Big Sur 11.3 beta fail on Zenith II extreme
ddk
since Big Sur 11.3 beta and later all are fail to boot with my T-Rex40 Zenith ii extreme, AMD Ryzen TR 3960x.
latest AMD_Vanilla patch applied
OpenCore 0.6.6 and 0.6.7 both failed, 6 hours stuck on "flush" messages
is there any solution ?
is there any solution?
Edited by ddk
  • ddk changed the title to Big Sur 11.3 beta fail on Zenith II extreme
27 minutes ago, fabiosun said:
do you mean you have yet installed it or you see many verbose errors?
It could be a very long process to install this beta ..many verbose errors
I see also many patches our chipset does not need ..(ie Fix Pat related ones)
this is After installing 11.3 beta 2 update,
and even boot from recovery environments not possible boot stuck.
how long does it takes I waited 6 hours.
screenshot after disabling fix Pat
@ddk
try this EFi and see if you have the same problem...
or different one
sometimes some quirks could create problem..but not usb related for now...memory map related one..
let me know
first you must be sure you have installed it well
because also in real MC installation was problematic in beta 2 (d version)
change in this EFI only mmio part..insert yours
Edited by fabiosun
@ddk
sorry but Are you trying with rx 6900 xt only inserted?
if so it seems no support for this in latest beta ()no support at all , before in vesa it was working)
I saw also @valmeida has a similar problem with latest beta if i am not wrong at all..
i cant test because i have sold my reference 6900xt)
14 minutes ago, fabiosun said:
@ddk
if you are using only Big Sur you can try also to simplify your huge used patches ...
you can try this reduced set I am using for BigSur 11.2.1 and latest 11.3 beta 2
Thanks but I with reduced patches Kernel Panic on both 11.2.1 and 11.3 beta 2
don't you think this is weird?
20 minutes ago, fabiosun said:
if you want
try to use these set of patches 🙂
if it works also for you..check then stability in your usual daily workflow!
the one of @Arrakis's works for me on 11.2.1 and a bit faster , I didn't test on 11.3 ignoring for now.
I will test the one you sent me and let you know how it goes.
reduced-config.zip
Edited by ddk
with latest 11.3 beta you have to use an updated one you can find in my creduced set 🙂
with Arrakis we did time ago this discovery..MSI motherboard does not need of topology cpu patch..Gigabyte..and now ASUS yes
I do not know why 🙂
Tomorrow I will receive "Sonnet eGPU Breakaway Puck Radeon RX 5700"
Is there any special setup in opencore except for bootArguments agdpmod=pikera and disabling Internal GPU RX 6900 XT ?
Is the EGPU may solve my booting problem on 11.3 beta ?
