff80035e5000 0x9000     0x9000     com.apple.kec.pthread (1) 33C1DFBF-F57E-3D13-8D6A-650DC1D56CBD <8 7 6 5 3 1>
   12    1 0xffffff80035fc000 0x3000     0x3000     com.apple.driver.watchdog (1) 4CFADD2A-613E-320D-AD14-9C9379E87CB7 <8 7 6 5 3 1>
   13   29 0xffffff8002844000 0x2000     0x2000     com.apple.iokit.IOACPIFamily (1.4) 59A305C2-E322-3EA6-B8DB-475512053CDE <8 7 5 3>
   14   41 0xffffff8002d6c000 0x29000    0x29000    com.apple.iokit.IOPCIFamily (2.9) 4E85D41F-6AD7-3C24-911C-A8B80B599F86 <8 7 6 5 3>
   15    9 0xffffff8001956000 0x19000    0x19000    com.apple.driver.AppleSMC (3.1.9) 41EE0F43-5968-345F-9A44-9C865EA40A7F <14 13 12 8 7 6 5 3 1>
   16    2 0xffffff800132b000 0x78000    0x78000    com.apple.driver.AppleACPIPlatform (6.1) 46FB6C93-6F17-3119-95FD-E555EFD68B91 <15 14 13 8 7 6 5 3 1>
   17    4 0xffffff8002e67000 0x2000     0x2000     com.apple.driver.IOSlaveProcessor (1) 96E68785-D479-3E40-BA9E-F533E715AD91 <5 3>
   18    3 0xffffff800193b000 0x11000    0x11000    com.apple.driver.AppleSEPManager (1.0.1) 4B4EDD44-B518-30D1-A0A5-CA177C305DAC <17 14 10 8 7 6 5 3 1>
   19    1 0xffffff800162e000 0x4000     0x4000     com.apple.driver.AppleBusPowerController (1.0) DE5AE2EA-D8C1-36ED-8DF9-EE255EE48756 <15 13 7 6 5 3>
   20    9 0xffffff8001aa6000 0x4000     0x4000     com.apple.driver.usb.AppleUSBCommon (1.0) 5B5CAB3F-3665-3803-A219-F173D273F101 <6 5 3 1>
   21    3 0xffffff8003185000 0x1000     0x1000     com.apple.driver.AppleUSBHostMergeProperties (1.2) 4CB11432-7941-3C8E-BF8D-B7B320E34C52 <5 3 1>
   22   19 0xffffff800308a000 0x8f000    0x8f000    com.apple.iokit.IOUSBHostFamily (1.2) 854E579F-B284-3221-B1FC-D4A0FDC1F056 <21 20 19 15 13 8 7 6 5 3 1>
   23    3 0xffffff8003304000 0xf000     0xf000     com.apple.driver.KernelRelayHost (1) 2676CF50-C7C6-38A3-BEBF-0DE10AEA8AC7 <22 6 5 3>
   24    1 0xffffff80016a3000 0x51000    0x51000    com.apple.driver.AppleCredentialManager (1.0) DBF199FD-00AC-3F68-B55E-BA7B9AA308B6 <23 18 17 10 8 7 6 5 3 1>
   25    2 0xffffff8001711000 0x6000     0x6000     com.apple.driver.AppleEffaceableStorage (1.0) 5B734F34-DF9F-3478-8365-8314846DDD3C <8 6 5 3 1>
   26    0 0xffffff800171b000 0x6000     0x6000     com.apple.driver.AppleFDEKeyStore (28.30) 136DECA6-E160-391F-AB0D-3D645C3C2C45 <25 10 8 7 6 5 3 1>
   27    0 0xffffff80017a6000 0x1d000    0x1d000    com.apple.driver.AppleIntelCPUPowerManagement (222.0.0) 8B50AF31-4BF1-3BF1-81BD-BA02CFE3DDAB <8 7 6 5 3 1>
   28    2 0xffffff8001c47000 0x7000     0x7000     com.apple.kext.CoreTrust (1) 66A04501-8B18-33C7-B7A7-95F0DAEE0EC9 <10 5>
   29    8 0xffffff80018c0000 0x16000    0x16000    com.apple.driver.AppleMobileFileIntegrity (1.0.5) A994AEFE-3919-310E-A2C9-405E864BCB7B <28 10 8 7 6 5 3 2 1>
   30    4 0xffffff8002da8000 0x14000    0x14000    com.apple.iokit.IOSCSIArchitectureModelFamily (436.140.1) 1D017356-4FE3-31D6-A99B-938742AB2C91 <7 6 5 3 1>
   31   12 0xffffff8002e6f000 0x12000    0x12000    com.apple.iokit.IOStorageFamily (2.1) 7C0E4949-640F-3D1D-97AF-030903A22663 <8 7 6 5 3 1>
   32    1 0xffffff8002dcd000 0xe000     0xe000     com.apple.iokit.IOSCSIBlockCommandsDevice (436.140.1) 31D397A0-78BC-39A9-9BAD-03F2D7F599DF <31 30 7 6 5 3 1>
   33    1 0xffffff80032e0000 0x1a000    0x1a000    com.apple.iokit.IOUSBMassStorageDriver (184.140.2) 9C356AA9-7A2B-35EC-8517-3AA8E8A12FA1 <31 30 22 14 7 6 5 3 1>
   34    1 0xffffff80019b2000 0x8000     0x8000     com.apple.driver.AppleUSBTDM (511.141.1) 6CDB609D-F0A2-3946-B997-CDD1F140FA2C <33 32 31 30 29 22 8 7 6 5 3 1>
   35    0 0xffffff800180a000 0x90000    0x90000    com.apple.driver.AppleKeyStore (2) 5648AD22-A65F-31F1-A994-DDE20D2669E8 <34 29 28 24 23 18 17 10 8 7 6 5 3 1>
   36    0 0xffffff8001977000 0x7000     0x7000     com.apple.driver.AppleSSE (1.0) 53EC6A25-5312-34C2-9048-BD2CDD52EED8 <23 18 17 8 6 5 3 1>
   37    1 0xffffff8001b6d000 0x7000     0x7000     com.apple.iokit.CoreAnalyticsFamily (1) F9C68CEA-A200-3BF1-96B0-17B5D58B5E32 <8 7 6 5 3 1>
   38    2 0xffffff80018bc000 0x3000     0x3000     com.apple.kext.AppleMatch (1.0.0d1) EAD07327-D5B8-36D8-B3CC-DBEE8E4EE295 <5 1>
   39    3 0xffffff800334c000 0x47000    0x47000    com.apple.security.sandbox (300.0) 1E5C48E7-0D4C-30DA-BFA4-C87B27353F0D <38 31 29 8 7 6 5 3 2 1>
   40    2 0xffffff8003343000 0x8000     0x8000     com.apple.security.quarantine (4) 7F58EC1B-37A0-34FF-ACA7-089BCEEC0305 <39 38 8 7 6 5 3 2 1>
   41    0 0xffffff8001c4f000 0x50000    0x50000    com.apple.iokit.EndpointSecurity (1) 6610AB2E-F555-3F6F-A905-2E64F433E13F <40 29 8 7 6 5 3 2 1>
   42    1 0xffffff800299f000 0x6000     0x6000     com.apple.iokit.IOBluetoothPacketLogger (8.0.5d7) 78BBB921-B83C-33DA-935B-916AEE422484 <7 6 5 3 1>
   43    7 0xffffff8002da3000 0x3000     0x3000     com.apple.iokit.IOReportFamily (47) 77F098F2-012A-32EF-BD19-8A0E7ADF46E9 <6 5 3>
   44    3 0xffffff80028b1000 0x9e000    0x9e000    com.apple.iokit.IOBluetoothFamily (8.0.5d7) 5AD42C13-C37E-3F3C-93A6-B5FC9B4B7D5D <43 42 22 13 8 7 6 5 3 1>
   45    0 0xffffff80029db000 0xc000     0xc000     com.apple.driver.DiskImages (493.0.0) 822EFCF5-4602-3872-9A9A-F28D49A07147 <31 8 7 6 5 3 1>
   46    0 0xffffff8002aac000 0x1000     0x1000     com.apple.iokit.IOKitRegistryCompatibility (1) 109660E3-43C8-3F57-8DAA-801B4D2FAEF5 <5 3>
   47   11 0xffffff8002ae0000 0x17000    0x17000    com.apple.iokit.IONetworkingFamily (3.4) 85A525E4-C60E-345C-B651-6266952AFCA5 <8 7 6 5 3 1>
   48    2 0xffffff8002fba000 0x1c000    0x1c000    com.apple.iokit.IOTimeSyncFamily (985.2) 65E1B8DA-D7E4-3F0E-8108-440507F8C0F7 <47 6 5 3 1>
   49    5 0                  0x2e000    0x2e000    as.vit9696.Lilu (1.5.6) 041A34BB-B5DF-303E-B95B-57F9A6E43922 <8 6 5 3 2 1>
   50    0 0                  0x80000    0x80000    as.vit9696.WhateverGreen (1.5.4) 38407940-D579-3501-AF74-1293088C3DD0 <49 14 8 6 5 3 2 1>
   51    0 0                  0x18a000   0x18a000   as.vit9696.AppleALC (1.6.5) C6E85CCF-EF94-3491-99AA-63AAEBB7B272 <49 14 8 6 5 3 1>
   52    0 0                  0xd000     0xd000     as.vit9696.RestrictEvents (1.0.5) 652DCD68-033F-3A3D-916F-A02DCF913176 <49 8 6 5 3 2 1>
   53    0 0                  0x20000    0x20000    wtf.spinach.AMDRyzenCPUPowerManagement (0.7) 10AE6854-47D8-3FE6-B1D3-66937EF615EF <49 14 9 8 6 5 3 2 1>
   54    0 0xffffff8001320000 0xa000     0xa000     com.apple.nke.applicationfirewall (311) CBBA825D-8A92-34FA-9A7E-5CA82B06F2D4 <8 7 6 5 3 1>
   55    1 0xffffff800177d000 0x11000    0x11000    com.apple.security.AppleImage4 (3.0.0) 94010577-1544-331F-97F2-28A99361745E <10 8 7 5 3 1>
   56    0 0xffffff80019ce000 0xe000     0xe000     com.apple.AppleSystemPolicy (2.0.0) F22D52AF-BA75-372F-BA22-3A12E32D8F73 <40 39 29 8 7 6 5 3 2 1>
   57    0 0xffffff80013ce000 0x2000     0x2000     com.apple.driver.AppleAPIC (1.7) DFCF092E-FBC8-32A1-B3DE-5C2F07C26D15 <14 5 3>
   58    0 0xffffff8001952000 0x3000     0x3000     com.apple.driver.AppleSMBIOS (2.1) 28EA8D67-47F7-3414-8092-5A0B5ED73117 <8 5 3>
   59    0 0xffffff8001921000 0x6000     0x6000     com.apple.driver.AppleRTC (2.0) 65713D4E-E60F-3223-A43F-89738516BFAA <13 8 6 5 3 1>
   60    5 0xffffff8002a1c000 0x5d000    0x5d000    com.apple.iokit.IOHIDFamily (2.0.0) 5E0196BC-18C3-3E59-8AF5-625F0DE6A839 <43 8 7 6 5 3 2 1>
   61    2 0xffffff8002e26000 0x1000     0x1000     com.apple.iokit.IOSMBusFamily (1.1) 410FB6C3-CC9F-31E8-8A00-7F9838775FDA <6 5 3>
   62    0 0xffffff80013b6000 0x6000     0x6000     com.apple.driver.AppleACPIEC (6.1) 20AC689E-2C06-3025-A726-F3540A25FD6E <61 60 43 16 13 8 7 6 5 3 1>
   63    0 0xffffff80013b1000 0x2000     0x2000     com.apple.driver.AppleACPIButtons (6.1) B7C341D5-D269-3C12-9B08-580F42DB6201 <60 43 16 13 8 7 6 5 3 1>
   64    0 0                  0x1a000    0x1a000    as.vit9696.VirtualSMC (1.2.7) 9DAADEEB-D155-3EEC-AFDF-2F05E221EA01 <49 13 8 6 5 3 1>
   65    0 0xffffff800174f000 0x2000     0x2000     com.apple.driver.AppleHPET (1.8) 02E9ED89-A6DA-3A35-B420-9D3A1D4C2FD0 <13 8 6 5 3>
   66    1 0xffffff80016fb000 0x2000     0x2000     com.apple.driver.AppleEFIRuntime (2.1) 585A3DB3-DEC0-34F1-B797-B37CAB66CCA0 <8 7 6 5 3>
   67    3 0xffffff80016fe000 0xa000     0xa000     com.apple.driver.AppleEFINVRAM (2.1) 4E1980E9-004D-36DF-A5D3-C536B34A9E7A <66 8 7 6 5 3 1>
   68    0 0xffffff8002aae000 0x2a000    0x2a000    com.apple.iokit.IONVMeFamily (2.1.0) 67F14708-951E-3E86-AA3E-864B4A39BA17 <67 43 31 29 14 8 7 6 5 3 1>
   69    1 0xffffff8003220000 0x4e000    0x4e000    com.apple.driver.usb.AppleUSBXHCI (1.2) 90680482-1DD4-3BFC-AD5A-452EB4D2E91D <22 20 13 8 7 6 5 3 1>
   70    0 0xffffff8003277000 0x2a000    0x2a000    com.apple.driver.usb.AppleUSBXHCIPCI (1.2) 58EE7C12-43C8-3940-8000-3469AB07DAD5 <69 22 20 14 13 8 7 6 5 3 1>
   71    1 0xffffff8003527000 0x17000    0x17000    com.apple.driver.corecapture (1.0.4) 3203EA3B-A580-3DA3-8E97-3BA664D604F7 <8 7 6 5 3 1>
   72    1 0xffffff8002d66000 0x5000     0x5000     com.apple.driver.mDNSOffloadUserClient (1.0.1b8) D4B89780-21D2-3499-8CC1-E92275BA0604 <47 5 3 1>
   73    2 0xffffff8002e37000 0x22000    0x22000    com.apple.iokit.IOSkywalkFamily (1) 08312F19-B6FD-39DA-B806-8419DD53EECE <72 47 8 7 6 5 3 1>
   74    1 0xffffff8001d13000 0x180000   0x180000   com.apple.iokit.IO80211Family (1200.12.2b1) CAB76D43-3874-3057-9F2C-3C3FEA43B495 <73 71 47 29 10 8 7 6 5 3 1>
   75    0 0                  0xcf0000   0xcf0000   com.zxystd.AirportItlwm (2.0.0) 47A4963E-A822-3EF1-BFD7-CD036AD9FBED <74 47 14 6 5 3 1>
   76    0 0                  0x30000    0x30000    com.smalltree.driver.SmallTreeIntel82576 (1.3.0) FC2E800A-F5FF-3F86-AF25-58E04BEDFBC3 <47 14 6 5 3 1>
   77    0 0                  0x35000    0x35000    com.insanelymac.LucyRTL8125Ethernet (1.1.0) F0E3AD51-AFB8-33D6-8054-828B385D60B6 <47 14 6 5 3 1>
   78    2 0xffffff800284a000 0x10000    0x10000    com.apple.iokit.IOAHCIFamily (294.100.1) 71245C4E-5F5F-3112-B61A-930502C5013E <6 5 3 1>
   79    0 0xffffff80013be000 0xa000     0xa000     com.apple.driver.AppleAHCIPort (346.100.2) C9FB886F-0C3F-33B8-810D-1A2EE1607111 <78 14 6 5 3 1>
   80    0 0xffffff800285e000 0x18000    0x18000    com.apple.iokit.IOAHCIBlockStorage (332) 77AF340D-F425-34BB-AF2C-F46AEC299C5B <78 31 7 6 5 3 1>
   81    0 0xffffff8001b2c000 0x3000     0x3000     com.apple.driver.AppleXsanScheme (3) 014B3A1E-448E-3BC0-B15C-97A48EC477EB <31 6 5 3 1>
   82    2 0xffffff80033ac000 0x170000   0x170000   com.apple.filesystems.apfs (1677.141.2) C27BB72B-DD05-3577-AF93-ECB5FBF79B46 <67 55 37 31 25 10 8 7 6 5 3 2 1>
   83    0 0xffffff8003317000 0x1000     0x1000     com.apple.private.KextAudit (1.0) 0D24D61F-C9C1-3172-8C63-436693117626 <15 8 7 6 5 3>
   84    0 0xffffff8002fe3000 0x66000    0x66000    com.apple.iokit.IOUSBFamily (900.4.2) 046C4128-958C-3B22-A62C-EDB1883C124B <22 20 14 8 6 5 3 1>
   85    0 0xffffff8003187000 0x2000     0x2000     com.apple.driver.usb.AppleUSBHostPacketFilter (1.0) 38E1D0B3-8C3F-3519-B341-C24213EFDDDC <22 20 8 7 6 5 3 1>
   86    0 0xffffff8001723000 0x2000     0x2000     com.apple.AppleFSCompression.AppleFSCompressionTypeDataless (1.0.0d1) 9B8CA849-5B3F-3B31-99F4-602E349887F8 <8 7 5 3 2 1>
   87    0 0xffffff8001726000 0x11000    0x11000    com.apple.AppleFSCompression.AppleFSCompressionTypeZlib (1.0.0) 7DE4B579-A698-3D23-8593-2E93BCFFB19C <7 5 3 2 1>
   88    0 0xffffff8001b5f000 0xc000     0xc000     com.apple.BootCache (40) FA056BB2-DE01-3B9D-8B62-FC14F1B989F4 <8 7 6 5 3 1>
   89    1 0xffffff8001d10000 0x2000     0x2000     com.apple.filesystems.hfs.encodings.kext (1) 9CD178E1-CCAD-3576-B810-4A13E8AF75A5 <8 7 6 5 3 1>
   90    1 0xffffff8001ca5000 0x69000    0x69000    com.apple.filesystems.hfs.kext (556.100.11) 62F1593F-0819-358E-B4BF-642B5DADE813 <89 8 7 6 5 3 1>
   91    2 0xffffff8002e96000 0x1d000    0x1d000    com.apple.iokit.IOSurface (290.8.1) 3BE6ED95-B932-3F71-9DD5-4563CF4BD0DC <8 7 6 5 3 1>
   92    0 0xffffff8001609000 0x1000     0x1000     com.apple.driver.AppleBSDKextStarter (3) F21ED920-357C-3A83-8D3F-5265F57B96AD <5 3>
   93    0 0xffffff80035ef000 0xc000     0xc000     com.apple.filesystems.tmpfs (1) C23C381F-1B0E-39FC-9707-D866E11F5ADD <8 7 6 5 1>
   94    0 0xffffff800173a000 0x2000     0x2000     com.apple.driver.AppleFileSystemDriver (3.0.1) E5303F46-C8B3-3E32-AC2A-AE14631D6315 <31 5 3>
   95    0 0xffffff80031bd000 0x1000     0x1000     com.apple.driver.AppleUSBMergeNub (900.4.2) DE33F2B7-3A34-3C7E-BF87-125CDE1CC92F <21 5 3 1>
   96    0 0                  0x2bd000   0x2bd000   com.zxystd.IntelBluetoothFirmware (2.0.1) 179C77D4-214E-3A31-808E-1BC03491AC55 <22 6 5 3>
   97    2 0xffffff800297a000 0x5000     0x5000     com.apple.iokit.IOBluetoothHostControllerTransport (8.0.5d7) BF1CEB44-E56B-3189-99F3-B1123DC72B0A <44 22 14 13 8 7 6 5 3 1>
   98    1 0xffffff8002985000 0x18000    0x18000    com.apple.iokit.IOBluetoothHostControllerUSBTransport (8.0.5d7) 9F3D7B38-08DB-3B5D-8CB3-BAC7FBD66027 <97 44 22 14 13 8 7 6 5 3 1>
   99    0 0xffffff8002968000 0x7000     0x7000     com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport (8.0.5d7) 12804F4D-FE6D-3306-AC0A-741C7C496F7D <98 97 44 22 14 13 8 7 6 5 3>
  100    0 0xffffff800318a000 0x28000    0x28000    com.apple.driver.usb.AppleUSBHub (1.2) 8E7CD5A8-0D79-3A1C-A567-DBE9199854A0 <22 20 13 6 5 3 1>
  101    1 0xffffff8003180000 0x3000     0x3000     com.apple.driver.usb.AppleUSBHostCompositeDevice (1.2) 48B4CDB8-A192-3EA5-9C0C-17CA13C821CD <22 20 7 6 5 3 1>
  102    1 0xffffff8001aee000 0x2000     0x2000     com.apple.driver.usb.networking (5.0.0) 4ADA7DCB-4F59-3881-A2A7-9EA3CDE48592 <22 7 6 5 3 1>
  103    0 0xffffff8001aa2000 0x2000     0x2000     com.apple.driver.usb.cdc (5.0.0) 50BDBEBF-1380-36D3-9A82-78F6761245DC <102 101 22 6 5 3 1>
  104    0 0xffffff80032d4000 0xa000     0xa000     com.apple.driver.usb.IOUSBHostHIDDevice (1.2) F3DA87FB-63EA-364B-83C3-C546125EBDC8 <60 22 20 6 5 3 1>
  105    0 0xffffff8002e0b000 0x5000     0x5000     com.apple.iokit.SCSITaskUserClient (436.140.1) 26773182-7CBA-3D31-95F2-D01E8107894C <31 30 6 5 3 1>
  107    1 0xffffff7f9b1e0000 0x65000    0x65000    com.apple.plugin.IOgPTPPlugin (985.2) CE4197E1-9903-3762-B279-BB103BF85990 <73 60 48 47 9 7 6 5 3 1>
  108    2 0xffffff7f9bbf8000 0xa9000    0xa9000    com.apple.vecLib.kext (1.2.0) 18E8B36F-F257-326B-9B0A-E1EB9E013F0B <9 8 7 6 5 3>
  109    5 0xffffff7f9b037000 0x1e000    0x1e000    com.apple.iokit.IOAudioFamily (300.6.1) 4265A084-45BB-3E23-A17D-9F4E2E185D13 <108 6 5 3 1>
  110   16 0xffffff7f9b135000 0x2f000    0x2f000    com.apple.iokit.IOGraphicsFamily (585.1) 240F08CD-4BC4-3093-8832-0E899EFC14F4 <14 8 6 5 3 1>
  111    3 0xffffff7f9b17a000 0x9000     0x9000     com.apple.iokit.IONDRVSupport (585.1) AA328351-3091-3921-B6C8-7668F83CD7D7 <110 14 8 6 5 3>
  112    0 0xffffff7f998c5000 0x5f000    0x5f000    com.apple.driver.AppleGFXHDA (100.1.433) 75CB5308-A25A-3AE7-9F06-CD89C08D1A46 <111 110 109 14 8 7 6 5 3 1>
  113    0 0xffffff7f99851000 0x2000     0x2000     com.apple.driver.AppleFIVRDriver (4.1.0) 36F24891-3FC2-39F6-AECB-BF996A2F5C10 <5 3>
  114    2 0xffffff7f99b9f000 0x4000     0x4000     com.apple.iokit.IOHDAFamily (283.15) 786C0C1F-80CE-3C7C-B230-3D5FD2EA1A9C <6 5 3 1>
  115    1 0xffffff7f99a7f000 0x13000    0x13000    com.apple.driver.AppleHDAController (283.15) 74BDFE3E-80FE-3074-9D4F-7B186C89071B <114 110 109 14 8 7 6 5 3 1>
  116    6 0xffffff7f9b185000 0x4000     0x4000     com.apple.driver.IOPlatformPluginFamily (6.0.0d8) D3E11711-F1A5-3A2D-9309-40C69607E8A8 <13 8 7 6 5 3>
  117    1 0xffffff7f9b1ac000 0x14000    0x14000    com.apple.driver.X86PlatformPlugin (1.0.0) 369C396B-C54C-37DE-B987-F81B6BD07DCC <116 22 15 13 8 7 6 5 3 1>
  118    1 0xffffff7f9b19e000 0x9000     0x9000     com.apple.driver.IOPlatformPluginLegacy (1.0.0) BE55EC63-A076-3C2A-AF09-14C90900DF64 <116 13 8 7 6 5 3>
  119    0 0xffffff7f9b18b000 0xd000     0xd000     com.apple.driver.ACPI_SMC_PlatformPlugin (1.0.0) 16988972-A3F9-35D5-A0C8-AAA1E874E7D6 <118 116 15 14 13 8 7 6 5 3>
  120    0 0xffffff7f9ad2a000 0x1000     0x1000     com.apple.driver.AppleSMBusPCI (1.0.14d1) A538CDCE-162C-3B75-9D2D-70596BEDB2FC <14 6 5 3>
  121    6 0xffffff7f99950000 0x4000     0x4000     com.apple.AppleGraphicsDeviceControl (6.3.5) FB94A956-9AB7-3783-B7B9-5B126328606C <110 14 8 7 6 5 3 1>
  122    0 0xffffff7f99666000 0xcf000    0xcf000    com.apple.kext.AMDSupport (4.0.6) 0805A1AE-22E8-3F49-A1F3-CD73D88665B7 <121 110 14 13 8 6 5 3 1>
  123    0 0xffffff7f9a9b1000 0xe000     0xe000     com.apple.driver.AppleIntelMCEReporter (115) E219831D-792D-305C-A197-E2EFD905F812 <14 13 8 7 6 5 3 1>
  124    1 0xffffff7f9ad20000 0x6000     0x6000     com.apple.driver.AppleSMBusController (1.0.18d1) 7C776793-9706-3C5E-8F36-9C3C09C784F0 <61 14 13 6 5 3>
  125    0 0xffffff7f9accc000 0x2000     0x2000     com.apple.driver.AppleLPC (3.1) 7ADB7411-A194-3413-B20F-263056FCC3BE <116 14 6 5 3>
  126    1 0xffffff8002e6c000 0x2000     0x2000     com.apple.iokit.IOSlowAdaptiveClockingFamily (1.0.0) 287071B7-EDC8-3FD3-81AF-BC0DD03EC083 <8 7 6 5 3 1>
  127    0 0xffffff7f9acca000 0x1000     0x1000     com.apple.driver.AppleIntelSlowAdaptiveClocking (4.0.0) A12D950C-5653-31E5-9326-0270C17D8DAA <126 5 3>
  128    0 0xffffff7f99946000 0x7000     0x7000     com.apple.AppleGPUWrangler (6.3.5) C2E1F237-DF3D-348B-B6EC-C0FBA94A36B4 <121 110 14 8 7 6 5 3 1>
  129    0 0xffffff7f8eefa000 0x27b000   0x27b000   com.apple.kext.AMDRadeonX6000Framebuffer (4.0.6) 88ECFDC2-F2DA-3116-9AE3-5A090BA33B5B <121 110 14 13 8 6 5 3 1>
  130    0 0xffffff7f99838000 0xc000     0xc000     com.apple.driver.AppleDiskImages2 (1) 63AEE133-8D6A-35FC-A98B-FC797271784A <31 6 5 3 1>
  131    0 0xffffff7f99ba7000 0xb000     0xb000     com.apple.driver.AppleHV (1) F97332B3-443C-3E7A-8FB9-B7748AE90A66 <39 8 7 6 5 3 1>
  132    0 0xffffff7f9ae44000 0x3000     0x3000     com.apple.Dont_Steal_Mac_OS_X (7.0.0) 60D453CB-1AF4-3EA0-99A7-BB9DFC45E6A3 <15 10 8 5 3 1>
  133    1 0xffffff8002d52000 0x2000     0x2000     com.apple.iokit.IOEthernetAVBController (1.1.0) 73FD9FF8-2EAC-3A79-AE55-34B885AEA4F6 <47 6 5 3 1>
  134    0 0xffffff7f9af48000 0x13000    0x13000    com.apple.iokit.IOAVBFamily (940.4) A20A576B-05B4-31A0-9AE2-75682EB7F35C <133 107 48 47 7 6 5 3 1>
  135    1 0xffffff8002e28000 0x6000     0x6000     com.apple.iokit.IOSerialFamily (11) 0C483CB1-9945-3C51-9C44-E5D59D3CD756 <8 7 6 5 3 1>
  136    0 0xffffff7f9b065000 0x7000     0x7000     com.apple.iokit.IOBluetoothSerialManager (8.0.5d7) 694239E2-8A51-3B0D-B4A1-32F7BBCC46BD <135 8 6 5 3 1>
  137    0 0xffffff7f9b26d000 0x19000    0x19000    com.apple.driver.usb.AppleUSBUserHCI (1) 504345B6-5476-3A47-955D-35EAA00ADC55 <22 20 6 5 3 1>
  138    0 0xffffff7f9b28c000 0x3000     0x3000     com.apple.iokit.IOUserEthernet (1.0.1) B2BD812D-42A3-31D9-952D-C7F76A31897B <47 7 6 5 3 1>
  139    0 0xffffff7f9bb25000 0x8000     0x8000     com.apple.driver.pmtelemetry (1) C9E0C796-310E-3C1E-A707-AC251BB4CB4F <8 7 6 5 3 1>
  140    0 0xffffff7f99943000 0x2000     0x2000     com.apple.AGDCPluginDisplayMetrics (6.3.5) 0F23175E-0A66-3224-AB70-DB8A4A59E49E <121 8 7 6 5 3 1>
  141    1 0xffffff7f9993c000 0x1000     0x1000     com.apple.driver.AppleGraphicsControl (6.3.5) A92D2729-18A3-3F4A-A8DD-EF2BB1FEEC3B <8 6 5 3 1>
  142    0 0xffffff7f99958000 0xa000     0xa000     com.apple.driver.AppleGraphicsDevicePolicy (6.3.5) AB7601EF-82A1-3E70-81BF-4787660492F8 <141 121 110 14 13 8 7 6 5 3 1>
  143    0 0xffffff7f81030000 0x3000     0x3000     com.apple.kext.AMDRadeonServiceManager (4.0.6) E7B029BA-4F2E-38AE-9547-2554CD8F3E40 <14 5 3 1>
  144    0 0xffffff7f8f233000 0x3000     0x3000     com.apple.kext.AMDRadeonX6000HWServices (4.0.6) 668A0F6E-1CA4-3FB1-95FB-0D919C7FC19A <110 14 13 8 6 5 3 1>
  145    0 0xffffff7f97eb1000 0x44f000   0x44f000   com.apple.kext.AMDRadeonX6800HWLibs (1.0) FC75718D-14B4-3470-A998-81695BD3E99B <14 6 5 3 1>
  146    1 0xffffff7f9afb4000 0x6b000    0x6b000    com.apple.iokit.IOAcceleratorFamily2 (442.9) 065DAA9E-DE99-3C6D-A8D6-06BFD26CA1DC <110 91 43 29 14 8 7 6 5 3 1>
  147    0 0xffffff7f8ed86000 0x141000   0x141000   com.apple.kext.AMDRadeonX6000 (4.0.6) 409A1CEA-9544-302D-9635-7D20432866C8 <146 110 91 14 8 6 5 3 1>
  148    6 0xffffff7f9ba99000 0xd000     0xd000     com.apple.filesystems.exfat (1.4) 413062D7-47DC-328D-8EAF-032AEA887FFA <8 6 5 1>
  149    1 0xffffff7f9b8ca000 0xf000     0xf000     com.apple.kext.OSvKernDSPLib (529) 891E90F9-ABBD-3E11-A707-7BFDBB97AC2D <6 5>
  150    1 0xffffff7f99aac000 0xe3000    0xe3000    com.apple.driver.DspFuncLib (283.15) 6B31E982-BA12-3D52-9E9A-2E0E7CBE9324 <149 109 108 67 7 6 5 3 1>
  151    0 0xffffff7f999ca000 0x90000    0x90000    com.apple.driver.AppleHDA (283.15) F582765E-B263-3D0E-8DAC-737703CB61BA <150 115 114 111 110 109 7 6 5 3 1>
  152    0 0xffffff7f99a95000 0x1000     0x1000     com.apple.driver.AppleHDAHardwareConfigDriver (283.15) 2E3F7BC6-B0FD-3591-913C-D67F5E5C46E8 <5 3>
  153    0 0xffffff7f9accf000 0xb000     0xb000     com.apple.driver.AppleMCCSControl (1.14) 99CB19F6-A5C7-3286-87AC-0D64266CA3D1 <124 110 15 14 13 8 6 5 3 1>
  154    0 0xffffff7f9ae1b000 0x3000     0x3000     com.apple.driver.AppleUpstreamUserClient (3.6.8) FF6A28EE-22AA-32DA-9208-A8C44331AC24 <110 14 13 8 6 5 3 1>
  155    2 0xffffff7f9bac2000 0x62000    0x62000    com.apple.filesystems.ntfs (3.14.3) 04C1802C-8974-30EA-AE82-4FB8C046F173 <8 7 6 5 1>
  156    2 0xffffff7f9bbbd000 0x3000     0x3000     com.apple.kext.triggers (1.0) 324F119B-FE59-3498-AFEA-33D9A1F83F0A <8 7 6 5 3 1>
  157    0 0xffffff7f9ba7f000 0x9000     0x9000     com.apple.filesystems.autofs (3.0) 9FD42EC2-9E3D-32F4-9B22-393363D5BE3B <156 8 7 6 5 3 2 1>
  158    0 0xffffff7f998a7000 0x18000    0x18000    com.apple.fileutil (20.036.15) 8E167222-2BE5-3DAE-A6DC-A91C04CF89ED <6 5 3 2 1>
  159    1 0xffffff7f9b1c1000 0x6000     0x6000     com.apple.driver.X86PlatformShim (1.0.0) 60B69B4F-8B32-36E8-AC16-0ABB1F272279 <117 116 15 8 5 3>
  160    0 0xffffff7f9ad1c000 0x2000     0x2000     com.apple.driver.ApplePlatformEnabler (2.7.0d0) 1DC2EE00-5871-3009-926D-2A1AF461E4AF <8 6 5 3>
  161    0 0xffffff7f999a9000 0x1d000    0x1d000    com.apple.driver.AGPM (122.1) C7F30B02-EF61-3E69-88D7-22015139E166 <121 116 111 110 14 7 6 5 3 1>
  162    0 0xffffff7f9ae26000 0x3000     0x3000     com.apple.driver.AudioAUUC (1.70) 6493FE3C-D030-3A96-9805-BDE42C3E1182 <110 109 14 13 8 6 5 3 1>
  163    0 0xffffff7f9bb40000 0x78000    0x78000    com.apple.filesystems.smbfs (3.6.1) F427E00C-4EA9-34B8-8045-A124507C0723 <156 10 8 7 6 5 3 1>
----FPS Report Legend:-----
Raw Instantaneous FPS:
    30FPS delimiter:    '|'
    10FPS delimiter:    '+'
    1FPS delimiter:     '-'
Defer+Work Instantaneous FPS:                'X'
Work Instantaneous FPS:                      '^'
Equal Work and Defer+Work Instantaneous FPS: '*'
====Frame Rate Report:====
   Frame Length [SampleRange] WS Wait Length [SampleRange]   Defer Length [SampleRange] WS Work Length [SampleRange]      Frame Rate
        16.76 ms[      1    ]         0.00 ms[ No samples]        14.90 ms[      1    ]         1.87 ms[ No samples]       59.65 FPS|---------+---------+---------|---------+---------+---------*
        15.81 ms[ No samples]         0.17 ms[ No samples]        14.54 ms[ No samples]         1.09 ms[ No samples]       63.27 FPS|---------+---------+---------|---------+---------+---------*
        16.58 ms[ No samples]         1.13 ms[ No samples]        14.43 ms[ No samples]         1.02 ms[ No samples]       60.32 FPS|---------+---------+---------|---------+---------+---------*
        16.84 ms[ No samples]         5.44 ms[ No samples]        10.25 ms[ No samples]         1.16 ms[ No samples]       59.37 FPS|---------+---------+---------|---------+---------+---------*
        16.57 ms[ No samples]         7.16 ms[ No samples]         8.38 ms[ No samples]         1.03 ms[ No samples]       60.36 FPS|---------+---------+---------|---------+---------+---------*
        16.64 ms[ No samples]         0.11 ms[ No samples]        15.53 ms[ No samples]         0.99 ms[ No samples]       60.10 FPS|---------+---------+---------|---------+---------+---------*
        16.98 ms[      2    ]         1.32 ms[ No samples]        14.38 ms[      2    ]         1.28 ms[ No samples]       58.89 FPS|---------+---------+---------|---------+---------+---------*
        16.74 ms[ No samples]         3.59 ms[ No samples]        11.79 ms[ No samples]         1.36 ms[ No samples]       59.74 FPS|---------+---------+---------|---------+---------+---------*
        16.62 ms[ No samples]         4.74 ms[ No samples]        10.62 ms[ No samples]         1.26 ms[ No samples]       60.18 FPS|---------+---------+---------|---------+---------+---------*
        16.16 ms[ No samples]         7.61 ms[ No samples]         7.78 ms[ No samples]         0.77 ms[ No samples]       61.88 FPS|---------+---------+---------|---------+---------+---------*
WS Idle: 406.81ms
       417.06 ms[    3-6    ]       406.81 ms[    3-6    ]         9.57 ms[ No samples]         0.68 ms[ No samples]        2.40 FPS                                                            *
WS Idle: 107.25ms
       116.68 ms[      7    ]       107.25 ms[      7    ]         8.78 ms[ No samples]         0.65 ms[ No samples]        8.57 FPS                                                            *
        17.18 ms[      8    ]         2.88 ms[      8    ]        13.09 ms[ No samples]         1.21 ms[ No samples]       58.19 FPS|---------+---------+---------|---------+---------+-------- *
        16.39 ms[ No samples]         0.33 ms[ No samples]        15.17 ms[ No samples]         0.89 ms[ No samples]       61.00 FPS|---------+---------+---------|---------+---------+---------*
        17.56 ms[ No samples]         0.33 ms[ No samples]        15.45 ms[ No samples]         1.79 ms[ No samples]       56.94 FPS|---------+---------+---------|---------+---------+-------X ^
        16.08 ms[ No samples]         0.09 ms[ No samples]        14.76 ms[ No samples]         1.23 ms[ No samples]       62.19 FPS|---------+---------+---------|---------+---------+---------*
        16.68 ms[ No samples]         1.36 ms[ No samples]        14.09 ms[ No samples]         1.22 ms[ No samples]       59.96 FPS|---------+---------+---------|---------+---------+---------*
        16.75 ms[ No samples]         3.85 ms[ No samples]        11.61 ms[ No samples]         1.29 ms[ No samples]       59.69 FPS|---------+---------+---------|---------+---------+---------*
        16.48 ms[      9    ]         7.42 ms[      9    ]         7.97 ms[ No samples]         1.09 ms[ No samples]       60.67 FPS|---------+---------+---------|---------+---------+---------*
        16.79 ms[ No samples]         0.19 ms[ No samples]        15.40 ms[ No samples]         1.20 ms[ No samples]       59.57 FPS|---------+---------+---------|---------+---------+---------*
        17.22 ms[ No samples]         1.33 ms[ No samples]        14.21 ms[ No samples]         1.68 ms[ No samples]       58.07 FPS|---------+---------+---------|---------+---------+-------- *
WS Idle: 100.54ms
       115.92 ms[     10    ]       100.54 ms[     10    ]        14.49 ms[ No samples]         0.89 ms[ No samples]        8.63 FPS                                                            *
        16.62 ms[ No samples]         0.69 ms[ No samples]        15.08 ms[ No samples]         0.85 ms[ No samples]       60.18 FPS|---------+---------+---------|---------+---------+---------*
        17.01 ms[ No samples]         0.28 ms[ No samples]        15.57 ms[ No samples]         1.16 ms[ No samples]       58.79 FPS|---------+---------+---------|---------+---------+---------*
RAM: 65536MB
Machine: x86_64
Model: MacPro7,1
CPU * Core count: 16
CPU Frequency: 3800MHz
Bus Frequency: 400MHz
Open GL Renderer: AMD Radeon RX 6800 XT OpenGL Engine
Open GL Version: 2.1 ATI-4.6.20
Open GL Vendor: ATI Technologies Inc.
Open GL Extensions: L_ARB_color_buffer_float, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_draw_buffers, GL_ARB_draw_elements_base_vertex, GL_ARB_draw_instanced, GL_ARB_fragment_program, GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader, GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB, GL_ARB_half_float_pixel, GL_ARB_half_float_vertex, GL_ARB_imaging, GL_ARB_instanced_arrays, GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_provoking_vertex, GL_ARB_seamless_cube_map, GL_ARB_shader_objects, GL_ARB_shader_texture_lod, GL_ARB_shading_language_100, GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_sync, GL_ARB_texture_border_clamp, GL_ARB_texture_compression, GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3, GL_ARB_texture_float, GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two, GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_transpose_matrix, GL_ARB_vertex_array_bgra, GL_ARB_vertex_blend, GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_bindable_uniform, GL_EXT_blend_color, GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_clip_volume_hint, GL_EXT_debug_label, GL_EXT_debug_marker, GL_EXT_depth_bounds_test, GL_EXT_draw_buffers2, GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB, GL_EXT_geometry_shader4, GL_EXT_gpu_program_parameters, GL_EXT_gpu_shader4, GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil, GL_EXT_packed_float, GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color, GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_texture_array, GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_s3tc, GL_EXT_texture_env_add, GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer, GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp, GL_EXT_texture_rectangle, GL_EXT_texture_shared_exponent, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode, GL_EXT_timer_query, GL_EXT_transform_feedback, GL_EXT_vertex_array_bgra, GL_APPLE_aux_depth_stencil, GL_APPLE_client_storage, GL_APPLE_element_array, GL_APPLE_fence, GL_APPLE_float_pixels, GL_APPLE_flush_buffer_range, GL_APPLE_flush_render, GL_APPLE_object_purgeable, GL_APPLE_packed_pixels, GL_APPLE_pixel_buffer, GL_APPLE_rgb_422, GL_APPLE_row_bytes, GL_APPLE_specular_vector, GL_APPLE_texture_range, GL_APPLE_transform_hint, GL_APPLE_vertex_array_object, GL_APPLE_vertex_array_range, GL_APPLE_vertex_point_size, GL_APPLE_vertex_program_evaluators, GL_APPLE_ycbcr_422, GL_ATI_blend_equation_separate, GL_ATI_blend_weighted_minmax, GL_ATI_separate_stencil, GL_ATI_texture_compression_3dc, GL_ATI_texture_env_combine3, GL_ATI_texture_float, GL_ATI_texture_mirror_once, GL_IBM_rasterpos_clip, GL_NV_blend_square, GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fog_distance, GL_NV_light_max_exponent, GL_NV_texgen_reflection, GL_NV_texture_barrier, GL_SGI_color_matrix, GL_SGIS_generate_mipmap, GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod
HighbeamSessionId:
Adobe Product Version: 22.5.1
Adobe Product Build: 20210907.r.441
Adobe Crash Reporter Version: 10.1.4
User GUID: F4A482CF-19EF-4032-9ABF-727570EDAE95
Crash GUID: 3AFF5FF1-26B2-45F4-8496-B4EB25CF2B9E
Exit Code: 15
Report Type: hqlog
Custom Data:
Sniffer-out: [0 ms]
Launch GPUSnifferThread
[0 ms]
Start RunAllAPIs
[0 ms]
"/Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/MacOS/sniffer" -baseTimeMS=1243436 -comment=Photoshop Version:Adobe Photoshop 22.5.1 20210907.r.441 de74e1a x64
[148 ms]
Start sniffer 2021-10-27 15:54:11
# Photoshop Version:Adobe Photoshop 22.5.1 20210907.r.441 de74e1a x64
sniffer -baseTimeMS=1243436 -comment=Photoshop Version:Adobe Photoshop 22.5.1 20210907.r.441 de74e1a x64
{8 ms}
-native
Display 0
Display:724060044
Attached Device:AMD Radeon RX 6800 XT index=0 preferred=1
Device 0
Name:AMD Radeon RX 6800 XT
Preferred:TRUE
# attached displays:1
724060044
GPU accessible RAM:17163 MB
VRAM:17163 MB
Dedicated System RAM:0 MB
Shared System RAM:0 MB
Vendor name:AMD
{130 ms}
{130 ms}
-OpenGL
Display 0
Display:724060044
Attached Device:16915972 index=0 preferred=1
Device 0
Name:AMD Radeon RX 6800 XT OpenGL Engine
Preferred:TRUE
724060044
GPU accessible RAM:16368 MB
VRAM:16368 MB
Vendor name:AMD
GLSL version:1.20 1.20
CGL ID:16915972
Display mask:511
{135 ms}
{135 ms}
-OpenCL
Device 0
Name:AMD Radeon RX 6800 XT Compute Engine
Preferred:TRUE
# attached displays:0
VRAM:17163 MB
Vendor name:AMD
Device name string:AMD Radeon RX 6800 XT Compute Engine
Device vendor string:AMD
Platform name string:Apple
Platform vendor string:Apple
{147 ms}
Exit code kExitNormal
End sniffer 2021-10-27 15:54:11
[kStatusNormal kExitNormal]
[148 ms]
Finish RunAllAPIs
[1032 ms]
Start GetSnifferResult
[1032 ms]
Finish GetSnifferResult
GPUCapable: GPUDeny:0
GPUForce:0
useGPU:1
useOpenCL:1
isGPUCapable:1
GPUName:AMD Radeon RX 6800 XT
GPUVendor:AMD
IsNativeGPUCapable:1
IsOpenGLGPUCapable:1
IsOpenCLGPUCapable:1
HasSufficientRAM:1
Required GPU accessible RAM:1500 MB
UseGraphicsProcessorChecked:1
UseOpenCLChecked:1
Custom Data End:
imsUserGuid:
codeType: X86-64 (Native)
Hardware is as per my signature. I've added the environment.plist and the dylib, and I've replaced the Adaptive Wide Angle filter plugin as described.
Edited by eeeduard0
addendum
After some tests done with @tomnic, we were able to use Premiere Pro 15.4.1, but it is also possible with other programs, I said we were able to use the apps patched with SIP enabled It is important to reassign the signature to the patched plugin or library like this:
codesign --force --deep --sign - / Applications / Adobe \ Premiere \ Pro \ 2021 / Adobe \ Premiere \ Pro \ 2021.app/Contents/Plug -Ins / Common / AEFilterRollingShutter.bundle / Contents / MacOS / AEFilterRollingShutter
this above for rolling shutter (after clearly patching it)
the same for other part of the app/plugin using Intel MKL as shown by @tomnicin this thread
@Driftwoodmaybe you can test with your CC beta suite 😉
855151384_Screenshot2021-10-27at9_53_16PM.thumb.png.1839e19bd48fea3ef3635a657398c120.png
sip Enabled
solution with patched lib:
sudo codesign --force --deep --sign - /Applications/Adobe\ Photoshop\ \(Beta\)/Adobe\ Photoshop\ \(Beta\).app/Contents/Frameworks/libmkl_core.dylib
Edited by fabiosun
Hello I would like to make photoshop and after effects work but I do not have much knowledge about this issue of patching ... there is an easy way to do this if you can explain it to me step by step I would be very grateful since I would like to have a functional hackintosh but always I return to windows because adobe programs do not work for me
ragazzi mi ri fa di nuovo questo e il mio report
guys re doing this and my report again
Translated Report (Full Report Below)
Process:               Adobe Photoshop 2021 [1009]
Path:                  /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/MacOS/Adobe Photoshop 2021
Identifier:            com.adobe.Photoshop
Version:               22.5.1 (22.5.1)
Code Type:             X86-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2021-11-13 20:15:11.7979 +0100
OS Version:            macOS 12.0.1 (21A559)
Report Version:        12
Anonymous UUID:        01441806-2262-3076-0EB0-DB836BC83F9F
Time Awake Since Boot: 1000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Application Specific Information:
abort() called
terminating with uncaught exception of type std::runtime_error: mutex: pthread_mutex_lock failed: Invalid argument
Thread 0 Crashed::  Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib                0x7ff81dd2a112 __pthread_kill + 10
1   libsystem_pthread.dylib               0x7ff81dd60233 pthread_kill + 263
2   libsystem_c.dylib                     0x7ff81dcacd10 abort + 123
3   libc++abi.dylib                       0x7ff81dd1d0b2 abort_message + 241
4   libc++abi.dylib                       0x7ff81dd0e1e5 demangling_terminate_handler() + 242
5   libobjc.A.dylib                       0x7ff81dc0b6e6 _objc_terminate() + 104
6   libc++abi.dylib                       0x7ff81dd1c4d7 std::__terminate(void (*)()) + 8
7   libc++abi.dylib                       0x7ff81dd1c488 std::terminate() + 56
8   Adobe Photoshop 2021                     0x10d52747c 0x10b7ab000 + 30917756
9   Adobe Photoshop 2021                     0x10e22729a 0x10b7ab000 + 44548762
10  Adobe Photoshop 2021                     0x10e216bab 0x10b7ab000 + 44481451
11  Adobe Photoshop 2021                     0x10e2e74f1 0x10b7ab000 + 45335793
12  Adobe Photoshop 2021                     0x10e2d23b8 0x10b7ab000 + 45249464
13  Adobe Photoshop 2021                     0x10e2d24c4 0x10b7ab000 + 45249732
14  Adobe Photoshop 2021                     0x10e1d243f 0x10b7ab000 + 44201023
15  Spaces                                   0x126486fa5 PG_SendEventOverride(objc_object*, objc_selector*, NSEvent*) + 261
16  AppKit                                0x7ff820b9f80b -[NSApplication _handleEvent:] + 65
17  AppKit                                0x7ff82076737e -[NSApplication run] + 623
18  Adobe Photoshop 2021                     0x10e1d2f12 0x10b7ab000 + 44203794
19  Adobe Photoshop 2021                     0x10e1d53e0 0x10b7ab000 + 44213216
20  Adobe Photoshop 2021                     0x10e2d2c8c 0x10b7ab000 + 45251724
21  Adobe Photoshop 2021                     0x110e49288 0x10b7ab000 + 90825352
22  Adobe Photoshop 2021                     0x10b7adc89 0x10b7ab000 + 11401
23  dyld                                     0x11d9314fe start + 462
Thread 1:
0   libsystem_pthread.dylib               0x7ff81dd5c00c start_wqthread + 0
Thread 2:
0   libsystem_kernel.dylib                0x7ff81dd26506 __psynch_cvwait + 10
1   libsystem_pthread.dylib               0x7ff81dd60a89 _pthread_cond_wait + 1224
2   Adobe Photoshop 2021                     0x10e19cbbb 0x10b7ab000 + 43981755
3   Adobe Photoshop 2021                     0x10e19c2bb 0x10b7ab000 + 43979451
4   Adobe Photoshop 2021                     0x10e19c418 0x10b7ab000 + 43979800
5   libsystem_pthread.dylib               0x7ff81dd60514 _pthread_start + 125
6   libsystem_pthread.dylib               0x7ff81dd5c02f thread_start + 15
Thread 3:: com.adobe.ngl-RecurringLogPosting-0x70000c501000
2   libc++.1.dylib                        0x7ff81dcbff53 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93
3   Adobe Photoshop 2021                     0x11007dd2e 0x10b7ab000 + 76361006
4   Adobe Photoshop 2021                     0x110092067 0x10b7ab000 + 76443751
5   Adobe Photoshop 2021                     0x110091fba 0x10b7ab000 + 76443578
6   Adobe Photoshop 2021                     0x1100921de 0x10b7ab000 + 76444126
7   libsystem_pthread.dylib               0x7ff81dd60514 _pthread_start + 125
8   libsystem_pthread.dylib               0x7ff81dd5c02f thread_start + 15
Thread 4:: VulcanMsgRecv
0   libsystem_kernel.dylib                0x7ff81dd27022 __recvfrom + 10
1   VulcanMessage5.dylib                     0x11567e900 0x115609000 + 481536
2   VulcanMessage5.dylib                     0x115681864 0x115609000 + 493668
3   VulcanMessage5.dylib                     0x11565893d 0x115609000 + 325949
4   VulcanMessage5.dylib                     0x1156529af 0x115609000 + 301487
5   VulcanMessage5.dylib                     0x11565456e 0x115609000 + 308590
6   VulcanMessage5.dylib                     0x115654189 0x115609000 + 307593
7   VulcanMessage5.dylib                     0x11565a2bb 0x115609000 + 332475
8   VulcanMessage5.dylib                     0x115659ec1 0x115609000 + 331457
9   VulcanMessage5.dylib                     0x115659ddd 0x115609000 + 331229
10  VulcanMessage5.dylib                     0x115617414 0x115609000 + 58388
11  VulcanMessage5.dylib                     0x11566a121 0x115609000 + 397601
12  VulcanMessage5.dylib                     0x115688409 0x115609000 + 521225
13  libsystem_pthread.dylib               0x7ff81dd60514 _pthread_start + 125
14  libsystem_pthread.dylib               0x7ff81dd5c02f thread_start + 15
Thread 5:: com.apple.NSURLConnectionLoader
0   libsystem_kernel.dylib                0x7ff81dd23aba mach_msg_trap + 10
1   libsystem_kernel.dylib                0x7ff81dd23e2b mach_msg + 59
2   CoreFoundation                        0x7ff81de26d51 __CFRunLoopServiceMachPort + 319
3   CoreFoundation                        0x7ff81de2540f __CFRunLoopRun + 1329
4   CoreFoundation                        0x7ff81de24809 CFRunLoopRunSpecific + 567
5   CFNetwork                             0x7ff8229399a6 0x7ff8226eb000 + 2419110
6   Foundation                            0x7ff81ebac3c9 __NSThread__start__ + 1025
Thread 6:: com.adobe.ngl-RecurringProfileAndAuthStateCheck-0x70000c70d000
3   Adobe Photoshop 2021                     0x110080b1f 0x10b7ab000 + 76372767
Thread 7:: com.adobe.ngl-AuthStatusFileWatcher-0x70000c790000
5   CoreFoundation                        0x7ff81deabdc6 CFRunLoopRun + 40
6   Adobe Photoshop 2021                     0x1100e945f 0x10b7ab000 + 76801119
7   Adobe Photoshop 2021                     0x11005ec33 0x10b7ab000 + 76233779
8   Adobe Photoshop 2021                     0x110092067 0x10b7ab000 + 76443751
9   Adobe Photoshop 2021                     0x110091fba 0x10b7ab000 + 76443578
10  Adobe Photoshop 2021                     0x1100921de 0x10b7ab000 + 76444126
11  libsystem_pthread.dylib               0x7ff81dd60514 _pthread_start + 125
12  libsystem_pthread.dylib               0x7ff81dd5c02f thread_start + 15
Thread 8:
2   libc++.1.dylib                        0x7ff81dcbfec2 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18
3   Adobe Photoshop 2021                     0x10f04b9db 0x10b7ab000 + 59378139
4   Adobe Photoshop 2021                     0x10f04a61d 0x10b7ab000 + 59373085
5   Adobe Photoshop 2021                     0x110daff27 0x10b7ab000 + 90197799
6   libsystem_pthread.dylib               0x7ff81dd60514 _pthread_start + 125
7   libsystem_pthread.dylib               0x7ff81dd5c02f thread_start + 15
Thread 9:: UXP Database Thread
3   dynamic-torqnative                       0x126e27b9c 0x126d6c000 + 768924
4   dynamic-torqnative                       0x126e272d1 0x126d6c000 + 766673
5   dynamic-torqnative                       0x126e2acd2 0x126d6c000 + 781522
Thread 10:: UXP PluginManager Thread
Thread 11:: LibUV Loop Thread
0   libsystem_kernel.dylib                0x7ff81dd2845e kevent + 10
1   dynamic-torqnative                       0x127d6d1c3 0x126d6c000 + 16781763
2   dynamic-torqnative                       0x127d6f819 uv_run + 359
3   dynamic-torqnative                       0x127f89dd5 0x126d6c000 + 18996693
4   dynamic-torqnative                       0x127f8a023 0x126d6c000 + 18997283
Thread 12:: Third Party - UXP JavaScript Thread
Thread 13:: First Party - UXP JavaScript Thread
0   dynamic-torqnative                       0x128d4fd58 0x126d6c000 + 33439064
1   ???                                   0x1e33e395c011 ???
2   dynamic-torqnative                       0x128d5147d 0x126d6c000 + 33444989
3   dynamic-torqnative                       0x128e00ba9 0x126d6c000 + 34163625
4   dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
5   ???                                   0x1e33e3958430 ???
6   dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
7   dynamic-torqnative                       0x128d290bf 0x126d6c000 + 33280191
8   dynamic-torqnative                       0x128e018be 0x126d6c000 + 34166974
9   dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
10  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
11  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
12  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
13  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
14  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
15  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
16  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
17  dynamic-torqnative                       0x128dc8281 0x126d6c000 + 33931905
18  dynamic-torqnative                       0x128d1e578 0x126d6c000 + 33236344
19  dynamic-torqnative                       0x128e09ae1 0x126d6c000 + 34200289
20  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
21  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
22  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
23  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
24  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
25  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
26  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
27  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
28  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
29  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
30  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
31  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
32  dynamic-torqnative                       0x128d21119 0x126d6c000 + 33247513
33  dynamic-torqnative                       0x128dc9b31 0x126d6c000 + 33938225
34  dynamic-torqnative                       0x128d3fd8c 0x126d6c000 + 33373580
35  dynamic-torqnative                       0x128d1eed8 0x126d6c000 + 33238744
36  dynamic-torqnative                       0x12811136b 0x126d6c000 + 20599659
37  dynamic-torqnative                       0x128111973 0x126d6c000 + 20601203
38  dynamic-torqnative                       0x128111a51 0x126d6c000 + 20601425
39  dynamic-torqnative                       0x12813de16 0x126d6c000 + 20782614
40  dynamic-torqnative                       0x12813dc27 0x126d6c000 + 20782119
41  dynamic-torqnative                       0x12812b588 0x126d6c000 + 20706696
42  dynamic-torqnative                       0x127fe83d0 0x126d6c000 + 19383248
43  dynamic-torqnative                       0x127f9e12a napi_call_function + 173
44  Adobe Photoshop 2021                     0x11075c66f 0x10b7ab000 + 83564143
45  Adobe Photoshop 2021                     0x11119a58a 0x10b7ab000 + 94303626
46  Adobe Photoshop 2021                     0x1111948bd 0x10b7ab000 + 94279869
47  Adobe Photoshop 2021                     0x1111a65d0 0x10b7ab000 + 94352848
48  Adobe Photoshop 2021                     0x110767b73 0x10b7ab000 + 83610483
49  Adobe Photoshop 2021                     0x11073fbf2 0x10b7ab000 + 83446770
50  dynamic-torqnative                       0x127002706 0x126d6c000 + 2713350
51  dynamic-torqnative                       0x126e23793 0x126d6c000 + 751507
52  dynamic-torqnative                       0x126e2d041 0x126d6c000 + 790593
53  dynamic-torqnative                       0x126e27c26 0x126d6c000 + 769062
54  dynamic-torqnative                       0x126e272d1 0x126d6c000 + 766673
55  dynamic-torqnative                       0x126e2acd2 0x126d6c000 + 781522
56  libsystem_pthread.dylib               0x7ff81dd60514 _pthread_start + 125
57  libsystem_pthread.dylib               0x7ff81dd5c02f thread_start + 15
Thread 14:: UI Worker 1
0   libsystem_kernel.dylib                0x7ff81dd2520a __ulock_wait + 10
1   libsystem_pthread.dylib               0x7ff81dd61c8d _pthread_join + 362
2   Camera Raw                               0x1931cf525 0x1926c5000 + 11576613
3   Camera Raw                               0x1934f6754 0x1926c5000 + 14882644
4   Camera Raw                               0x1934ea727 0x1926c5000 + 14833447
5   libsystem_c.dylib                     0x7ff81dc59cdd __cxa_finalize_ranges + 409
6   libsystem_c.dylib                     0x7ff81dc59af7 exit + 35
7   libmkl_core.dylib                        0x118c97778 mkl_serv_exit + 24
8   ???                                       0x3f800000 ???
Thread 15:: V8 DefaultWorke
2   dynamic-torqnative                       0x127fc1144 0x126d6c000 + 19222852
3   dynamic-torqnative                       0x127fc0780 0x126d6c000 + 19220352
4   dynamic-torqnative                       0x127fb7947 0x126d6c000 + 19183943
Thread 16:: V8 DefaultWorke
Thread 17:: V8 DefaultWorke
Thread 18:: V8 DefaultWorke
Thread 19:: V8 DefaultWorke
Thread 20:: V8 DefaultWorke
Thread 21:: V8 DefaultWorke
Thread 22:: V8 DefaultWorke
Thread 23:: V8 DefaultWorke
Thread 24:: V8 DefaultWorke
Thread 25:: V8 DefaultWorke
Thread 26:: V8 DefaultWorke
Thread 27:: V8 DefaultWorke
Thread 28:: V8 DefaultWorke
Thread 29:: V8 DefaultWorke
Thread 30:
2   LogSession                               0x115c0a8ee 0x115aca000 + 1313006
3   LogSession                               0x115b9246d 0x115aca000 + 820333
4   LogSession                               0x115b8cf16 0x115aca000 + 798486
5   LogSession                               0x115c09ce7 0x115aca000 + 1309927
Thread 31:
3   LogSession                               0x115bc3949 0x115aca000 + 1022281
4   LogSession                               0x115bc34aa 0x115aca000 + 1021098
Thread 32:: TypeKitDownload
3   Adobe Photoshop 2021                     0x1107bc993 0x10b7ab000 + 83958163
4   Adobe Photoshop 2021                     0x1107bda94 0x10b7ab000 + 83962516
5   Adobe Photoshop 2021                     0x1107bd96a 0x10b7ab000 + 83962218
Thread 33:: TypeKitDownload
Thread 34:: TypeKitDownload
Thread 35:: TypeKitDownload
Thread 36:: TypeQuest
5   Adobe Photoshop 2021                     0x1107d349f 0x10b7ab000 + 84051103
6   Adobe Photoshop 2021                     0x1107d6e51 0x10b7ab000 + 84065873
Thread 37:: UxTech Queue ThreadController
Thread 38:: UxTech Queue ThreadController
Thread 39:: UxTech Queue ThreadController
Thread 40:: UxTech Queue ThreadController
Thread 41:: UxTech Queue ThreadController
Thread 42:: UxTech Queue ThreadController
Thread 43:: UxTech Queue ThreadController
Thread 44:: UxTech Queue ThreadController
Thread 45:: General Background Service
3   Adobe Photoshop 2021                     0x10ccb3750 0x10b7ab000 + 22054736
4   Adobe Photoshop 2021                     0x10ccb32dc 0x10b7ab000 + 22053596
5   Adobe Photoshop 2021                     0x10ccb4bee 0x10b7ab000 + 22060014
Thread 46:: LEC-IngestPoll
3   Adobe Photoshop 2021                     0x10de6785b 0x10b7ab000 + 40618075
4   Adobe Photoshop 2021                     0x10b986401 0x10b7ab000 + 1946625
5   Adobe Photoshop 2021                     0x10b95ec6e 0x10b7ab000 + 1784942
6   Adobe Photoshop 2021                     0x10b960071 0x10b7ab000 + 1790065
Thread 47:: ACPLSDKWorkerThread2
0   libsystem_kernel.dylib                0x7ff81dd263da __semwait_signal + 10
1   libsystem_c.dylib                     0x7ff81dc3b8a9 nanosleep + 196
2   libc++.1.dylib                        0x7ff81dcc9c11 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > const&) + 73
3   Adobe Photoshop 2021                     0x10ec38658 0x10b7ab000 + 55105112
4   Adobe Photoshop 2021                     0x10ec3985e 0x10b7ab000 + 55109726
Thread 48:: com.apple.CFSocket.private
0   libsystem_kernel.dylib                0x7ff81dd2be4a __select + 10
1   CoreFoundation                        0x7ff81de4db04 __CFSocketManager + 638
2   libsystem_pthread.dylib               0x7ff81dd60514 _pthread_start + 125
3   libsystem_pthread.dylib               0x7ff81dd5c02f thread_start + 15
Thread 49:
0   libsystem_kernel.dylib                0x7ff81dd23af6 semaphore_wait_trap + 10
1   libtbb.dylib                             0x114c6c6b8 0x114c55000 + 95928
2   libtbb.dylib                             0x114c6c559 0x114c55000 + 95577
Thread 50:
Thread 51:
Thread 52:
Thread 53:
Thread 54:
Thread 55:
Thread 56:
Thread 57:
Thread 58:
Thread 59:
Thread 60:
Thread 61:
Thread 62:
Thread 63:
Thread 64:
2   dynamic-torqnative                       0x127d798d2 uv_cond_wait + 9
3   dynamic-torqnative                       0x127d68ff0 0x126d6c000 + 16764912
4   libsystem_pthread.dylib               0x7ff81dd60514 _pthread_start + 125
5   libsystem_pthread.dylib               0x7ff81dd5c02f thread_start + 15
Thread 65:
Thread 66:
Thread 67:
Thread 68:: UI Worker 2
Thread 69:: BridgeTalk
2   ScriptingSupport                         0x12b83fb38 ScObjects::Thread::wait(unsigned int) + 56
3   ScriptingSupport                         0x12b824892 ScObjects::BridgeTalkThread::run() + 290
4   ScriptingSupport                         0x12b83f6e7 ScObjects::Thread::go(void*) + 151
Thread 70:: UI Worker 3
Thread 71:: TaskSchedulerServiceThread
1   Chromium Embedded Framework              0x17bc2bad9 0x17964b000 + 39717593
2   Chromium Embedded Framework              0x17bc295bd 0x17964b000 + 39708093
3   Chromium Embedded Framework              0x17bc287be 0x17964b000 + 39704510
4   Chromium Embedded Framework              0x17bba9ad5 0x17964b000 + 39185109
5   Chromium Embedded Framework              0x17bbdde84 0x17964b000 + 39399044
6   Chromium Embedded Framework              0x17bbf0316 0x17964b000 + 39473942
7   Chromium Embedded Framework              0x17bc20467 0x17964b000 + 39670887
8   libsystem_pthread.dylib               0x7ff81dd60514 _pthread_start + 125
9   libsystem_pthread.dylib               0x7ff81dd5c02f thread_start + 15
Thread 72:: TaskSchedulerForegroundWorker
2   Chromium Embedded Framework              0x17bbc0480 0x17964b000 + 39277696
3   Chromium Embedded Framework              0x17bbc0591 0x17964b000 + 39277969
4   Chromium Embedded Framework              0x17bbd94f8 0x17964b000 + 39380216
5   Chromium Embedded Framework              0x17bbd9d83 0x17964b000 + 39382403
6   Chromium Embedded Framework              0x17bbd9a34 0x17964b000 + 39381556
Thread 73:: TaskSchedulerForegroundBlockingWorker
Thread 74:: TaskSchedulerBackgroundWorker
6   Chromium Embedded Framework              0x17bbd99a4 0x17964b000 + 39381412
Thread 75:: Chrome_IOThread
5   Chromium Embedded Framework              0x17aba1a44 0x17964b000 + 22374980
Thread 76:: NetworkConfigWatcher
5   Foundation                            0x7ff81ebb375e -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 216
6   Chromium Embedded Framework              0x17bb88a80 0x17964b000 + 39049856
7   Chromium Embedded Framework              0x17bb879e7 0x17964b000 + 39045607
8   Chromium Embedded Framework              0x17bba9ad5 0x17964b000 + 39185109
9   Chromium Embedded Framework              0x17bbf0316 0x17964b000 + 39473942
10  Chromium Embedded Framework              0x17bc20467 0x17964b000 + 39670887
Thread 77:: DnsConfigService
3   Chromium Embedded Framework              0x17bc287d7 0x17964b000 + 39704535
5   Chromium Embedded Framework              0x17bbf0316 0x17964b000 + 39473942
6   Chromium Embedded Framework              0x17bc20467 0x17964b000 + 39670887
Thread 78:: TaskSchedulerForegroundBlockingWorker
Thread 79:: TaskSchedulerForegroundBlockingWorker
5   Chromium Embedded Framework              0x17bbd9b22 0x17964b000 + 39381794
Thread 80:: TaskSchedulerBackgroundBlockingWorker
Thread 81:: CompositorTileWorker1/177411
2   Chromium Embedded Framework              0x17bc1f6d5 0x17964b000 + 39667413
3   Chromium Embedded Framework              0x17cba9178 0x17964b000 + 55959928
4   Chromium Embedded Framework              0x17bbef774 0x17964b000 + 39470964
5   Chromium Embedded Framework              0x17bc20467 0x17964b000 + 39670887
Thread 82:: AudioThread
3   Chromium Embedded Framework              0x17bbc033f 0x17964b000 + 39277375
4   Chromium Embedded Framework              0x17bb8789d 0x17964b000 + 39045277
5   Chromium Embedded Framework              0x17bba9ad5 0x17964b000 + 39185109
Thread 83:: TaskSchedulerSingleThreadForegroundBlocking0
4   Chromium Embedded Framework              0x17bbd94ea 0x17964b000 + 39380202
6   Chromium Embedded Framework              0x17bbd9a94 0x17964b000 + 39381652
Thread 84:: TaskSchedulerSingleThreadBackgroundBlocking1
6   Chromium Embedded Framework              0x17bbd9a04 0x17964b000 + 39381508
Thread 85:: TaskSchedulerSingleThreadSharedBackgroundBlocking2
6   Chromium Embedded Framework              0x17bbd99d4 0x17964b000 + 39381460
Thread 86:: TaskSchedulerSingleThreadSharedForegroundBlocking3
6   Chromium Embedded Framework              0x17bbd9a64 0x17964b000 + 39381604
Thread 87:: NetworkConfigWatcher
Thread 88:: CacheThread_BlockFile
Thread 89:: com.apple.NSEventThread
5   AppKit                                0x7ff8208e4cec _NSEventThread + 132
Thread 90:: UI Worker 4
Thread 91:: Background DOM Loader Thread - UXP JavaScript Thread
Thread 92:
2   dynamic-torqnative                       0x126fc827e 0x126d6c000 + 2474622
3   dynamic-torqnative                       0x126fbf77c 0x126d6c000 + 2439036
4   dynamic-torqnative                       0x126fb9d5b 0x126d6c000 + 2415963
5   dynamic-torqnative                       0x126fb9c73 0x126d6c000 + 2415731
6   dynamic-torqnative                       0x126fbdce4 0x126d6c000 + 2432228
Thread 93:
1   dynamic-torqnative                       0x126fbd36f 0x126d6c000 + 2429807
2   dynamic-torqnative                       0x126fbf7ba 0x126d6c000 + 2439098
3   dynamic-torqnative                       0x126fb9d5b 0x126d6c000 + 2415963
4   dynamic-torqnative                       0x126fb9c73 0x126d6c000 + 2415731
5   dynamic-torqnative                       0x126fb013c 0x126d6c000 + 2375996
Thread 94:
Thread 95:
Thread 96:
Thread 97:
Thread 98:
Thread 99:: cr_scratch
3   Camera Raw                               0x1934ed05b 0x1926c5000 + 14843995
4   Camera Raw                               0x1931cf6b1 0x1926c5000 + 11577009
Thread 100:
Thread 101:
Thread 102:
Thread 103:
Thread 104:
Thread 105:
Thread 106:
Thread 107:
Thread 108:
Thread 109:
Thread 110:
Thread 111:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x000000011d9a4600  rcx: 0x00007ff7b4751f98  rdx: 0x0000000000000000
  rdi: 0x0000000000000103  rsi: 0x0000000000000006  rbp: 0x00007ff7b4751fc0  rsp: 0x00007ff7b4751f98
   r8: 0x00007ff7b4751e60   r9: 0x00007ff81dd1ff78  r10: 0x0000000000000000  r11: 0x0000000000000246
  r12: 0x0000000000000103  r13: 0x0000003000000008  r14: 0x0000000000000006  r15: 0x0000000000000016
  rip: 0x00007ff81dd2a112  rfl: 0x0000000000000246  cr2: 0x00007ff85da68980
Logical CPU:     0
Error Code:      0x02000148
Trap Number:     133
Binary Images:
    0x7ff81dd23000 -     0x7ff81dd59fff libsystem_kernel.dylib (*) <12bd6f13-c452-35ee-9069-51befef29f1a> /usr/lib/system/libsystem_kernel.dylib
    0x7ff81dd5a000 -     0x7ff81dd65fff libsystem_pthread.dylib (*) <29a2750e-f31b-3630-8761-242a6bc3e99e> /usr/lib/system/libsystem_pthread.dylib
    0x7ff81dc2b000 -     0x7ff81dcb3fff libsystem_c.dylib (*) <991f58b7-b4c0-3c3a-84a8-c9c571de5a27> /usr/lib/system/libsystem_c.dylib
    0x7ff81dd0d000 -     0x7ff81dd22fff libc++abi.dylib (*) <a851e310-475a-3c94-b547-8eb5ae90191a> /usr/lib/libc++abi.dylib
    0x7ff81dbeb000 -     0x7ff81dc27fff libobjc.A.dylib (*) <6b22efe4-18cc-3551-90ba-d18236104790> /usr/lib/libobjc.A.dylib
       0x10b7ab000 -        0x113716fff com.adobe.Photoshop (22.5.1) <abd52ca8-a36d-3767-898a-824cc6574f28> /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/MacOS/Adobe Photoshop 2021
       0x1263e9000 -        0x126588fff com.adobe.ps.spaces (22.5) <7b8680af-d5f9-3e45-931c-9f3c00f4be44> /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/PlugIns/Required/Spaces/Spaces.plugin/Contents/MacOS/Spaces
    0x7ff820738000 -     0x7ff8215c4fff com.apple.AppKit (6.9) <dd0028a3-78e3-3a8a-a51b-ddd68123adef> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
       0x11d92c000 -        0x11d997fff dyld (*) <1a6ae033-9438-33c0-8077-988fd885250a> /usr/lib/dyld
    0x7ff81dcb4000 -     0x7ff81dd0cfff libc++.1.dylib (*) <91a6d960-2646-34e2-a81e-4e34e3697a92> /usr/lib/libc++.1.dylib
       0x115609000 -        0x115694fff VulcanMessage5.dylib (*) <d9692b38-8895-3064-91ed-968b50905575> /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/Frameworks/VulcanMessage5.dylib
    0x7ff81dda7000 -     0x7ff81e2a7fff com.apple.CoreFoundation (6.9) <afcc752e-074d-340f-890c-263efd2da77f> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7ff8226eb000 -     0x7ff822b80fff com.apple.CFNetwork (1325.0.1) <8a8cd85d-cf83-3019-bd2c-b99a711c97d7> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7ff81eb53000 -     0x7ff81ef0dfff com.apple.Foundation (6.9) <d7fd0214-4bbb-3d84-88f7-820b25a6e16c> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
       0x126d6c000 -        0x1294abfff com.adobe.uxp.macos.alpaca.v8 (local) <bdc87eb3-1c9c-3593-969e-da8c1bf9959b> /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/Frameworks/dynamic-torqnative.framework/Versions/A/dynamic-torqnative
               0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
       0x1926c5000 -        0x198a40fff com.adobe.CameraRaw (14.0.1 (952)) <2f93e39d-46f3-356f-bfee-daa20695e74d> /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/MacOS/Camera Raw
       0x118c83000 -        0x11ca13fff libmkl_core.dylib (*) <4e843307-4d4a-3350-873e-2f7a7e48c9ab> /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/Frameworks/libmkl_core.dylib
       0x115aca000 -        0x115c39fff com.adobe.headlights.LogSessionFramework (*) <96cb4041-f593-393f-a5ed-3e0e00a1f882> /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
       0x114c55000 -        0x114c74fff libtbb.dylib (*) <6847c745-6a55-3135-b251-bf03bbe525fb> /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/Frameworks/libtbb.dylib
       0x12b4d6000 -        0x12b905fff com.adobe.PSAutomate (22.5) <dbf8b6be-3e3f-399d-97cf-6882f708a653> /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/PlugIns/Required/Extensions/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
       0x17964b000 -        0x18080dfff org.chromium.ContentShell.framework (3.3626.1882.0) <0e0cf0df-f3bd-3ea0-aeeb-f8f6ec8157d6> /Applications/Adobe Photoshop 2021/Adobe Photoshop 2021.app/Contents/PlugIns/Required/Spaces/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.8G resident=0K(0%) swapped_out_or_unallocated=1.8G(100%)
Writable regions: Total=4.0G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=4.0G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               768K        6
Activity Tracing                   256K        1
CG backing stores                 3600K        8
CG image                          2480K       46
ColorSync                          240K       28
CoreAnimation                     74.9M       66
CoreGraphics                        16K        3
CoreServices                       624K        2
CoreUI image data                 2792K       25
Foundation                          44K        2
Image IO                           292K       29
Kernel Alloc Once                    8K        1
MALLOC                             1.8G      888
MALLOC guard page                   48K       10
MALLOC_LARGE (reserved)            412K        1         reserved VM address space (unallocated)
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
Memory Tag 255                   677.2M     1073
Memory Tag 255 (reserved)           16K        1         reserved VM address space (unallocated)
PROTECTED_MEMORY                     4K        1
SQLite page cache                  192K        3
STACK GUARD                       56.4M      112
Stack                            289.4M      114
VM_ALLOCATE                        1.2G      115
__DATA                            86.5M      631
__DATA_CONST                      29.6M      347
__DATA_DIRTY                      1591K      211
__FONT_DATA                          4K        1
__GLSLBUILTINS                    5176K        1
__LINKEDIT                       662.2M       84
__OBJC_RO                         81.6M        1
__OBJC_RW                         3120K        3
__TEXT                             1.2G      615
__UNICODE                          588K        1
dyld private memory               1024K        1
libnetwork                        1664K       24
mapped file                      255.8M       66
shared memory                      776K       18
TOTAL                              6.7G     4540
TOTAL, minus reserved VM space     6.4G     4540
Full Report
{"app_name":"Adobe Photoshop 2021","timestamp":"2021-11-13 20:15:12.00 +0100","app_version":"22.5.1","slice_uuid":"abd52ca8-a36d-3767-898a-824cc6574f28","build_version":"22.5.1","platform":1,"bundleID":"com.adobe.Photoshop","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.0.1 (21A559)","incident_id":"D6331691-9367-4D77-9109-B86F82CDFA5B","name":"Adobe Photoshop 2021"}
  "uptime" : 1000,
  "procLaunch" : "2021-11-13 20:14:12.5140 +0100",
  "procRole" : "Foreground",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "MacPro7,1",
  "procStartAbsTime" : 1024256559593,
  "coalitionID" : 671,
  "osVersion" : {
    "train" : "macOS 12.0.1",
    "build" : "21A559",
    "releaseType" : "User"
  "captureTime" : "2021-11-13 20:15:11.7979 +0100",
  "incident" : "D6331691-9367-4D77-9109-B86F82CDFA5B",
  "bug_type" : "309",
  "pid" : 1009,
  "procExitAbsTime" : 1083526182395,
  "cpuType" : "X86-64",
  "procName" : "Adobe Photoshop 2021",
  "procPath" : "\/Applications\/Adobe Photoshop 2021\/Adobe Photoshop 2021.app\/Contents\/MacOS\/Adobe Photoshop 2021",
  "bundleInfo" : {"CFBundleShortVersionString":"22.5.1","CFBundleVersion":"22.5.1","CFBundleIdentifier":"com.adobe.Photoshop"},
  "storeInfo" : {"deviceIdentifierForVendor":"B65274A6-CEFA-5218-AC7A-A154ED7FF40A","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "com.adobe.Photoshop",
  "crashReporterKey" : "01441806-2262-3076-0EB0-DB836BC83F9F",
  "sip" : "enabled",
  "isCorpse" : 1,
  "exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGABRT"},
  "asi" : {"libc++abi.dylib":["terminating with uncaught exception of type std::runtime_error: mutex: pthread_mutex_lock failed: Invalid argument"],"libsystem_c.dylib":["abort() called"]},
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 0,
  "threads" : [{"triggered":true,"id":22924,"threadState":{"r13":{"value":206158430216},"rax":{"value":0},"rflags":{"value":582},"cpu":{"value":0},"r14":{"value":6},"rsi":{"value":6},"r8":{"value":140701861224032},"cr2":{"value":140704699812224},"rdx":{"value":0},"r10":{"value":0},"r9":{"value":140703628918648},"r15":{"value":22},"rbx":{"value":4791617024,"symbolLocation":0,"symbol":"_main_thread"},"trap":{"value":133},"err":{"value":33554760},"r11":{"value":582},"rip":{"value":140703628960018,"matchesCrashFrame":1},"rbp":{"value":140701861224384},"rsp":{"value":140701861224344},"r12":{"value":259},"rcx":{"value":140701861224344},"flavor":"x86_THREAD_STATE","rdi":{"value":259}},"queue":"com.apple.main-thread","frames":[{"imageOffset":28946,"symbol":"__pthread_kill","symbolLocation":10,"imageIndex":0},{"imageOffset":25139,"symbol":"pthread_kill","symbolLocation":263,"imageIndex":1},{"imageOffset":531728,"symbol":"abort","symbolLocation":123,"imageIndex":2},{"imageOffset":65714,"symbol":"abort_message","symbolLocation":241,"imageIndex":3},{"imageOffset":4581,"symbol":"demangling_terminate_handler()","symbolLocation":242,"imageIndex":3},{"imageOffset":132838,"symbol":"_objc_terminate()","symbolLocation":104,"imageIndex":4},{"imageOffset":62679,"symbol":"std::__terminate(void (*)())","symbolLocation":8,"imageIndex":3},{"imageOffset":62600,"symbol":"std::terminate()","symbolLocation":56,"imageIndex":3},{"imageOffset":30917756,"imageIndex":5},{"imageOffset":44548762,"imageIndex":5},{"imageOffset":44481451,"imageIndex":5},{"imageOffset":45335793,"imageIndex":5},{"imageOffset":45249464,"imageIndex":5},{"imageOffset":45249732,"imageIndex":5},{"imageOffset":44201023,"imageIndex":5},{"imageOffset":647077,"symbol":"PG_SendEventOverride(objc_object*, objc_selector*, NSEvent*)","symbolLocation":261,"imageIndex":6},{"imageOffset":4618251,"symbol":"-[NSApplication _handleEvent:]","symbolLocation":65,"imageIndex":7},{"imageOffset":193406,"symbol":"-[NSApplication run]","symbolLocation":623,"imageIndex":7},{"imageOffset":44203794,"imageIndex":5},{"imageOffset":44213216,"imageIndex":5},{"imageOffset":45251724,"imageIndex":5},{"imageOffset":90825352,"imageIndex":5},{"imageOffset":11401,"imageIndex":5},{"imageOffset":21758,"symbol":"start","symbolLocation":462,"imageIndex":8}]},{"id":22936,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":22968,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":43981755,"imageIndex":5},{"imageOffset":43979451,"imageIndex":5},{"imageOffset":43979800,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":22970,"name":"com.adobe.ngl-RecurringLogPosting-0x70000c501000","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48979,"symbol":"std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >)","symbolLocation":93,"imageIndex":9},{"imageOffset":76361006,"imageIndex":5},{"imageOffset":76443751,"imageIndex":5},{"imageOffset":76443578,"imageIndex":5},{"imageOffset":76444126,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":22974,"name":"VulcanMsgRecv","frames":[{"imageOffset":16418,"symbol":"__recvfrom","symbolLocation":10,"imageIndex":0},{"imageOffset":481536,"imageIndex":10},{"imageOffset":493668,"imageIndex":10},{"imageOffset":325949,"imageIndex":10},{"imageOffset":301487,"imageIndex":10},{"imageOffset":308590,"imageIndex":10},{"imageOffset":307593,"imageIndex":10},{"imageOffset":332475,"imageIndex":10},{"imageOffset":331457,"imageIndex":10},{"imageOffset":331229,"imageIndex":10},{"imageOffset":58388,"imageIndex":10},{"imageOffset":397601,"imageIndex":10},{"imageOffset":521225,"imageIndex":10},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":22990,"name":"com.apple.NSURLConnectionLoader","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":523601,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":11},{"imageOffset":517135,"symbol":"__CFRunLoopRun","symbolLocation":1329,"imageIndex":11},{"imageOffset":514057,"symbol":"CFRunLoopRunSpecific","symbolLocation":567,"imageIndex":11},{"imageOffset":2419110,"imageIndex":12},{"imageOffset":365513,"symbol":"__NSThread__start__","symbolLocation":1025,"imageIndex":13},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":22996,"name":"com.adobe.ngl-RecurringProfileAndAuthStateCheck-0x70000c70d000","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48979,"symbol":"std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >)","symbolLocation":93,"imageIndex":9},{"imageOffset":76372767,"imageIndex":5},{"imageOffset":76443751,"imageIndex":5},{"imageOffset":76443578,"imageIndex":5},{"imageOffset":76444126,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":22997,"name":"com.adobe.ngl-AuthStatusFileWatcher-0x70000c790000","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":523601,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":11},{"imageOffset":517135,"symbol":"__CFRunLoopRun","symbolLocation":1329,"imageIndex":11},{"imageOffset":514057,"symbol":"CFRunLoopRunSpecific","symbolLocation":567,"imageIndex":11},{"imageOffset":1068486,"symbol":"CFRunLoopRun","symbolLocation":40,"imageIndex":11},{"imageOffset":76801119,"imageIndex":5},{"imageOffset":76233779,"imageIndex":5},{"imageOffset":76443751,"imageIndex":5},{"imageOffset":76443578,"imageIndex":5},{"imageOffset":76444126,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23004,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":59378139,"imageIndex":5},{"imageOffset":59373085,"imageIndex":5},{"imageOffset":90197799,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23005,"name":"UXP Database Thread","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":768924,"imageIndex":14},{"imageOffset":766673,"imageIndex":14},{"imageOffset":781522,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23006,"name":"UXP PluginManager Thread","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":768924,"imageIndex":14},{"imageOffset":766673,"imageIndex":14},{"imageOffset":781522,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23008,"name":"LibUV Loop Thread","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":0},{"imageOffset":16781763,"imageIndex":14},{"imageOffset":16791577,"symbol":"uv_run","symbolLocation":359,"imageIndex":14},{"imageOffset":18996693,"imageIndex":14},{"imageOffset":18997283,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23009,"name":"Third Party - UXP JavaScript Thread","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":768924,"imageIndex":14},{"imageOffset":766673,"imageIndex":14},{"imageOffset":781522,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23010,"name":"First Party - UXP JavaScript Thread","frames":[{"imageOffset":33439064,"imageIndex":14},{"imageOffset":33208210407441,"imageIndex":15},{"imageOffset":33444989,"imageIndex":14},{"imageOffset":34163625,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33208210392112,"imageIndex":15},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33280191,"imageIndex":14},{"imageOffset":34166974,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33931905,"imageIndex":14},{"imageOffset":33236344,"imageIndex":14},{"imageOffset":34200289,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33247513,"imageIndex":14},{"imageOffset":33938225,"imageIndex":14},{"imageOffset":33373580,"imageIndex":14},{"imageOffset":33238744,"imageIndex":14},{"imageOffset":20599659,"imageIndex":14},{"imageOffset":20601203,"imageIndex":14},{"imageOffset":20601425,"imageIndex":14},{"imageOffset":20782614,"imageIndex":14},{"imageOffset":20782119,"imageIndex":14},{"imageOffset":20706696,"imageIndex":14},{"imageOffset":19383248,"imageIndex":14},{"imageOffset":19079466,"symbol":"napi_call_function","symbolLocation":173,"imageIndex":14},{"imageOffset":83564143,"imageIndex":5},{"imageOffset":94303626,"imageIndex":5},{"imageOffset":94279869,"imageIndex":5},{"imageOffset":94352848,"imageIndex":5},{"imageOffset":83610483,"imageIndex":5},{"imageOffset":83446770,"imageIndex":5},{"imageOffset":2713350,"imageIndex":14},{"imageOffset":751507,"imageIndex":14},{"imageOffset":790593,"imageIndex":14},{"imageOffset":769062,"imageIndex":14},{"imageOffset":766673,"imageIndex":14},{"imageOffset":781522,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23011,"name":"UI Worker 1","frames":[{"imageOffset":8714,"symbol":"__ulock_wait","symbolLocation":10,"imageIndex":0},{"imageOffset":31885,"symbol":"_pthread_join","symbolLocation":362,"imageIndex":1},{"imageOffset":11576613,"imageIndex":16},{"imageOffset":14882644,"imageIndex":16},{"imageOffset":14833447,"imageIndex":16},{"imageOffset":191709,"symbol":"__cxa_finalize_ranges","symbolLocation":409,"imageIndex":2},{"imageOffset":191223,"symbol":"exit","symbolLocation":35,"imageIndex":2},{"imageOffset":83832,"symbol":"mkl_serv_exit","symbolLocation":24,"imageIndex":17},{"imageOffset":1065353216,"imageIndex":15}]},{"id":23012,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23013,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23014,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23015,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23016,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23017,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23018,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23019,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23020,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23021,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23022,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23023,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23024,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23025,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23026,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":19222852,"imageIndex":14},{"imageOffset":19220352,"imageIndex":14},{"imageOffset":19183943,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23027,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":1313006,"imageIndex":18},{"imageOffset":820333,"imageIndex":18},{"imageOffset":798486,"imageIndex":18},{"imageOffset":1309927,"imageIndex":18},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23028,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":1313006,"imageIndex":18},{"imageOffset":1022281,"imageIndex":18},{"imageOffset":1021098,"imageIndex":18},{"imageOffset":1309927,"imageIndex":18},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23030,"name":"TypeKitDownload","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":83958163,"imageIndex":5},{"imageOffset":83962516,"imageIndex":5},{"imageOffset":83962218,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23031,"name":"TypeKitDownload","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":83958163,"imageIndex":5},{"imageOffset":83962516,"imageIndex":5},{"imageOffset":83962218,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23032,"name":"TypeKitDownload","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":83958163,"imageIndex":5},{"imageOffset":83962516,"imageIndex":5},{"imageOffset":83962218,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23033,"name":"TypeKitDownload","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":83958163,"imageIndex":5},{"imageOffset":83962516,"imageIndex":5},{"imageOffset":83962218,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23034,"name":"TypeQuest","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":523601,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":11},{"imageOffset":517135,"symbol":"__CFRunLoopRun","symbolLocation":1329,"imageIndex":11},{"imageOffset":514057,"symbol":"CFRunLoopRunSpecific","symbolLocation":567,"imageIndex":11},{"imageOffset":84051103,"imageIndex":5},{"imageOffset":84065873,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23035,"name":"UxTech Queue ThreadController","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":83958163,"imageIndex":5},{"imageOffset":83962516,"imageIndex":5},{"imageOffset":83962218,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23036,"name":"UxTech Queue ThreadController","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":83958163,"imageIndex":5},{"imageOffset":83962516,"imageIndex":5},{"imageOffset":83962218,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23037,"name":"UxTech Queue ThreadController","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":83958163,"imageIndex":5},{"imageOffset":83962516,"imageIndex":5},{"imageOffset":83962218,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23038,"name":"UxTech Queue ThreadController","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":83958163,"imageIndex":5},{"imageOffset":83962516,"imageIndex":5},{"imageOffset":83962218,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23039,"name":"UxTech Queue ThreadController","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":83958163,"imageIndex":5},{"imageOffset":83962516,"imageIndex":5},{"imageOffset":83962218,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23040,"name":"UxTech Queue ThreadController","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":83958163,"imageIndex":5},{"imageOffset":83962516,"imageIndex":5},{"imageOffset":83962218,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23041,"name":"UxTech Queue ThreadController","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":83958163,"imageIndex":5},{"imageOffset":83962516,"imageIndex":5},{"imageOffset":83962218,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23042,"name":"UxTech Queue ThreadController","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":83958163,"imageIndex":5},{"imageOffset":83962516,"imageIndex":5},{"imageOffset":83962218,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23050,"name":"General Background Service","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":22054736,"imageIndex":5},{"imageOffset":22053596,"imageIndex":5},{"imageOffset":22060014,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23052,"name":"LEC-IngestPoll","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48979,"symbol":"std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >)","symbolLocation":93,"imageIndex":9},{"imageOffset":40618075,"imageIndex":5},{"imageOffset":1946625,"imageIndex":5},{"imageOffset":1784942,"imageIndex":5},{"imageOffset":1790065,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23058,"name":"ACPLSDKWorkerThread2","frames":[{"imageOffset":13274,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":0},{"imageOffset":67753,"symbol":"nanosleep","symbolLocation":196,"imageIndex":2},{"imageOffset":89105,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > const&)","symbolLocation":73,"imageIndex":9},{"imageOffset":55105112,"imageIndex":5},{"imageOffset":55109726,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23061,"name":"com.apple.CFSocket.private","frames":[{"imageOffset":36426,"symbol":"__select","symbolLocation":10,"imageIndex":0},{"imageOffset":682756,"symbol":"__CFSocketManager","symbolLocation":638,"imageIndex":11},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23062,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23063,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23064,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23065,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23066,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23067,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23068,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23069,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23070,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23071,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23072,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23073,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23074,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23075,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23076,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":95928,"imageIndex":19},{"imageOffset":95577,"imageIndex":19},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23089,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":16832722,"symbol":"uv_cond_wait","symbolLocation":9,"imageIndex":14},{"imageOffset":16764912,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23090,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":16832722,"symbol":"uv_cond_wait","symbolLocation":9,"imageIndex":14},{"imageOffset":16764912,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23091,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":16832722,"symbol":"uv_cond_wait","symbolLocation":9,"imageIndex":14},{"imageOffset":16764912,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23092,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":16832722,"symbol":"uv_cond_wait","symbolLocation":9,"imageIndex":14},{"imageOffset":16764912,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23133,"name":"UI Worker 2","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":22054736,"imageIndex":5},{"imageOffset":22053596,"imageIndex":5},{"imageOffset":22060014,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23150,"name":"BridgeTalk","frames":[{"imageOffset":13274,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":0},{"imageOffset":67753,"symbol":"nanosleep","symbolLocation":196,"imageIndex":2},{"imageOffset":3578680,"symbol":"ScObjects::Thread::wait(unsigned int)","symbolLocation":56,"imageIndex":20},{"imageOffset":3467410,"symbol":"ScObjects::BridgeTalkThread::run()","symbolLocation":290,"imageIndex":20},{"imageOffset":3577575,"symbol":"ScObjects::Thread::go(void*)","symbolLocation":151,"imageIndex":20},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23151,"name":"UI Worker 3","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":22054736,"imageIndex":5},{"imageOffset":22053596,"imageIndex":5},{"imageOffset":22060014,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23152,"name":"TaskSchedulerServiceThread","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":0},{"imageOffset":39717593,"imageIndex":21},{"imageOffset":39708093,"imageIndex":21},{"imageOffset":39704510,"imageIndex":21},{"imageOffset":39185109,"imageIndex":21},{"imageOffset":39399044,"imageIndex":21},{"imageOffset":39473942,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23153,"name":"TaskSchedulerForegroundWorker","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":39277696,"imageIndex":21},{"imageOffset":39277969,"imageIndex":21},{"imageOffset":39380216,"imageIndex":21},{"imageOffset":39382403,"imageIndex":21},{"imageOffset":39381556,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23154,"name":"TaskSchedulerForegroundBlockingWorker","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":39277696,"imageIndex":21},{"imageOffset":39277969,"imageIndex":21},{"imageOffset":39380216,"imageIndex":21},{"imageOffset":39382403,"imageIndex":21},{"imageOffset":39381556,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23155,"name":"TaskSchedulerBackgroundWorker","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":39277696,"imageIndex":21},{"imageOffset":39277969,"imageIndex":21},{"imageOffset":39380216,"imageIndex":21},{"imageOffset":39382403,"imageIndex":21},{"imageOffset":39381412,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23157,"name":"Chrome_IOThread","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":0},{"imageOffset":39717593,"imageIndex":21},{"imageOffset":39708093,"imageIndex":21},{"imageOffset":39704510,"imageIndex":21},{"imageOffset":39185109,"imageIndex":21},{"imageOffset":22374980,"imageIndex":21},{"imageOffset":39473942,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23158,"name":"NetworkConfigWatcher","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":523601,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":11},{"imageOffset":517135,"symbol":"__CFRunLoopRun","symbolLocation":1329,"imageIndex":11},{"imageOffset":514057,"symbol":"CFRunLoopRunSpecific","symbolLocation":567,"imageIndex":11},{"imageOffset":395102,"symbol":"-[NSRunLoop(NSRunLoop) runMode:beforeDate:]","symbolLocation":216,"imageIndex":13},{"imageOffset":39049856,"imageIndex":21},{"imageOffset":39045607,"imageIndex":21},{"imageOffset":39185109,"imageIndex":21},{"imageOffset":39473942,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23159,"name":"DnsConfigService","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":0},{"imageOffset":39717593,"imageIndex":21},{"imageOffset":39708093,"imageIndex":21},{"imageOffset":39704535,"imageIndex":21},{"imageOffset":39185109,"imageIndex":21},{"imageOffset":39473942,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23160,"name":"TaskSchedulerForegroundBlockingWorker","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":39277696,"imageIndex":21},{"imageOffset":39277969,"imageIndex":21},{"imageOffset":39380216,"imageIndex":21},{"imageOffset":39382403,"imageIndex":21},{"imageOffset":39381556,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23161,"name":"TaskSchedulerForegroundBlockingWorker","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":39277696,"imageIndex":21},{"imageOffset":39277969,"imageIndex":21},{"imageOffset":39380216,"imageIndex":21},{"imageOffset":39381794,"imageIndex":21},{"imageOffset":39381556,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23162,"name":"TaskSchedulerBackgroundBlockingWorker","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":39277696,"imageIndex":21},{"imageOffset":39277969,"imageIndex":21},{"imageOffset":39380216,"imageIndex":21},{"imageOffset":39382403,"imageIndex":21},{"imageOffset":39381412,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23163,"name":"CompositorTileWorker1\/177411","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":39667413,"imageIndex":21},{"imageOffset":55959928,"imageIndex":21},{"imageOffset":39470964,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23164,"name":"AudioThread","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":39277696,"imageIndex":21},{"imageOffset":39277375,"imageIndex":21},{"imageOffset":39045277,"imageIndex":21},{"imageOffset":39185109,"imageIndex":21},{"imageOffset":39473942,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23165,"name":"TaskSchedulerSingleThreadForegroundBlocking0","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":39277696,"imageIndex":21},{"imageOffset":39277375,"imageIndex":21},{"imageOffset":39380202,"imageIndex":21},{"imageOffset":39382403,"imageIndex":21},{"imageOffset":39381652,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23171,"name":"TaskSchedulerSingleThreadBackgroundBlocking1","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":39277696,"imageIndex":21},{"imageOffset":39277375,"imageIndex":21},{"imageOffset":39380202,"imageIndex":21},{"imageOffset":39382403,"imageIndex":21},{"imageOffset":39381508,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23172,"name":"TaskSchedulerSingleThreadSharedBackgroundBlocking2","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":39277696,"imageIndex":21},{"imageOffset":39277375,"imageIndex":21},{"imageOffset":39380202,"imageIndex":21},{"imageOffset":39381794,"imageIndex":21},{"imageOffset":39381460,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23173,"name":"TaskSchedulerSingleThreadSharedForegroundBlocking3","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":39277696,"imageIndex":21},{"imageOffset":39277375,"imageIndex":21},{"imageOffset":39380202,"imageIndex":21},{"imageOffset":39381794,"imageIndex":21},{"imageOffset":39381604,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23176,"name":"NetworkConfigWatcher","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":523601,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":11},{"imageOffset":517135,"symbol":"__CFRunLoopRun","symbolLocation":1329,"imageIndex":11},{"imageOffset":514057,"symbol":"CFRunLoopRunSpecific","symbolLocation":567,"imageIndex":11},{"imageOffset":395102,"symbol":"-[NSRunLoop(NSRunLoop) runMode:beforeDate:]","symbolLocation":216,"imageIndex":13},{"imageOffset":39049856,"imageIndex":21},{"imageOffset":39045607,"imageIndex":21},{"imageOffset":39185109,"imageIndex":21},{"imageOffset":39473942,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23178,"name":"CacheThread_BlockFile","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":0},{"imageOffset":39717593,"imageIndex":21},{"imageOffset":39708093,"imageIndex":21},{"imageOffset":39704510,"imageIndex":21},{"imageOffset":39185109,"imageIndex":21},{"imageOffset":39473942,"imageIndex":21},{"imageOffset":39670887,"imageIndex":21},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23211,"name":"com.apple.NSEventThread","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":523601,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":11},{"imageOffset":517135,"symbol":"__CFRunLoopRun","symbolLocation":1329,"imageIndex":11},{"imageOffset":514057,"symbol":"CFRunLoopRunSpecific","symbolLocation":567,"imageIndex":11},{"imageOffset":1756396,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23256,"name":"UI Worker 4","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":22054736,"imageIndex":5},{"imageOffset":22053596,"imageIndex":5},{"imageOffset":22060014,"imageIndex":5},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23257,"name":"Background DOM Loader Thread - UXP JavaScript Thread","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":768924,"imageIndex":14},{"imageOffset":766673,"imageIndex":14},{"imageOffset":781522,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23286,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":2474622,"imageIndex":14},{"imageOffset":2439036,"imageIndex":14},{"imageOffset":2415963,"imageIndex":14},{"imageOffset":2415731,"imageIndex":14},{"imageOffset":2432228,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23287,"frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":0},{"imageOffset":2429807,"imageIndex":14},{"imageOffset":2439098,"imageIndex":14},{"imageOffset":2415963,"imageIndex":14},{"imageOffset":2415731,"imageIndex":14},{"imageOffset":2375996,"imageIndex":14},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23819,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23820,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23821,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23822,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23823,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23963,"name":"cr_scratch","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":0},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":1},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":14843995,"imageIndex":16},{"imageOffset":11577009,"imageIndex":16},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":23967,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23968,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23969,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23970,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23971,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23972,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23973,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23974,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23975,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23977,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23978,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":23979,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703628931072,
    "size" : 225280,
    "uuid" : "12bd6f13-c452-35ee-9069-51befef29f1a",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703629156352,
    "size" : 49152,
    "uuid" : "29a2750e-f31b-3630-8761-242a6bc3e99e",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703627915264,
    "size" : 561152,
    "uuid" : "991f58b7-b4c0-3c3a-84a8-c9c571de5a27",
    "path" : "\/usr\/lib\/system\/libsystem_c.dylib",
    "name" : "libsystem_c.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703628840960,
    "size" : 90112,
    "uuid" : "a851e310-475a-3c94-b547-8eb5ae90191a",
    "path" : "\/usr\/lib\/libc++abi.dylib",
    "name" : "libc++abi.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703627653120,
    "size" : 249856,
    "uuid" : "6b22efe4-18cc-3551-90ba-d18236104790",
    "path" : "\/usr\/lib\/libobjc.A.dylib",
    "name" : "libobjc.A.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4487557120,
    "CFBundleShortVersionString" : "22.5.1",
    "CFBundleIdentifier" : "com.adobe.Photoshop",
    "size" : 133611520,
    "uuid" : "abd52ca8-a36d-3767-898a-824cc6574f28",
    "path" : "\/Applications\/Adobe Photoshop 2021\/Adobe Photoshop 2021.app\/Contents\/MacOS\/Adobe Photoshop 2021",
    "name" : "Adobe Photoshop 2021",
    "CFBundleVersion" : "22.5.1"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4936601600,
    "CFBundleShortVersionString" : "22.5",
    "CFBundleIdentifier" : "com.adobe.ps.spaces",
    "size" : 1703936,
    "uuid" : "7b8680af-d5f9-3e45-931c-9f3c00f4be44",
    "path" : "\/Applications\/Adobe Photoshop 2021\/Adobe Photoshop 2021.app\/Contents\/PlugIns\/Required\/Spaces\/Spaces.plugin\/Contents\/MacOS\/Spaces",
    "name" : "Spaces",
    "CFBundleVersion" : "22.5"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703673057280,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 15257600,
    "uuid" : "dd0028a3-78e3-3a8a-a51b-ddd68123adef",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2113"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4791123968,
    "size" : 442368,
    "uuid" : "1a6ae033-9438-33c0-8077-988fd885250a",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703628476416,
    "size" : 364544,
    "uuid" : "91a6d960-2646-34e2-a81e-4e34e3697a92",
    "path" : "\/usr\/lib\/libc++.1.dylib",
    "name" : "libc++.1.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4653617152,
    "size" : 573440,
    "uuid" : "d9692b38-8895-3064-91ed-968b50905575",
    "path" : "\/Applications\/Adobe Photoshop 2021\/Adobe Photoshop 2021.app\/Contents\/Frameworks\/VulcanMessage5.dylib",
    "name" : "VulcanMessage5.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703629471744,
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5246976,
    "uuid" : "afcc752e-074d-340f-890c-263efd2da77f",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "1855.105"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703706296320,
    "CFBundleShortVersionString" : "1325.0.1",
    "CFBundleIdentifier" : "com.apple.CFNetwork",
    "size" : 4808704,
    "uuid" : "8a8cd85d-cf83-3019-bd2c-b99a711c97d7",
    "path" : "\/System\/Library\/Frameworks\/CFNetwork.framework\/Versions\/A\/CFNetwork",
    "name" : "CFNetwork",
    "CFBundleVersion" : "1325.0.1"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703643807744,
    "CFBundleIdentifier" : "com.apple.Foundation",
    "size" : 3911680,
    "uuid" : "d7fd0214-4bbb-3d84-88f7-820b25a6e16c",
    "path" : "\/System\/Library\/Frameworks\/Foundation.framework\/Versions\/C\/Foundation",
    "name" : "Foundation",
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4946575360,
    "CFBundleShortVersionString" : "local",
    "CFBundleIdentifier" : "com.adobe.uxp.macos.alpaca.v8",
    "size" : 41156608,
    "uuid" : "bdc87eb3-1c9c-3593-969e-da8c1bf9959b",
    "path" : "\/Applications\/Adobe Photoshop 2021\/Adobe Photoshop 2021.app\/Contents\/Frameworks\/dynamic-torqnative.framework\/Versions\/A\/dynamic-torqnative",
    "name" : "dynamic-torqnative",
    "CFBundleVersion" : "local"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 6751539200,
    "CFBundleShortVersionString" : "14.0.1 (952)",
    "CFBundleIdentifier" : "com.adobe.CameraRaw",
    "size" : 104316928,
    "uuid" : "2f93e39d-46f3-356f-bfee-daa20695e74d",
    "path" : "\/Library\/Application Support\/Adobe\/*\/Camera Raw.plugin\/Contents\/MacOS\/Camera Raw",
    "name" : "Camera Raw",
    "CFBundleVersion" : "14.0.1f952"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4710739968,
    "size" : 64557056,
    "uuid" : "4e843307-4d4a-3350-873e-2f7a7e48c9ab",
    "path" : "\/Applications\/Adobe Photoshop 2021\/Adobe Photoshop 2021.app\/Contents\/Frameworks\/libmkl_core.dylib",
    "name" : "libmkl_core.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4658601984,
    "CFBundleIdentifier" : "com.adobe.headlights.LogSessionFramework",
    "size" : 1507328,
    "uuid" : "96cb4041-f593-393f-a5ed-3e0e00a1f882",
    "path" : "\/Applications\/Adobe Photoshop 2021\/Adobe Photoshop 2021.app\/Contents\/Frameworks\/LogSession.framework\/Versions\/A\/LogSession",
    "name" : "LogSession",
    "CFBundleVersion" : "8.2.0.16"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4643442688,
    "size" : 131072,
    "uuid" : "6847c745-6a55-3135-b251-bf03bbe525fb",
    "path" : "\/Applications\/Adobe Photoshop 2021\/Adobe Photoshop 2021.app\/Contents\/Frameworks\/libtbb.dylib",
    "name" : "libtbb.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 5021458432,
    "CFBundleIdentifier" : "com.adobe.PSAutomate",
    "size" : 4390912,
    "uuid" : "dbf8b6be-3e3f-399d-97cf-6882f708a653",
    "path" : "\/Applications\/Adobe Photoshop 2021\/Adobe Photoshop 2021.app\/Contents\/PlugIns\/Required\/Extensions\/ScriptingSupport.plugin\/Contents\/MacOS\/ScriptingSupport",
    "name" : "ScriptingSupport",
    "source" : "P",
    "arch" : "x86_64",
    "base" : 6331609088,
    "CFBundleShortVersionString" : "3.3626.1882.0",
    "CFBundleIdentifier" : "org.chromium.ContentShell.framework",
    "size" : 119287808,
    "uuid" : "0e0cf0df-f3bd-3ea0-aeeb-f8f6ec8157d6",
    "path" : "\/Applications\/Adobe Photoshop 2021\/Adobe Photoshop 2021.app\/Contents\/PlugIns\/Required\/Spaces\/Frameworks\/Chromium Embedded Framework.framework\/Chromium Embedded Framework",
    "name" : "Chromium Embedded Framework",
    "CFBundleVersion" : "1882.0"
  "sharedCache" : {
  "base" : 140703625916416,
  "size" : 15215640576,
  "uuid" : "b5084610-afe4-3485-bade-628c4468b057"
  "vmSummary" : "ReadOnly portion of Libraries: Total=1.8G resident=0K(0%) swapped_out_or_unallocated=1.8G(100%)\nWritable regions: Total=4.0G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=4.0G(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               768K        6 \nActivity Tracing                   256K        1 \nCG backing stores                 3600K        8 \nCG image                          2480K       46 \nColorSync                          240K       28 \nCoreAnimation                     74.9M       66 \nCoreGraphics                        16K        3 \nCoreServices                       624K        2 \nCoreUI image data                 2792K       25 \nFoundation                          44K        2 \nImage IO                           292K       29 \nKernel Alloc Once                    8K        1 \nMALLOC                             1.8G      888 \nMALLOC guard page                   48K       10 \nMALLOC_LARGE (reserved)            412K        1         reserved VM address space (unallocated)\nMALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)\nMemory Tag 255                   677.2M     1073 \nMemory Tag 255 (reserved)           16K        1         reserved VM address space (unallocated)\nPROTECTED_MEMORY                     4K        1 \nSQLite page cache                  192K        3 \nSTACK GUARD                       56.4M      112 \nStack                            289.4M      114 \nVM_ALLOCATE                        1.2G      115 \n__DATA                            86.5M      631 \n__DATA_CONST                      29.6M      347 \n__DATA_DIRTY                      1591K      211 \n__FONT_DATA                          4K        1 \n__GLSLBUILTINS                    5176K        1 \n__LINKEDIT                       662.2M       84 \n__OBJC_RO                         81.6M        1 \n__OBJC_RW                         3120K        3 \n__TEXT                             1.2G      615 \n__UNICODE                          588K        1 \ndyld private memory               1024K        1 \nlibnetwork                        1664K       24 \nmapped file                      255.8M       66 \nshared memory                      776K       18 \n===========                     =======  ======= \nTOTAL                              6.7G     4540 \nTOTAL, minus reserved VM space     6.4G     4540 \n",
  "legacyInfo" : {
  "threadTriggered" : {
    "queue" : "com.apple.main-thread"
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "5fc94383418129005b4e9ae0",
      "factorPackIds" : {
      "deploymentId" : 240000153
      "rolloutId" : "60da5e84ab0ca017dace9abf",
      "factorPackIds" : {
      "deploymentId" : 240000008
      "rolloutId" : "607844aa04477260f58a8077",
      "factorPackIds" : {
        "SIRI_MORPHUN_ASSETS" : "6103050cbfe6dc472e1c982a"
      "deploymentId" : 240000066
      "rolloutId" : "601d9415f79519000ccd4b69",
      "factorPackIds" : {
        "SIRI_TEXT_TO_SPEECH" : "618455f04b3765609b8b78c1"
      "deploymentId" : 240000311
      "rolloutId" : "602ad4dac86151000cf27e46",
      "factorPackIds" : {
        "SIRI_DICTATION_ASSETS" : "6189b1ae4b3765609b8b7ec1"
      "deploymentId" : 240000264
      "rolloutId" : "5ffde50ce2aacd000d47a95f",
      "factorPackIds" : {
      "deploymentId" : 240000076
  "experiments" : [
Model: MacPro7,1, BootROM 1715.40.15.0.0, 8 processors, AMD Ryzen 7 2700 Eight-Core Processor, 3,2 GHz, 16 GB, SMC
Graphics: Radeon RX 560, Radeon RX 560, PCIe, 4 GB
Display: U28E590, 3840 x 2160 (2160p/4K UHD 1 - Ultra High Definition), Main, MirrorOff, Online
Display: HA240Y, 1920 x 1080 (1080p FHD - Full High Definition), MirrorOff, Online
Memory Module: P0 CHANNEL A/DIMM 1, 8 GB, DDR4, 3200 MHz, Kingston, KHX3200C16D4/8GX
Memory Module: P0 CHANNEL B/DIMM 1, 8 GB, DDR4, 3200 MHz, Kingston, KHX3200C16D4/8GX
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: WDC  WDS500G2B0B-00YS70, 500,11 GB
Serial ATA Device: WDC WD5000LPVX-22V0TT0, 500,11 GB
Serial ATA Device: KINGSTON SA400S37480G, 480,1 GB
USB Device: USB30Bus
USB Device: Microsoft® 2.4GHz Transceiver v7.0
USB Device: GXT 101 Gaming Mouse
USB Device: USB31Bus
USB Device: HD Web Camera
Thunderbolt Bus:
Edited by fabiosun
spoiler and English (next one will be deleted)
Le 19/11/2021 à 15:18, fabiosun a déclaré :
I have been doing this message for many days since I have been on this problem, and after searching through internet I have not found any solutions yet.
So, I recently changed bluid, for this:
B550 Vision D
Ryzen 9 5900x 12-Core
Radeon RX 6800XT 16GB
NVMe WD_BLACK SN850 500 GB
Crucial Ballistix 3200 MHz, DDR4 2x 32GB
macOS Big Sur 11.6.1 (iMac Pro 2017)
Since then I have hardly encountered any problems, expect in Premiere Pro and in After Effects, warp stabilizer and Tracker camera don't work, when I drag it on footage, Pr craching imedialely and Ae stay at 0%.
How have you patch the issue in this video ?
to explain better:
After Effects CC
Libraries to be patched:
1) libiomp5.dylib
2) libmkl_core.1.dylib
3) libmkl_avx512.1.dylib
Photoshop:
Library / plugin to be patched:
1) libmkl_core.dylib
2) Adaptive Wide angle
Premiere Pro:
Effects / plugins to be patched:
1) Warp Stabiliser
2) Rolling Shutter
3) Morph Cut
The environment.plist method requires SIP disabled not because of Zii but because it's not possible to link the fakdylib with SIP enabled. So the best way is to actually patch the adobe dylib directly but fabiosun and tomnic have not showed how to perform this direct patch yet.
9 hours ago, Raven90z said:
@TReXintosh humm, I undersand what to do, but I don't quite understand how to do it, everything is mixed up in the thread 😕
This thread is a wip project
now we have reached our goal to patch only things we need
@tomnicwill describe his method when it will be possible
for now if you want post an external link with those libs if you need
and I will patch it for you (for PS see here: https://www.macos86.it/topic/5299-adobe-photoshop-2251-amd-fix/)
if so you have only to use those libs and disable all old methods
@zoiko192
by the way
here we do not teach to crack a software
we try to have it working on AMD Cpu system
Edited by fabiosun
6 hours ago, fk2106 said:
  Same here, it's not obvious where the patched files are.
Solution is pretty simple
Our problem is  many people lurk here without helping with some debug
So me and overall @tomnicare trying to debug all Adobe creative features from our own
Our main goal is to have our OSX system more vanilla we can, without injecting stuff for all app (that do not need of any patches I mean), and in my case also to have SIP Enabled! 🙂
From a crash log you can find two useful indications:
1) library which fails and its path
2) the reason
Then, with a disassembler and an HEX app is possible to locate and change some bytes to have library calls redirected to AMD compliant instructions 🙂
Thanks always @tomnic, with this idea we have a nice improvment to old patching method and not only for Adobe applications, also for many others (discord, Luminar, Maya,Matlab.. and so on)
Edited by fabiosun
@Raven90z
with which app have you problem?
If it is Photoshop...which version?
if you use 22..5.1, @tomnic has posted in a thread libs you need
to patch you have to do:
1) overwrite original lib (if app you are using is the same (IE 22.5.1)
2) resign it if you have sip enabled
obviously you have to work without any old patching method.
to be more clear
all methods we posted (lib posted) are working perfectly
If you have some problem with that app you can post a detailed log or when problem happens 🙂
10 minutes ago, Raven90z said:
Maybe I can you send my crash log ?
you can zip it and to attack it here or create a new thread
  • tomnic changed the title to [WIP] Photoshop, After Effects CC 2021, Premiere Pro CC 2021 15.4 AMD hackintosh fix
  • fabiosun unpinned this topic
  • fabiosun locked this topic
