MSI TRX40 - CATALINA 10.15.7 - BOOTED
eye2eyespy
sorry it is a pretty similar config which I use
If you can try all things as we said
and if it works ok you can stay with that old bios
 if not you should update to latest one which introduces a new agesa..and probably you have to modify then your MMIO values
@eye2eyespy I am pretty sure that EFI works well on three similar system..so problem should be local
I have no BT or WIFI hardware..cant test it by myself
also bios Update could be an option if you are not scared to do it
Shutdown problem is not the best to have 🙂
before to discover MMIO way we have all shutdown a reboot problem..your MMIo are a bit different from mine
I can't say for sure they are different cause different bios or different devices in our systems
13 minutes ago, eye2eyespy said:
ok, I am going to upgrade to oc 064 and give it a shot.
also going to get latest kexts and drivers
I will let you know how it goes.
see above message
latest EFI has a newer opencore than 064...
