Testing our GPU in OSX/Linux/Windows in pro app (Blackmagic DaVinci Resolve Studio /AE/PR Pro,PS)
In this thread is possible to post  benchmarks with owned GPU ('s)
Candle benchmark for DaVinci Resolve Studio
Thread is open also for unsupported GPU in OSX like 6900 xt, 6800 Xt, 6800 (we hope in a near support for them) but also it is possible to post results for Nvidia GPU like RTX series that will never be supported by OSX (Sob 🙂)
I will start with mine GPU, you can see in this video
On YouTube a simple video showing initial Davinci resolve setup (OpenGL / Metal or Cuda if it is available)
If you like you can post your results using a screenshot for frame rate in different environment you use
It is welcome any new GPU benchmark (AMD rx 6900 xt and similar 🙂 🙂 )
You must play inside Color page and take note only there of your maximal FPS
Attached useful file for this benchmark
Candle benchmark.zip
  • Like 3
Gigabyte Radeon Vega 64 Gaming OC 8 GB
OSX 11.1 (20C69)
Metal:
66 noise nodes
14/15/16 fps
6TRN nodes
19/20/21
OpenCL:
66 noise nodes
7/8/9 fps
6TRN nodes
6/7
Windows 10 Pro 64 Bit
OpenCL:
66 noise nodes
12/13 fps
6TRN nodes
17/18/19
Gigabyte Radeon Pro WX 9100 16 GB
OSX 11.1 (20C69)
Metal:
66 noise nodes
13 /14 fps
6TRN nodes
19 / 20 fps
OpenCL:
66 noise nodes
7 / 8 fps
6TRN nodes
9 / 10 fps
OpenCL:
66 noise nodes
10 / 11 fps
6TRN nodes
17/18 fps
The same for my actual temporary 1080ti in macOS High Sierra, cough cough 😛
MSI GeForce GTX 1080ti Aero 11Gb
macOS 10.13.6
CUDA
66 blur nodes
15 fps
6 TRN nodes
21/22 fps
Windows 10 Pro 64 bit
CUDA
66 blur nodes
14 fps
6 TRN nodes
19 fps
 AMD Radeon Rx 6900 XT 16 GB
OSX 11.1 (20C69)
Metal:
66 noise nodes
SOB
6TRN nodes
SOB
OpenCL:
66 noise nodes
SOB
6TRN nodes
Sigh :)
OpenCL:
66 noise nodes
23/24 fps
6TRN nodes
33/34
17_Beta 6
Software is unrensponsive..not production ready with new GPU in my case
Sapphire RX 5700 XT 8G
Davinci Resolve 17.1 Beta 7 (Free Edition)
macOS 11.1
Metal
66 blur nodes
15 fps
6 TRN nodes
20 fps
OpenCL
66 blur nodes
8 fps
6 TRN nodes
10 fps
Edited by jsq2627
post davinci version
@6900 or 6800xt users😂
could try candle davinci benchmark with resize bar on and off and see if benchmark results are better or lower?
I am trying with a rtx 3090 in Windows and without resize bar on they are pretty similar of mine and @Ploddlespreviously posted results
thanks
😀 Just for information, since version 17.1 of Resolve Studio, there is no longer a need for the patch (Matlabs). In addition, the "libiomp5.dylib" file is no longer present in the application library and therefore inoperative.
617554104_Capturedecran2021-03-14a20_24_40.thumb.png.c39bb9c9f9b49484348d6e39255e1d03.png
  • fabiosun changed the title to Testing our GPU in OSX/Linux/Windows in pro app (Blackmagic DaVinci Resolve Studio /AE/Premiere Pro)
to complete without error this production Davinci Resolve Benchmark i have had to put a fan pumping fresh air to 3090 FE backplate
due huge GPU memory temperatures during this test..
results are great
  • 4 weeks later...
Thanks @valmeida 's great patience, we were able to do some tests via remote access to his machine
the good news is that some refresh issues in windows have also been fixed
the bad news is that for the moment the metal driver is not as performing as it should
At the moment the results are about
21/24 frames with 6 nodes
17 with 66 nodes
I also tried working with 8k red videos and the processing runs smoothly  in windows as in OSX
In windows we have results compatible with the other tests made in the past by me , @meina222and @Ploddles
For now, in OSX the Candle Benchmark results are comparable with a vega 64 previously owned by me
It is very weird because others aspect in editing and coloring are identical in windows
to give more datas and infos about my simple testing:
I have used three footage in 8k resolution on a multi layer timeline (RED camera footage)
Playback was set @ 25 frame/s
system is playing  @ right and constant speed i have set in project settings
we hope in future driver enhancement in OSX
  • fabiosun changed the title to Testing our GPU in OSX/Linux/Windows in pro app (Blackmagic DaVinci Resolve Studio /AE/PR Pro,PS)
